Old 12-15-2012, 07:04 PM   #3121
RememberTheFallen
RememberTheFallen's Avatar
Oddometer: 396
Originally Posted by mrt10x View Post
There is nothing locked on the husaberg ecu's... they just come with a stock map that can be changed by the dealer. Mine was changed to the "race" map by the dealer for free, but I have heard of folks being charged as much as $100 bucks for it. The new KTM street legal 500 and 350 are truly "locked" and reportedly the dealer cant even unlock them.. a condition imposed by CARB.
If it is a new bike make sure they pull the fuel pump and ensure it has the new pump... brown topped...or green?
And that they have done the recall work on the fuel filters and the triple trees.
Sent from my DROID RAZR using Tapatalk 2
What is wrong with the triple clamps? I was aware of the fuel filter recall but after the B.S. I went thru with my dealer charging me labor after checking out a brand new bike with power loss problems I am very hesitant to ever take it back to them. The owner eventually dropped the charges and I still ride there but I refuse to ever buy a part from them and their company stickers have been removed from my bike. They aren't getting free advertising from me!
Hope it isn't a major issue cause I would hate to have to find another dealer to do the recall work.
RememberTheFallen is offline   Reply With Quote
Old 12-15-2012, 09:10 PM   #3122
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,209
sorry not triple clamps.. it was the bar clamps.. there was a recall for my 2011 570FE .. have to make sure your clamps had a single dot.. Like a center punch mark.. Mine was already done before I bought it... they called me up and asked me to check for the markings because they didnt have it in their records if they had done it before I picked it up.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 12-16-2012, 08:15 AM   #3123
RememberTheFallen
Oddometer: 396
Oh ok. Just checking. I replaced mine immediately with some risers and a top clamp from HDB to get the bars up high.
Old 12-16-2012, 09:12 AM   #3124
rensho
Oddometer: 179
What my dealer told me, and also what I've read is, before any other map can be loaded in, the ecu has to be unlocked (plugged into Husaberg tool, phoned back to HQ, unlocked). Once unlocked, any map can be loaded, and never needs to be unlocked again.
Even though the tool is same as KTM, I don't think any KTM dealer can do it since they won't have a Husaberg account for the phone home. A lot of Husa dealers are also KTM, so that won't be that much of a problem.
rensho is offline   Reply With Quote
Old 12-16-2012, 09:38 AM   #3125
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,209
Interesting.. that is the exact opposite of what my dealer told me...he is a KTM an Husa dealer up in MA. Didnt charge me for the change in maps because he said it was so simple.. plug in the computer.. change the map. Very specifically told me that it was easier than KTM, and that the new KTM's couldnt be unlocked.. but as seen above, that part seems to have changed in the 10 months since he told me that.
Old 12-16-2012, 09:52 AM   #3126
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,608
They can all be unlocked. It may take a little while to figure out but they can all be unlocked. Unless the box is designed to self destruct when tampered with.
Seth S
Seth S is online now   Reply With Quote
Old 12-16-2012, 10:36 AM   #3127
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,647
anyone install heated handgrips on a Husa? How'd you wire them up?
"There isn't any secret," he said. "It's all very obvious."
UngaWunga is offline   Reply With Quote
Old 12-16-2012, 01:01 PM   #3128
RememberTheFallen
Oddometer: 396
Lost showed how he wired some up either on this thread or the 70 degree Adventure thread that he started. I have a set I have been procrastinating on installing. Probably due it this week. I will take pics of the way NOT to do it! Lol.
Old 12-16-2012, 06:38 PM   #3129
FamilyRider
FamilyRider's Avatar
Oddometer: 282
It has been a while, so I don't remember all of the details, but here are a few thoughts to consider...
I have a 2010 FE450, so these comments apply to that bike.
There was an unused connector down below the battery. This is for auxiliary power. If you look closely at this photo, you can see two connectors to the right of the disconnected fuel sensor cable. The one on the right has a blue and a brown wire coming out. Those are my power wires going up to the headlight area. The wiring harness in this area is really tight, so you have to be careful so wires don't get pinched. I later wrapped these wires with an old tire tube.
Here is the grip heater kit I bought. I actually installed a set on all of my kid's bikes as well. The wires are really weak. Almost every one broke on our first ride. I replaced them with some automotive grade wires. I have had some switches fail as well. At first I tried the mini-toggle switch from Radio Shack, but it couldn't handle the vibration and failed. I also added an LED so I can tell when the heaters are on.
I later learned of a different brand heater kit that has a beefier left heater to compensate for it being directly on the handlebar, which sucks the heat out.
I installed a piece of heat shrink (from Home Depot) on the left grip to provide some insulation. That worked well, and it makes the bar a little larger which is nice for long fingers. But I had to use a throttle side grip to fit over it, which meant I had to buy two sets of grips.
Here is a photo of the grips installed, with the wires hanging loose. It also shows my first attempt at a switch/LED/key panel which I later replaced.
Then carefully route the wires to the headlight area and cable tie them off. Be sure the throttle side has plenty of clearance for full throttle control without the wire snagging on anything. I cable tied it to the grip for added security.
Then just hook it up as explained in the instructions and cram the extra wires in behind the headlight.
FamilyRider is offline   Reply With Quote
Old 12-16-2012, 06:48 PM   #3130
FamilyRider
Oddometer: 282
MT43 trials tire fit
I am new to this forum, but not to Husaberg or other forums (DeeG on some other sites).
I have been using Dunlop D606 on my 2010 FE450, but it is time to replace them. I have a new Pirelli MT43 rear ready to mount along with a Tubliss set. I have read posts about the fit being tight and sometimes wearing a hole in the mud guard. It seems that some people have issues, while others do not. It also seems that the chain length may be different for different model years.
I really like the stock gearing (13/52 I think), but I haven't really tried anything else. Going to the larger MT43 will gear it up slightly.
I think the 2010 stock chain is 118 rolls. I have read posts of people solving the mud guard rubbing problem by going to a longer chain, but no one specifies the size. What size chain will solve the rubbing problem but not be too long to get the proper slack in the chain?
What type of chain is stock? I haven't yet sorted this all out - I have never had to mess with chains before. I would appreciate it if someone can give me a chain part number to buy.
Thanks,
Old 12-17-2012, 08:38 PM   #3131
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,647
Ok, my 2011 390 has an open connector around the battery as well, but brown and white wires. They're used to power the rear turn signals. I bought a KTM wiring harness to make my own streetlegal kit. So it's not really "unused". Maybe I can piggyback on it to close a relay for the grip power. I did that on a couple of different bikes.
Old 12-17-2012, 08:57 PM   #3132
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,209
Thanks,
This is what I know.. my FE570 had 13/50 and a 606 from the dealer... I put a MT43 with a 48 on it with the chain adjusters all the way out.. I put a few hundred miles on it this way and when I needed to adjust the chain I had to go back to the 50 rear. I dont know how many links were in the in the chain from the dealer.. sorry too lazy to go out and count them right now.
Old 12-17-2012, 09:17 PM   #3133
FamilyRider
Oddometer: 282
I installed a set of turn signals as well (SicAss). The rear turn signals plugged into an unused connector up near the ECU, leaving the other one (which is down near the bottom of the shock) still available. According to the wiring diagram, I think it is x300, which has a brown wire and a blue/yellow wire. I am pretty sure it is for auxiliary power. The brown and green wires are the ones I added to run up to the headlight area.
2014 KTM 350 XCF-W
Old 12-18-2012, 07:41 AM   #3134
rensho
Oddometer: 179
Thanks,
I've had holes wear thru the flap when using a 17" street tire, with the axle near the back of the swinger. Higher speed runs pushed the flap back enough to touch the tire and wear through. On slower speed or dirt riding, I imagine the tire can be fairly close and still be OK. The flap is only $12 at the dealer.
I've thought about putting an elastic tie around the bottom shock collar area and poke a small hole in the flap to fasten. It should keep the flap from bending back too far, but yet still allow up/down movement.
Old 12-18-2012, 09:35 AM   #3135
FamilyRider
Oddometer: 282
That is a great idea. I have heard that the problem is due to centrifugal expansion of the tire, which may be partially true, but the mud flap getting pushed back by the air movement makes a lot of sense. I will look into that after I mount my tire. If that isn't enough, then I will get a longer chain. Thanks for the great idea!
2014 KTM 350 XCF-W
Times are GMT -7.   It's 07:53 AM.
