12-14-2012, 09:37 AM
#166 | |
Befuddled Adventurer
Oddometer: 257
"Remember, you may have to grow old, but you don't have to mature." - Red Green |
12-14-2012, 11:38 AM
#167 | |
On Any Sunday
Oddometer: 582
Skunk Works vs. LC Garage
"Nothing can stop us but fear and common sense” |
12-14-2012, 07:36 PM
#168 | |
Racing Like a Noob
Oddometer: 4,281
Racing a Subaru in the 2013 Mexican 1000 |
12-14-2012, 09:07 PM
#169 |
Sprocket
Oddometer: 508
The new sub-frame looks awesome. At this rate there is going to be about 3 original molecules of Honda left, but it's getting awesomer (not a real word, but entirely appropriate for this build) by the minute.
2003 F650gs, 2005 KTM 525exc, 2006 Santa Cruz VP-Free |
12-14-2012, 09:08 PM
#170 |
On Any Sunday
Oddometer: 582
12-14-2012, 10:09 PM
#171 |
Racing Like a Noob
Oddometer: 4,281
12-14-2012, 10:45 PM
#172 | |
GPoET&P
Oddometer: 3,760
Has your back forgotten the motor already? That's 3 very heavy molecules.
12-15-2012, 12:40 AM
#173 | |
Oddometer: 257
The Honda SOHC four, herniating spinal disks since 1969!
12-15-2012, 06:36 AM
#174 |
Navigator
Oddometer: 63
That's what titanium plates are for.
![]() Just kidding
Strassen? AHRMA # 59 |
12-15-2012, 01:17 PM
#175 |
motorcycle addict
Oddometer: 897
Not funny...
![]() I just had a Ti plate in my neck go bad and 2 broken Ti screws. I had to have it all replaced last week after it failed. Avoid that kind of mess at all costs. Almost cost me all ability to ride ever again and has cost me all dirt riding for 2.5 years so far and 6 more months ahead minimum.
it is easier to ask for forgiveness than permission |
12-17-2012, 10:48 PM
#176 |
GPoET&P
Oddometer: 3,760
I got some fancy new carburetors a couple of weeks ago, and of course the outlet on them doesn't match the inlet on the head. I could have bought adapters but they take up an extra inch of space that I'd rather use for the airbox. So it's time to do more lathing.
Start with some round stock that is just the right OD, so I only need to turn out the middle. The downside of this is that the parts are a little eccentric, just like the rest of the bike. ![]() The stock was supposed to be long enough to make 4 spacers and has a little extra for clamping. It turned out to be long enough for 5; the four I needed and one screwup. Start by drilling out the center so that a boring tool can go in. ![]() Then cut out the middle to the right diameter ![]() The spigots are 30.0mm OD, so this is a .1mm press fit. It felt about right. The final part I did was more like .15mm and it was a bit on the tight side. Cut the part off: ![]() Side note: using the parting tool this far from the chuck didn't work very well until I used the tailstock to secure the part. Present the parts for inspection: ![]() Press it on the spigot, with sealant: ![]() One done, three to go. ![]() As mentioned, I did screw one up. It would have been the last one but the cutting tool got dull and started chattering. By the time I figured out what was going on it had cut the part to 30.0mm which was a nice slip fit, but not a proper press. Finally, fitting one up to the carbs. ![]() ![]() All in all, a good warmup to the shock bushing spacers that need to be made. |
12-18-2012, 12:45 AM
#177 |
Oddometer: 257
Very nice; the spigots look great!
Dang...Keihin CR29s! ![]()
12-18-2012, 04:39 AM
#178 |
Booze Merchant
Oddometer: 548
Never mind the CB - what's the Dog working on when it's not busy training you?
![]() Lovely build mate.
CambodiaYeah! |
12-18-2012, 11:12 AM
#179 |
GPoET&P
Oddometer: 3,760
Nu uh. CR26s Originally I was going to get CR29s, but there were too many reports of them sucking. The common theme was that the carbs were too big for the 550 and would go way lean below 7k rpm. The fact that most people run them with pod filters doesn't help, but still..... Sudco recommends CR29s for the 550, and probably because they're the only US importer, everyone else recommends the same thing. Except for Keihin. You know, the company that actually makes the carbs. They recommend the 26s for mildly built 550. For a full-on race motor on a racetrack, they do recommend going one size larger to the 29s. For a totally stock 550 they recommend going one size smaller. Or would, if that size existed. But anyway, that agrees with what the sohcforumites were saying, so I bought a set of 26s. I do already have a set of CV carbs that one guy said worked well; good performace, terrible fuel economy. But, it seemed like a lot of potential screwing around to get them working right. I'd rather spend a week screwing around with jetting than a month. |
12-18-2012, 11:24 AM
#180 | |
GPoET&P
Oddometer: 3,760
Thanks! A couple of weeks ago he was working on a rotting deer carcass. Then sprayed it back all over the house and shop. So he's not allowed to roam any more. He used to ignore me, I'd have to crack a beer to get his attention. Now he answers to my voice. Good thing, because cold beer isn't so appealing in a 40* shop. |
