Old 12-17-2012, 12:40 PM   #4051
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 705
muffler sounds
I don't know. The sound at idle is OK but when the throttle is blipped, it sounds like someone's passing gas . I've had an 08 and a '10 GS and those mufflers sounded much better than this one.
Doc Reid
2013 GS LC Red (the fastest color )
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 12-17-2012, 04:17 PM   #4052
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,430
I think the difference is that we are hearing an engine that spins up a lot faster than the previous boxer motors. Also an unloaded engine is going to sound a lot different than when you are riding. Have you really stood behind your bike and had someone rev it to 6k or more and listened to it? I know I haven't. Also, it seems that this engine was probably cold, which could also impact its sound.
EJ_92606 screwed with this post 12-17-2012 at 05:14 PM Reason: added cold engine
EJ_92606 is online now   Reply With Quote
Old 12-17-2012, 05:37 PM   #4053
nzcvlh
nzcvlh's Avatar
Oddometer: 58
too much blue smoke on that start up. doesn't appear they totally fixed the oil consumption problem.
nzcvlh is offline   Reply With Quote
Old 12-17-2012, 06:30 PM   #4054
Montauk
Oddometer: 260
I think we are all quite excited about the bike and one little thing we hear, we start o dissect. Nothing wrong with that, I am glad that we are hashing everything, 'cause that keeps me entertained.
My take on these two issues - sound and smoke are that it's premature for any conclusion. I like the leaf blower sound at idle, not sure If I like the reving sound though. Of course recording devices make a big difference as someone already pointed out.
When riding you won't necessarily hear it with ear plugs, so it doesn't matter. But then again, there is Akropovic (sp) exhaust to fancy your needs.
Montauk is offline   Reply With Quote
Old 12-17-2012, 07:25 PM   #4055
Moronic
Moronic's Avatar
Oddometer: 1,138
Pretty hard to fix that on this engine design. Big variations in crankcase pressure (from the pistons' boxing), and a combustion chamber that is gravity-fed oil when the bike is on the sidestand.
The amazing thing is that they drink so little oil.
Sorting out the S4Rs Ohlins shock: click here.
Moronic is offline   Reply With Quote
Old 12-17-2012, 07:42 PM   #4056
Montauk
Oddometer: 260
It depends, but it could be my old designed bike.
On 2004 R1200C, when I stop the engine, I stay on it for about 30-60 seconds and then put it on the side stand, to allow oil to drain below instead into the left cylinder. This consumes less oil. Now if I put it on the side stand immediately after turning ignition off, it can consume about a quart for 3,000 miles. Furthermore, it also becomes little harder to start due to accumulation of oil in the cylinder.
Old 12-18-2012, 04:49 AM   #4057
mtbenson
Oddometer: 155
What problem? I've owned oilheads/hexheads since 1995 and have only added oil one time between changes.
2007 R1200GS
1975 R90/6
mtbenson is offline   Reply With Quote
Old 12-18-2012, 07:14 AM   #4058
kencc
Oddometer: 62
You must change it a lot
kencc is offline   Reply With Quote
Old 12-18-2012, 08:08 AM   #4059
mtbenson
Oddometer: 155
No, 3-5k.
2007 R1200GS
1975 R90/6
Old 12-18-2012, 10:57 AM   #4060
paladinwest
Been Around
paladinwest's Avatar
Oddometer: 140
I have a R1200GSA and an HP2 Sport, neither burns any measurable amount of oil. The HP2 was raced for half it's life (before I got it) and it shows no change in oil level in the 4-5000 kms that I put on it each year. The GSA is changed at 10,000 km intervals and it hasn't used oil since the first 8000. My K100RS goes 7500 kms between changes and the drop in oil level at the sight glass is also not measurable. Just don't park it on the side stand, especially after making a hard left turn. If you allow it to cool down a bit chances are you will see some serious blue smoke - along the lines of an old ringding two stroke from the 60's.
'08 HP2 Sport - 10,000+, '08 R1200 GSA - 68,000+, '90 R100GSPD - 100,000, '86 K100RS - 152,000
paladinwest screwed with this post 12-18-2012 at 02:05 PM
paladinwest is offline   Reply With Quote
Old 12-18-2012, 02:25 PM   #4061
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 13,984
Originally Posted by EJ_92606 View Post
Found a better picture of the intake....yes, definitely an injector as can be seen by the light blue color signifying gasoline.
That picture looks just like a space alien standing on a flying wasser-boxer, warding off all foes with palm-beam death rays.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 12-18-2012, 03:15 PM   #4062
PirateJohn
Radical centrist
PirateJohn's Avatar
Oddometer: 21,419
The death rays will be an option in the USA. Or so I hear.
PirateJohn --
http://www.PirateJohn.com
IBA #7552 - SS1K in 2000 and 50CC in 2002
In the Laredo, TX area and always willing to help travelers escaping into Mexico.
PirateJohn is offline   Reply With Quote
Old 12-18-2012, 03:20 PM   #4063
RetrogradE
RetrogradE's Avatar
Oddometer: 1,076
It looks like the inside of my balls.
. . .as far as my imagination is concerned. I've never actually looked inside my balls.
RetrogradE is offline   Reply With Quote
Old 12-18-2012, 03:23 PM   #4064
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,430
Pending DOT approval
Old 12-18-2012, 03:52 PM   #4065
Marki_GSA
Oddometer: 209
If your current boxer uses a lot of oil it either hasn't done at least 12000 miles or it was pampered too much when it was being ran in. Boxer engines that have been pampered too much will always burn oil and there is only one way to fix it. Get the bores honed and re-ring it then give it some while breaking it in.
Marki_GSA is offline   Reply With Quote
Times are GMT -7.   It's 09:25 PM.
