Old 12-16-2012, 02:26 AM   #1
viz OP
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Pissed Removing Front Shock 2010 GSA?
This one is driving me nuts...
I am reasonably good as a spannerhead but I cannot get the front shock out of my (non ESA) 2010 GSA - I am replacing them with Wilburs. Rear went in fine, no probs. I cannot get the front shock low enough to pull it out - I have tried compressing the spring and can nearly get it there, but the compressors I am using are for cars springs etc and only work up to a point. I have even dropped the front forks to see if the fork bottoms will drop some more, but to no avail.
Bottom is undone, and the base of the shock is sitting in the bottom of the telelever, as far down as it can go. I have about 5 mm of the upper shaft thread still sitting inside the steering head mount. It is almost like the shaft is too long, but it musta got in there when it was built! Alternator cover is off, front crash bar brace is still on - and I am starting to think that is where the shocky has to come out...
Any hints?
TIA
viz
Pig In The City - 2010 BMW R1200 GSA Adventure
Webmaster BMW Touring Club of NSW
viz is offline   Reply With Quote
Old 12-16-2012, 03:13 AM   #2
IJM
Hinderant Backbenderz
IJM's Avatar
Oddometer: 223
Not sure if it's the same on the 2010, but on my 2004 there was a brake line support on the right hand side that I loosened - located near the rad - top right. From there the line went down to the forks and looked like it would have stopped the forks from fully extending.
Also make sure you have the front tire off the ground so that forks can fully extend.
Horizontally opposed, Vertically challenged
IJM is offline   Reply With Quote
Old 12-16-2012, 07:06 AM   #3
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,811
Viz - Definitely a challenging event on my '07 GSA as well, and installing/removing my Elka front shock adds to the adventure as the top stud is even a couple of millimeters longer than on the stock shock.
I didn't have to resort to using a spring compressor, fiddle with the fork legs or loosen any lines, but I did pull the alternator cover and the upper horizontal crash bar for all possible clearance. As IJM mentioned, ensuring that the forks are fully extended (A-arm as low as possible) with the bike on the centerstand and a floor jack under the engine so the rear tire is touching the ground, with someone steadying the bike I'm able to wrestle (no other word for it) the shock body downward enough to get the stud clear of the hole and then the shock will come free of the bike. Of course, going back in is almost as fun....
Good luck!
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 12-16-2012, 02:04 PM   #4
viz OP
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
I let youz all now how it goes - a nights sleep has certainly helped to put a fresh perspective on it. Methinks the secret is the crashbar...
viz
Old 12-16-2012, 02:54 PM   #5
The Other JC
4 year lurker..
The Other JC's Avatar
Oddometer: 206
My 2c
I must say this is not an area I remember having issues with.
As has been mentioned, make sure the front shocks are fully extended, and the bottom of the shock is dropped, the shock then comes out top first pulling towards you. Maybe a little bit of fiddling to maneuver past the other crap in there. I do not think you will get it out bottom first - I could be wrong!
Same for install, bottom in first, to pivot the top into place. Do up the bottom bolt and gently put weight onto the front to get the top of the shock back through the top hole.
My Hyperpro went back in a lot easier due to the bottom end not being as fat as the original.
Good luck.
The Other JC is offline   Reply With Quote
Old 12-16-2012, 02:58 PM   #6
Z50Pilot
Sparky
Z50Pilot's Avatar
Oddometer: 243
Front shock removal
Originally Posted by jdub View Post
viz - ..., but i did pull the alternator cover and the upper horizontal crash bar for all possible clearance. ... Of course, going back in is almost as fun....
good luck!
+1
PJ
Never lend a friend your Pacific Coast. Unless you like scratches and want a beer annuity
Z50Pilot is offline   Reply With Quote
Old 12-16-2012, 04:09 PM   #7
Schu
Oddometer: 39
My 2011 had a strap attached to the top. Hard to see. Harder to get released.
Schu is offline   Reply With Quote
Old 12-17-2012, 02:18 AM   #8
viz OP
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Success!
Move (not remove) the front crash-bar brace a bit and the shock has room to come down. Four screws two bolts all done.
I was pushing too hard (and why wouldn't you with shiny new christmas presents to install...), too fatigued after a busy week. Couldn't see the sheep for all the wool
Thanks for the hints
viz
Old 12-17-2012, 03:23 AM   #9
IJM
IJM's Avatar
Oddometer: 223
Good on ya
Glad to hear you got it sorted out.
Old 12-17-2012, 03:30 AM   #10
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 1,881
Dig that tyre out while you're pottering around
dirtsurfer is online now   Reply With Quote
Old 12-17-2012, 03:51 AM   #11
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,404
My two cents.......
Front or rear:
On ESA models select the lowest positon first (one up,no bags) and the other no frills shocks remove all preload before attempting removal. Gives you that extra bit.......
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is online now   Reply With Quote
Old 12-17-2012, 10:26 AM   #12
Osmin C
Oddometer: 106
Originally Posted by Reaver View Post
My two cents.......
Front or rear:
This is clever and simple yet I bet that most people are not thinking to do this. Great tip!
Osmin C is offline   Reply With Quote
Old 12-17-2012, 03:12 PM   #13
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,404
Great! Glad to help. Been there, struggled with that.
Does this mean I'm forgiven for trolling? My GS's belong in the Parallel Universe.
Reaver screwed with this post 01-05-2013 at 07:12 AM
Old 12-17-2012, 06:56 PM   #14
viz OP
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Come and get it any time Max - although if that does not work I think I am up that way New Year... You must be wearing the old one out by now?
voz
Times are GMT -7.   It's 09:32 PM.
