12-11-2012, 12:18 PM
#16 |
Oddometer: 26
I had an 04 KLR and thought the front end was mushy. I put in progressive springs and 15 or 20 weight oil. I liked that set up. The GS tends to dive on hard braking but I'm getting used to it. The suspension is OK but not great IMHO. I would like to get into some more off road stuff and adjustment up front would be nice. The spring and oil change is just a compromise for a great system. It is pretty cheap to do!!
I do cling to my Bible and Guns! |
12-11-2012, 02:06 PM
#17 |
NoMoTDM still Gary
Oddometer: 3,705
This is the issue with the forks:
![]() ![]() That is the cartridge tube. When BMW says non adjustable they mean it, the ends are crimped. KLR's have damping rod forks. A rod/plunger forces oil through fixed holes in cartridge tube. low tech but easily modified. Thinner/thicker oil viscosity effect how fast the oil flows through the tube. You have cheap options like cartridge emulators. The 800 has a compression valve crimped into the bottom. It uses washers for the oil to pass through. The oil flows around the washer and/or bends them. The viscosity benefit is limited. Too light an oil and it gets past the washer easily. Too heavy a viscosity and it will force the washers to bend too much/ too quick. The proper fix is change the stack of washers. Usually changing springs will create a need to change the resistance in the compression valve. You can't do that with these. This is a cheap solution that causes the owners to spend more than necessary to fix. At least Triumph and KTM have better suspension guru's or accountants are not part of the design team. My first ride of substance was Death/Saline Valley. I survived it also, though not much fun. A dinged rim (22psi) and a tank slapper between Race track and Lippincott. I am chasing an ADV rider on a Wee Strom and losing. Not a lot of options in 2009. I did the springs/oil and later the first available cartridge tube. I fixed the abrupt throttle and moved the COG forward a little with suspension adjustments. That made a significant change in this bike. I now have a stabilizer, but it was the last modification and not a requirement. Yes I can ride it faster, but it is also easier to ride. Mine is a very stable bike.
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." itsatdm screwed with this post 12-11-2012 at 02:13 PM |
12-11-2012, 03:18 PM
#18 | |
Oddometer: 691
I'm starting to think about the steering damper, a roof on my house took priority of more farkles.
2009 BMW F800GS NON ABS the best thing to buy for your bike is gas.....Neduro Remote is not found on the coffee table.......seen on a T Shirt |
12-11-2012, 10:19 PM
#19 |
Oddometer: 963
I just spoke to a friend who competed at the GS Trophy In South America on a 2013 F8. He personally owns (and rides the wheels off) an 09 F8. He said the new WP forks are a huge improvement over the Marzocchi's on the 08-12 bikes. He said they still aren't as good as 48mm WP units but definitely better.
Oso Blanco screwed with this post 12-15-2012 at 03:46 AM |
12-14-2012, 07:20 PM
#20 | |
Oddometer: 554
Current: BMW Sertao "Gizelle" Past: 2012 Super Tenere, 2009 WR250X/R, 2004 Triumph Tiger 955i, 2009 KLR 685, 2006 DRZ400S, 2006 TW200, 2001 KTM 250 EXC |
12-15-2012, 03:48 AM
#21 |
Oddometer: 963
Not sure specifically what was different or changed but they rode the '13s hard at the Trophy event and were happy with the new forks for what its worth.
12-15-2012, 12:32 PM
#22 |
Oddometer: 52
forks..............
I just did a 7k trip last year on my 10' f800gs. To the point.....that suspension is shit- the upgrades are expensive-good luck...............oh yeah the rims are soft,upgrade............the throttle/fuel injection is abrupt i think they fixed it on the 13's but i haven't gone in for the upgrade to cpu so it remains to be seen..............that seat is shit get an upgrade................bent rear shock bolt- the fix was done by a customer on here! - what the fuck BMW..............haven't had the fuel pump problem but its been well documented............... overall its probably the best 50/50 bike on the market................but for the price you shouldnt have to fix all these problems that BMW used shortcuts on.
12-15-2012, 03:20 PM
#23 |
Oddometer: 2,782
Ohhhhh dear....
Erling |
12-15-2012, 03:35 PM
#24 |
Oddometer: 470
12-15-2012, 05:21 PM
#25 |
Oddometer: 52
p.s.
i was being nice
12-15-2012, 05:28 PM
#26 |
Oddometer: 2,366
I gather you don't like it then?
Forks can be sorted without spending a fortune, but it is sub-standard for a 20K bike. I still haven't found another bike that can match the F8GS for what I do on it. If there was something out there I would have it in my garage!!
"I'm a thousand miles from nowhere,Time don't matter to me, Cause I'm a thousand miles from nowhere, And there's no place I'd rather be!! |
12-15-2012, 05:50 PM
#27 | |
Oddometer: 1,320
Wot he said. I drank the Kool Aid and fitted Ohlins NIX, this was after I shagged a set of Bitubos. Cost a small fortune but worth it if you're going to use the bike for purposes it wasn't designed for, such as taking it off road.
Armageddon Was Yesterday, Today We Have a Problem East is East & West is West 2008 http://www.advrider.com/forums/ad.php?t=400050 A Long Weekend 2009 http://www.advrider.com/forums/showthread.php?t=523893 All the Way to Nowhere & Back Again. 2010 http://www.advrider.com/forums/showthread.php?t=619683 Save 5 bucks on your Smugmug, use my discount code hQo9Atub1N9jg |
12-16-2012, 12:11 AM
#28 | |
Oddometer: 1,116
Truth in advertising would be a start. Motorcycle media who didn't kiss corporate ass would help.
My trail videos. Yes, I need to learn to edit. Baby steps... https://www.youtube.com/user/DRMZ650?feature=mhee |
12-16-2012, 01:26 AM
#29 | |
Oddometer: 2,366
The bikes that have top class suspension seem to sell in such small numbers! I wonder sometimes, maybe race-bred suspension isn't what the bulk of adventure riders want? If it was, there would be a lot more 990 Adventures sold, I think they have sold about 16 in Australia this year?
12-16-2012, 02:26 AM
#30 |
Oddometer: 1,116
They didn't sell 17 because they wouldn't let me test ride one with wifey on the back.
They have dropped the price. But still no demo. BMW had demo bikes, but no stock to sell. You have to wonder.
