Old 12-19-2012, 02:53 AM   #6556
tertsu
Oddometer: 16
Originally Posted by 690Emaf10 View Post
Were you able to find one? I have the #10 from that pic if that helps. It includes the 120mm hose and the quick disconnect. Item #75007016050
From MotionPro. There are different models available i.e. this one http://www.motionpro.com/motorcycle/...ect_couplings/
tertsu is offline   Reply With Quote
Old 12-19-2012, 05:19 AM   #6557
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
Originally Posted by toast View Post
Thanks for the replies, I have the parts on order and they are due in Thursday.
Happy Holidays my friends! Ride on!
If you don't already you will soon know that the oem clamps are one and done - they need to be cut off the hoses and new ones procured. This is a good chance to change out for more field service friendly version. I was unfamiliar with high pressure FI clamps but your standard hardware store hose clamp versions are less suitable for this task.
The two auto parts places close to my house didn't have properly sized replacements, ended up ordering from here.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 12-19-2012, 05:38 AM   #6558
giuspepp
Oddometer: 4
Originally Posted by Albie View Post
You don't have one of these in your toolbox?
I have already used a screwdriver with bad result,now i can't hit more the shock collar without ruin it completely and so, no one knows which tool works??U6910066 or U6951172?
giuspepp is offline   Reply With Quote
Old 12-19-2012, 06:19 AM   #6559
ktmmitch
Oddometer: 662
Originally Posted by giuspepp View Post
Hi guys!
Which of these tools should i buy to adjust the spring pre-load,U6910066 or U6951172?(bike 690enduro r)
U6910066: http://www.cyclehuttktm.com/ktm-part...tment=bigbikes
U6951172: http://www.cyclehuttktm.com/ktm-part...tment=bigbikes
and someone does know where i can find it in europe?
These are only for EXC,there is not enough room around the rear tank on a 690 to get 1 notch movement at a time with those C spanners.
We change the OEM(weak) lock rings for our stainless thicker locking ring,then it is possible,by using a jack-up stand to take the weight off the rear wheel,to turn the lock ring using an aluminium or brass bar.
Shock Collar
ktmmitch is online now   Reply With Quote
Old 12-19-2012, 06:44 AM   #6560
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,605
Screw driver might work ok on the beefy shock collars but it will just deform and bind the stock 690 one resulting in you having to cut off the collar with a dremel. I know nothing about this from personal experience last summer.
Seth S
Seth S is offline   Reply With Quote
Old 12-19-2012, 07:25 AM   #6561
MrHix
MrHix's Avatar
Oddometer: 384
I bought a 3/8" diameter brass rod and cut a 10" piece off to use as a drift. I used it on my 2012 690 shock and it deformed the collar rings with no deformation to the rod. I'm getting a new aftermarket collar installed with my revalve.
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 12-19-2012, 08:37 AM   #6562
Biped
NooB Again
Biped's Avatar
Oddometer: 339
Unfortunatly with the OEM collar the best way is to remove the shock from the bike. I use a large channel lock plier to turn the collar rather than apply a shock load with a drift which will oval the OEM butter soft rings.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 12-19-2012, 10:00 AM   #6563
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,551
Originally Posted by 13x View Post
sweet! thanks!
Singapore, I could be wrong abt the MY12\13 thou. Arrived earlier this mth from KTM motherland. Any major changes between both years?
The 2012 & 2013 models are supposed to be the same as far as I know.
It's just that, here in the US, all the 2012 are gone so anyone wanting a new 690 is going to have to wait for the 2013s to show up, which is likely going to be around March/April 2013.
Old 12-19-2012, 11:01 AM   #6564
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 973
I use 1 Motionpro C spanner and 1 BMW GS C spanner suitably ground down to adjust preload. That said, I can only reduce preload, the other direction is buggered
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 12-19-2012, 11:11 AM   #6565
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,102
Originally Posted by TheMuffinMan View Post
Anyone know the iridium plug part number for '12 + 690 E's? Is it the same or different than 08-11's?
This. Also the wiki is forming up nicely (link in my sig).
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 12-19-2012, 11:57 AM   #6566
Seth S
Seth S's Avatar
Oddometer: 4,605
Because my bike is an 08 there was no beefy collar replacement available. I believe I have one from a Suzuki 1000 on it now.
Seth S
Old 12-19-2012, 01:21 PM   #6567
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,690
It's what SMS used when they set my suspension up.
Old 12-19-2012, 02:05 PM   #6568
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Superplush makes one.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 12-19-2012, 02:35 PM   #6569
Seth S
Seth S's Avatar
Oddometer: 4,605
well good luck with that.
Seth S
Old 12-19-2012, 02:36 PM   #6570
Seth S
Seth S's Avatar
Oddometer: 4,605
is that a recent offering? Rally Raid UK makes them for the 09 and newer but the 08's have a different thread pitch.
Seth S
Times are GMT -7.   It's 11:47 PM.
