12-19-2012, 12:44 PM
#61 | |||
Oddometer: 372
Your first response to my post in this thread contained only straw man arguments and attempts to create an argument where there is none: Quote:
12-19-2012, 07:01 PM
#62 |
Dude Buddha
Oddometer: 576
You obviously are a sensitive individual with some very strong opinions, which you are welcome to. Good luck with that bowie knife fight, OK?
Oh, that bit about animals growing bigger the further they are from the equator? Look that one up, OK? |
12-19-2012, 08:07 PM
#63 |
Oddometer: 372
I called you out for your BS. Sorry you don't feel like saving face.
Here I go again: http://en.wikipedia.org/wiki/Bergmann%27s_rule |
12-19-2012, 09:16 PM
#64 |
Dude Buddha
Oddometer: 576
This started as such a civil thread with lots of good information. I hope other readers don't lose that fact in this little tiff.
This is not about saving face, it's about presenting factual information. If you do some research using current references related to bears, you'll find that what I've noted is not B.S. but based on case studies. I live in bear country; work in the wilderness; and have to keep current on bear behaviour (opinions on which changes with new and additional information), so keep up on this stuff. Yes, I understand your Wikipedia reference, and like lots of generalisms, it has it's uses. Like a lot of general statements, it also has limitations and modifications. The reference is similar to the argument for geodisic domes as maximum volume for minimum surface area, therefore they must be most energy efficient. Except that calculation is done without an insulation value, which changes the picture quite rapidly. Same thing - a general rule that is "true" but has to be thought about and put in context before thinking it applies to a specific instance. Unlike physics, the biological sciences are more variable, so Bergmann's Rule needs a big grain of salt - elephants and other large tropical land mammals, for instance, don't exactly fall into that rule, do they? Do some research, specifically in terms of bears, since that's what we're discussing. Check the range of weights for various populations in different geographic regions, such as southern U.S., mountain state U.S. central Canada, Yukon and coastal Alaska. You're not going to find a uniform size increase with latitude. Instead, you're going to find a better correlation with habitat, food source, climate, need to hibernate and some other factors. Why are coastal Alaskan bears so big? Salmon swim into their mouth without much effort on the part of the bear, and it's a mild climate, they eat for more months of the year. Same latitude, tougher climate, you'll find a considerably smaller bear. Like I said, I don't think you're stupid, but you are presenting half truths, angry personal arguments, generalist rules and the like, as fact. Luckily, nobody here has to rely on either of our opinions, they can do their own homework. Bears are generally not a big deal when camping, and that's been pointed out by many posters. |
12-20-2012, 09:07 AM
#65 | |
Oddometer: 372
Obviously there are exceptions to Bergman's Rule so it is not a "rule" in the traditional definition but it has been accepted by science none the less as a useful generalization with much more conformity than exception. I already know from reading many things that black bears here in CO are smaller on average than those in higher latitudes. A 300 pound black bear is considered big here. Not so much the case in Canada and Alaska. Is that difference directly attributable to the latitude difference itself? No (because the rule is about correlation not causation which no one said was uniform), but does it matter? No, my whole point about Bergman's Rule was that bears are less dangerous where they are smaller like most animals that are dangerous from their physical strength. And the end reality is that the further north you go, the bigger most animals get in general (like you pointed out, its not necessarily uniform, but the scientific generalization is still applicable nonetheless). That includes bears. Therefore the further north I go the more I worry about bears regardless of the species. They have bears running around Arizona...how big do you think they are (regardless of the reason for that)?To see a grizzly all I have to do is drive to Wyoming...but staying here in CO I don't have to worry about grizzlies or truly large black bears, at least at this time. |
12-20-2012, 11:00 AM
#66 | |
Oddometer: 2,200
07 SE PG007 "Up there where you eat moose-cock you must all be rockets scientists." |
12-20-2012, 12:19 PM
#67 |
Oddometer: 372
12-20-2012, 12:34 PM
#68 |
Dude Buddha
Oddometer: 576
For those who care, these are fascinating animals. As the Yukon Environment site notes, "most like man" in several ways, finding a place in myth and legend. When you see what they can do (the cabin photos) but typically don't, you realize that they're actually pretty mild mannered, and with the cautions many posters have noted, aren't a big issue when camping.
http://www.env.gov.yk.ca/animals-habitat/mammals.php click on black and grizzly bears, and whatever else strikes your fancy. If the Least Weasel was bigger, we'd live in fear, it has attitude! Also: http://www.arktofile.net/pages/bear_am.html and http://www.ursusinternational.org/en/factsblack.html and several others. Yukon male grizzly: 500 to 800 pounds. Coastal Alaskan grizzly sucking back salmon and lounging in the rain: up to twice that. Yukon black bear average male weight in spring is about 180 to 240 pounds, about 20%+ more in fall. In Yellowstone, about 260 pounds is an average male weight, in New York State, about 300 pounds, Great Smoky National Park, around 250. 600 pounds would be a record bear, although there have been exceptionally large bears recorded. A bear biologist told me that in coastal regions, after salmon, black bear is the #2 protein in a grizzly bear's diet. Hmmm. |
12-20-2012, 12:55 PM
#69 |
UDF Adventurer
Location: an alternate universe, much better than yours
Oddometer: 298
After reading this nonsense, I have made up my mind; I am rooting for the bears!
But to leave on a good note, here is an old joke: Two biology students are tagging bear cubs pulled from winter dens. They tranquilize the sow first and haul her out. One of the sows starts to wake up early and seeing them with her cub, jumps up with a roar and comes at them. Both fellas take off at a run through the bush but after a few metres, one turns to the other and says "this is silly, we both know we cannot outrun a charging bear!" And the other guy looks him in the eyes and says "No, but I can outrun you..............."
Honda ST1300, Ural Gear Up, Rokon Ranger and now an Argo, WTF is wrong with me? A Brit named Billy once said something silly; he so wrongly concluded that Ural deluded.
12-25-2012, 09:51 PM
#70 |
Oddometer: 26
Kind of hate to have my very first post on this forum something really dumb I did with a black bear. You will probably wonder why they have dropped the IQ requirement so greatly.
I live on a 1.5 acre property in the country. A few years ago I saw a black bear eyeing the beehives a friend keeps on one corner of our property - not hard to imagine what was going through its mind. An old single shot 12 guage was by the back door along with some light trap loads, used for dispatching magpies. I picked up the gun and a few shells and walked toward the bear. When I was about 30 yards away from the bear and it was facing away from me, I fired into its butt. Figured the noise and sting of the pellets would send it running. I was half lucky. It didn't run back at me, which it well could have. Instead it ran for the closest fir tree and started climbing. It finally dawns on me that this bear not only knows where there is an excellent food source (which will cost my friend hundreds of dollars when it tears apart the hives) but also a bear with one very bad experience with human beings. Rightly or wrongly, I decide this bear has to die. I have no shotgun slugs nor a high power rifle, so call a friend who does have a .300 magnum. The bear is still up the tree when he arrives. What follows should give pause to any of you planning to possibly kill a bear with a handgun. When he shot it in the heart/lung area, that bear climbed another 25 feet up the tree faster than any cat I've seen climb a tree before falling to the ground dead. What I WISH I had done was simply fire a shot or two in the air close to my back door. Not sure if that would have scared the bear off for good, The hives are still there, now surrounded by electric netting with solar power. No more bear problems. |
12-26-2012, 11:44 AM
#71 |
Dude Buddha
Oddometer: 576
Good story, they don't die easily, not comparable to a human.
Electric fencing generally works really well. I occasionally get a request for it from campers used to down south bear country. Not enough problems here to carry it. Bears are smart and persistent. I know an outfitter with some fly-in cabins, used to have bear break-ins every year. Put up an electric fence, no problems until the year a tree fell across the line. The bears must have just kept checking until it was OK again.... |
01-02-2013, 10:37 PM
#72 |
Oddometer: 24
Food
Ok here is a total noob question from someone with limited outdoor experience and very little bear experience. I am asking this specifically to those that stealth camp or camp in bear country. What do you do with your food and food debris and garbage? Like the pots and utensils with food don't they attract bears and if you wash them out, doesn't the puddle of food gunk and water attract the bears? I know this question is dumb but for someone who want to do more and more stealth camping and such I have not found an obvious solution to the cooking and food smell issue.
01-03-2013, 01:01 AM
#73 | |
Oddometer: 122
01-03-2013, 02:03 PM
#74 |
Oddometer: 24
Ok........
Ok, thank you for the response. I am talking more specifically about if you are traveling in an area where you can't leave trash, there is no where to dispose of it so you must take it with you. I have already ate early and then camped elsewhere but I am talking more specifically in the more remote areas where you must pack your empty cans, etc with you. Or does everyone just eat dried food and what not?
01-03-2013, 05:21 PM
#75 |
Oddometer: 122
I usually hang my food and heavily scented gear from a tree branch using paracord.
