Old 12-19-2012, 07:44 AM   #6586
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,467
Originally Posted by Albie View Post
You don't have one of these in your toolbox?
Screw driver might work ok on the beefy shock collars but it will just deform and bind the stock 690 one resulting in you having to cut off the collar with a dremel. I know nothing about this from personal experience last summer.
Seth S
Seth S is offline   Reply With Quote
Old 12-19-2012, 08:25 AM   #6587
MrHix
MrHix's Avatar
Oddometer: 384
I bought a 3/8" diameter brass rod and cut a 10" piece off to use as a drift. I used it on my 2012 690 shock and it deformed the collar rings with no deformation to the rod. I'm getting a new aftermarket collar installed with my revalve.
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 12-19-2012, 09:37 AM   #6588
Biped
NooB Again
Biped's Avatar
Oddometer: 324
Unfortunatly with the OEM collar the best way is to remove the shock from the bike. I use a large channel lock plier to turn the collar rather than apply a shock load with a drift which will oval the OEM butter soft rings.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is online now   Reply With Quote
Old 12-19-2012, 11:00 AM   #6589
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,477
Originally Posted by 13x View Post
sweet! thanks!
Singapore, I could be wrong abt the MY12\13 thou. Arrived earlier this mth from KTM motherland. Any major changes between both years?
The 2012 & 2013 models are supposed to be the same as far as I know.
It's just that, here in the US, all the 2012 are gone so anyone wanting a new 690 is going to have to wait for the 2013s to show up, which is likely going to be around March/April 2013.
Yellow Pig is online now   Reply With Quote
Old 12-19-2012, 12:01 PM   #6590
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 957
I use 1 Motionpro C spanner and 1 BMW GS C spanner suitably ground down to adjust preload. That said, I can only reduce preload, the other direction is buggered
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 12-19-2012, 12:11 PM   #6591
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,908
Originally Posted by TheMuffinMan View Post
Anyone know the iridium plug part number for '12 + 690 E's? Is it the same or different than 08-11's?
This. Also the wiki is forming up nicely (link in my sig).
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 12-19-2012, 12:57 PM   #6592
Seth S
Seth S's Avatar
Oddometer: 4,467
Because my bike is an 08 there was no beefy collar replacement available. I believe I have one from a Suzuki 1000 on it now.
Seth S
Old 12-19-2012, 02:21 PM   #6593
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,419
It's what SMS used when they set my suspension up.
Albie is offline   Reply With Quote
Old 12-19-2012, 03:05 PM   #6594
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,671
Superplush makes one.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 12-19-2012, 03:35 PM   #6595
Seth S
Seth S's Avatar
Oddometer: 4,467
well good luck with that.
Seth S
Old 12-19-2012, 03:36 PM   #6596
Seth S
Seth S's Avatar
Oddometer: 4,467
is that a recent offering? Rally Raid UK makes them for the 09 and newer but the 08's have a different thread pitch.
Seth S
Old 12-19-2012, 03:57 PM   #6597
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,671
Fyi:
Superplush is now making stainless shock collars for the 690e. Even the '08.
I'm not sure if its on the website yet.
I posted this up a few months back.
Its not a different thread pitch.. different shock diameter I think.
You can get it here
Old 12-19-2012, 04:22 PM   #6598
Seth S
Seth S's Avatar
Oddometer: 4,467
You can get it here
Ok, maybe not different pitch...different though that the 09 and newer collars don't fit. I have not been around the forum too much lately. I will check it out. thanks for the link.
Seth S
Old 12-19-2012, 08:54 PM   #6599
13x
13x's Avatar
Oddometer: 48
sales person mentioned that no changes to both MY, even the decals are the same. hmmm
oh well no diff to me. I LOVE IT! =X
13x is offline   Reply With Quote
Old 12-19-2012, 09:19 PM   #6600
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,107
I've been looking into a merge preload adjuster , they are no longer made but maybe a group buy might influence
Them in a production run
http://www.cheapcycleparts.com/produ...raulic-preload
Mudguts is offline   Reply With Quote
Times are GMT -7.   It's 08:43 AM.
