Old 12-14-2012, 05:12 AM   #4006
ragtoplvr
Oddometer: 6,406
Originally Posted by dmac57 View Post
There was mention of something along the lines of "automated decompressors" during startup. Can anyone point me to that? Going to have to float a valve for that to happen, and I hadn't seen that anywhere.
You can see a centrifugal decompression device on the exhaust cam in the upper right hand corner.
Rod
ragtoplvr is offline   Reply With Quote
Old 12-14-2012, 05:14 AM   #4007
ragtoplvr
Oddometer: 6,406
Originally Posted by twray View Post
Seems unusual for one cylinder cam chain to run of the crankshaft and the other running of the counterbalance shaft. Seems some valve timing issues could result in gear wear from the counterbalance shaft and crankshaft relationship....
I suspect they wanted the slack side of the chain on the bottom. Look at some of the issues they had with the slack on the top with the oilheads. to do that one side must have reverse drive.
Rod
Old 12-14-2012, 07:19 AM   #4008
cug
Oddometer: 4,934
Originally Posted by markjenn View Post
Short of having a MP sensor that measures vacuum in each inlet tract, I don't know of any way for the system to adjust itself based on running conditions.
That reminds me of my Tiger 800: I hook up the laptop with diagnostic software and it tells me exactly how the TBs are out of sync, so it knows exactly what's wrong. It's NOT ride by wire though and and it doesn't have a computer controlled mechanism to adjust - so I have to manually adjust them. Would have been so much nicer to get ride by wire and have them automatically adjust via build in mechanism.
cug is offline   Reply With Quote
Old 12-14-2012, 08:26 AM   #4009
Dorsicano OP
Oddometer: 88
prices in Germany
New GS retail price in Germany (19% VAT included) has been quoted by a dealer to an inmate in another bmw forum as follows:
Base price with ABS 14,100 (plus delivery)
Comfort pack 650
Aktiv pack 890
Touring pack 1,490
Dynamic pack 2,100
I'm impressed. They did not go over the top.
Dorsicano is offline   Reply With Quote
Old 12-14-2012, 10:11 AM   #4010
Hunter6
Oddometer: 5
In Holland 16950. 400 less then the 2012 GS
Hunter6 is offline   Reply With Quote
Old 12-14-2012, 10:17 AM   #4011
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Originally Posted by Marki_GSA View Post
The current boxers don't require a sync on the idle circuit (idle servo) its only the mechanical cable part that you can adjust part throttle. I don't know if the new drive by wire uses a separate idle, main servo or if it's just one but however they do it now on the idle could be used on the new system.
Throttle sync is part of routine maintenance...every 6k on the boxer motors.
EJ_92606 is offline   Reply With Quote
Old 12-14-2012, 10:46 AM   #4012
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,531
Of idle throttle sync. The idle balance can (and should) be checked, but if it is off by more than 25 mbar BMW says check for air leaks and make sure the valves are the same side-to-side. There is no other adjustment specific to idle balance. That's through '09 models... I assume the camheads are the same.
It wouldn't surprise me if the LC bikes are the same, less any off idle throttle cable adjustments.
marchyman is offline   Reply With Quote
Old 12-14-2012, 11:56 AM   #4013
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I never said anything about idle balance, just the routine throttle synchronization on camhead and previous boxers. The new water boxer does not require this.
Old 12-14-2012, 01:12 PM   #4014
Marki_GSA
Oddometer: 577
I was using the current none udjustable idle sync as an example of how they currently know where the valves should be. I. E they can do it now so they can do it for the whole setup on the new engines. I already stated you can and need to adjust the off idle on the current models because it's mechanical.
Marki_GSA is offline   Reply With Quote
Old 12-14-2012, 02:15 PM   #4015
Montauk
Oddometer: 280
Dynamic ESA with Low Suspension question
I am trying to track back to my question to BMW Rep from NJ for him to recommend me to go with Standard GS with low seat option. I had shown my 30" inseam limitation and need for a lowered suspension to him. With Standard, I barely got the bike off the stand and was tippie towing.
Someone here mentioned that Dynamic ESA is not available with Low suspension for the WC. I searched google and could not find the answer. I wanted to confirm this.
Called my local dealer, he said with current model ESA is not available with low suspension, but he could not confirm same holds true for the new water cooled GS.
Does anyone have any answer, or have talked to the BMW rep and gotten any answer whether Dynamic ESA is available with Low Suspension.
.... I wish I was 6 foot tall, and then I wouldn't have had these problems.
Montauk is offline   Reply With Quote
Old 12-14-2012, 03:26 PM   #4016
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,341
Originally Posted by 6USMC6 View Post
Jim -
Just looking at the above print, do you think it would be possible to pull the driveshaft out through the swingarm, grease the spline and then push it back in?
Or would you have to drop the swingarm?
It looks like it, but it depends on the diameter of the swingarm. I am guessing yes.
Jim
Old 12-14-2012, 04:22 PM   #4017
Treadless
seeking adventure
Treadless's Avatar
Oddometer: 5,360
Have you had the opportunity to mount the h2ohead? I found the seat and seating position much more accommodating to those of us that were short changed in the leg department. And the overall ergos fit me much better than my '05 even with the changes that I made to it. You may find that the bike may not need to be lowered.
Oh, and about your question, I have no idea about a lower ESA version.
Treadless is offline   Reply With Quote
Old 12-14-2012, 05:14 PM   #4018
Dude69
Usurper of Gov'ts
Dude69's Avatar
Oddometer: 1,409
30" inseam.. you should be fine on a standard GS. Mine tops out at 29" and I rode an 08 GS and able to ride 800GS and taller bikes...
Motard stops are the rage... ;)
"I've never had a bike ask me if I'm going to be inside riding my wife all day"
1999 BMW R1200C & 2007 BMW R1200S
Past loves: 2008 R1200GSA/2001 R1200CLC & Phoenix /2005 F650GS/2002 R6/1973 R50/5 Toaster
IBA #32752
Dude69 is offline   Reply With Quote
Old 12-14-2012, 05:45 PM   #4019
Montauk
Oddometer: 280
That is amazing. I couldn't even get the F800GS off the side stand. My dealer always had to remind me that 800GS just not or me, but 1200GS is better option.
I saw one one gentleman at the Long Beach show, about my height and probably same inseam as mine, mounted the bike and was tippie towing. I went before he did, and I was nervous. He said even if he does not flat foot, he's okay with the I pipe tow.
Old 12-14-2012, 05:48 PM   #4020
Montauk
Oddometer: 280
Yes, I was able to mount the bike, albeit with BMW Rep from the back to make sure if I lift up and can't touch the ground I didn't wanted it fall. Bi was on the toes an not even the feet balls.
Times are GMT -7.   It's 01:49 AM.
