Old 12-09-2012, 02:31 PM   #3106
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,213
Here are some pics of the Seat Concepts low seat foam, with the original cover. I brought it to an upholsterer because I thought he would have to add some material around the edges to get it to fit.. but he didnt need to... If I had known that I would have done it myself... like I did on the DRZ in the background. You can also see the laminated error code list I taped to the bottom of the seat.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 12-09-2012, 04:16 PM   #3107
Gargoyle
Trail Jester
Gargoyle's Avatar
Oddometer: 1,180
Originally Posted by mrt10x View Post
I just sent another OEM seat off to Renazco to have true long distance seat made, I will report on the difference after Christmas when I get the back.
I am interested to hear about the differences between the Renazco and SC.
I was trail boss for our fall Dual Sport event riding 150 miles each day that weekend. I really liked the comfort of the Renazco and so did my butt.
'11 Husaberg FE570S
'12 KTM 990
'13 Husaberg FE350
Berkshire Trail Riders on Facebook or follow me on Twitter
Gargoyle is offline   Reply With Quote
Old 12-09-2012, 04:22 PM   #3108
Rockcat
LDA
Rockcat's Avatar
Oddometer: 382
I have a seat concepts on my FX. It is a very nice production seat. I had a Renazco on my 950 ADV. Full custom seat set up for height, weight of the rider; not an apples to apples comparison. For the price, the seat concepts is great and all I need for my Berg.
Rockcat is offline   Reply With Quote
Old 12-10-2012, 04:34 AM   #3109
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,741
Originally Posted by BogeyMan View Post
And, in that thread there's this tantalizing picture:
Looks like they're a lot lighter in color than the originals. Personally, I like that.
Perfect. If I keep the berg I will go that route for the extra fuel needed for longer trail rides around here.
Seth S
Seth S is offline   Reply With Quote
Old 12-10-2012, 08:03 AM   #3110
PABiker
Anywhere but here
Oddometer: 3,923
Originally Posted by Sproat Sport View Post
Continuing on with my display lights problem (high beam, low fuel and signal)....I checked the little bulbs and they are fine. so...don't know what to do now.
Most likely all those lights are tied to the same ground, look for the common color wire from each light and see where they go. KTM typically uses brown for the common and they like to tie them together with a crimp connection before attaching to a frame point. Look for a break in that connection.
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 12-11-2012, 06:53 PM   #3111
RememberTheFallen
RememberTheFallen's Avatar
Oddometer: 400
Anyone know where I can get the colored housings for the the 4 indicators that surround the computer? I was disassembling my computer protector and managed to break TWO of the little housings that the bulbs sit in when trying to remove them. Anyone know where I can get them? Searching kept coming up with the actual bulbs themselves.
RememberTheFallen is offline   Reply With Quote
Old 12-11-2012, 08:28 PM   #3112
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,240
Bergparts.com can usually get anything Husaberg (or KTM). You have to hunt down the KTM part#'s in a microfiche like here at elitektm, or in your Spare Parts manual that comes with new FE Bergs if you have that.
I have experience with Bergparts and they carry a lot in stock but likely they will have to be ordered from the KTM warehouse anyway, which any KTM or Husaberg dealer can also do.
cyborg screwed with this post 12-11-2012 at 10:01 PM Reason: added parts list
cyborg is offline   Reply With Quote
Old 12-12-2012, 09:41 AM   #3113
RememberTheFallen
Oddometer: 400
Thanks Cyborg! Just what I was looking for but couldn't find.
Old 12-13-2012, 08:59 PM   #3114
WetSideRider
Oddometer: 1,199
'10 FE 390 Idle Issue
I just reassembled my bike after a major rebuild (don't ask). It starts and runs fine with the idle adjustment screw pulled out, but dies immediately after the screw is pushed in. Before the rebuild it started flawlessly even in winter with no idle adjustment needed.
I can get the bike to continue running with the screw pushed in, but it sounds starved for air or fuel, running ragged. I think I smell a bit of unburned gas, which would indicate a rich condition, I'd guess.
Any ideas? No FI codes come up. Injector was recently replaced.
Oh, and an odd thing with the injector is that it was installed by the dealer with two seal rings (p/n 75041023010). I took one out when I reassembled, since the parts diagram only shows one. Did I do that wrong?
WetSideRider is offline   Reply With Quote
Old 12-15-2012, 09:25 AM   #3115
ribmtrider
Oddometer: 131
FI repair thoughts
I am ready to buy a new '11 fe390, my only reservation being that the closet dealer is 5 hrs away, and having a FI issue. Can I troubleshoot/reset the FI system w/o a scan tool? How about changing fuel mapping? Other than these unknowns with the FI I am ready to pick one up!
Tim
ribmtrider is offline   Reply With Quote
Old 12-15-2012, 09:54 AM   #3116
Tee2
I SAID! Woo Hoo!
Oddometer: 1,278
Tim
I bet I was thinking about buying the same bike you are. (About 3 hours away from me) If I didn't need to replace one of our cars it would be sitting in my garage now.
From what I heard and read most of the FI problems where in the earlier models. The later 2011 had fewer FI problems.
If it is the same dealer I talked to they said they would work with you and send you warrantied parts. Sounds like they sell a quite a few bikes to people that don't line in the area. That doesn't help you with remapping though. Maybe a KTM dealer would do that for you. Funny thing my local KTM shop said they would not work on them of sell parts for them.
I wish you where closer to me and you get it I would like to ride one.
Todd
Tee2 is offline   Reply With Quote
Old 12-15-2012, 02:49 PM   #3117
rensho
Oddometer: 182
Tim
If it is a new bike from a Husa dealer, they should unlock the ecu for you before it leaves their hands. If it is used, and still locked, you can send it to a dealer for unlock and remap. I've read people have done that for $50.
rensho is offline   Reply With Quote
Old 12-15-2012, 04:07 PM   #3118
ribmtrider
Oddometer: 131
Thanks, what is "locked" on the ecu? They are going to remap it for me, I think "competition" mapping-does that sound right? It's a new bike.
Old 12-15-2012, 04:56 PM   #3119
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,213
There is nothing locked on the husaberg ecu's... they just come with a stock map that can be changed by the dealer. Mine was changed to the "race" map by the dealer for free, but I have heard of folks being charged as much as $100 bucks for it. The new KTM street legal 500 and 350 are truly "locked" and reportedly the dealer cant even unlock them.. a condition imposed by CARB.
If it is a new bike make sure they pull the fuel pump and ensure it has the new pump... brown topped...or green?
And that they have done the recall work on the fuel filters and the triple trees.
Sent from my DROID RAZR using Tapatalk 2
Old 12-15-2012, 05:18 PM   #3120
SoilSampleDave
Oddometer: 2,143
KTM dealers now have the tools to unlock the EXC CPUs and reload with the unrestricted "Euro" map. Just had it done. But since the FE390 was not sold as a street legal bike here in the US, doesn't it already have the best map in it?
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is online now   Reply With Quote
Times are GMT -7.   It's 06:41 AM.
