Old 12-12-2012, 01:35 PM   #16
4PawsHacienda
4PawsHacienda's Avatar
Location: Climax NC or Fancy Gap VA (milemarker 199 BRP)
Oddometer: 551
work. Worth the cost - you decide. If you're going to replace a tire/tube may as well spend the couple of bucks on dyna beads, unless you'd rather buy a beer. Probably get better mileage out of the beer.
Looking to spend money on your Ural - try a better headlight.
I haven't needed any spare parts, yet. Thats' sure to change now though.
4PawsHacienda is offline   Reply With Quote
Old 12-12-2012, 03:36 PM   #17
tattoogunman OP
tattoogunman's Avatar
Oddometer: 583
Yep, you just opened yourself up the Ural Gremlins with that post
tattoogunman is offline   Reply With Quote
Old 12-13-2012, 09:45 AM   #18
RottVet
RottVet's Avatar
Oddometer: 322
I use dynabeads in my Gear Up, Seems to work as well or maybe even better than the factory spoke weights. I intend to keep using them too, sure easier than the traditional method of balancing, at least for me.
"If the going is getting easier, it is probably because you are going downhill"
RottVet is offline   Reply With Quote
Old 12-16-2012, 01:20 PM   #19
val. h.
On the wrong planet
val. h.'s Avatar
Oddometer: 123
They work
As I change my own tyres I find beads are a whole lot easier to fit than buying a balancing rig.
However! there are some things to consider. If you are reaming out the valve hole (as you have to on some tubes) make sure you don't drop the drill bit down the hole. Don't ask me how I know that. You mentioned they will come already installed in the tubes. So probably not a problem.
I tend not to use them in tubeless tyres though. Not for any other reason than I carry a tyre plugging kit. Dyna beads stick to the glue.
Val.
The land you visit may be a beautiful place with extraordinary views and heavenly skyes, but it's the people of the land that make it truly worthwhile returning time and time again.
Ay! and the roads need to be bloody good too
val. h. is offline   Reply With Quote
Times are GMT -7.   It's 03:20 PM.
