Old 10-10-2012, 04:12 PM   #871
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,488
Originally Posted by zap2504 View Post
I took an empty gallon windshield washer fluid jug, cut off the bottom and part of the side (where the handle is) to form a sort of flexible old-time sugar scoop. Now I dump my hardware into the scoop, sort through it looking for what I need, then compress the ends of the scoop together to form a funnel for pouring the parts back into the storage container. Since it's free, I've made a couple others for friends.
I like that idea. I think I'll go home and make one of those.
Old 10-10-2012, 06:34 PM   #872
ride2little
MoveAlongNothingHere
ride2little's Avatar
Oddometer: 1,961
I just use an old tackle box and keep all of my misc fasteners, connectors, washers, nuts, bolts, heat shrink, terminal, etc, etc... Another positive about being a fisherman.
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
ride2little is online now   Reply With Quote
Old 10-12-2012, 07:02 AM   #873
Guy Young
Guy Young's Avatar
Oddometer: 8,492
This may be a 205, and apologies if it is.
Fella brought in a wheel off his Strom that one of the rear bearing completely came apart. Trick was to get the outer race of the hub. The bearing was completely separated and the outer race was sitting flush with the lip you see in the bore. Absolutely nothing to gain purchase on. All of the claw extractors I have were too thick to even begin to get a hold of the thing. Ground down a piece of steel, kinda tapped it down into the bore of the outer race, and tacked it into place. That gave me a nice surface to drive it out from the other side. Popped right out.
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/Garage-Project
Guy Young is offline   Reply With Quote
Old 10-12-2012, 07:51 AM   #874
gn77b
Oddometer: 147
antenna of broken radio + a bit of epoxy + a neodymium magnet I had laying around = a pick-up tool that costs 0. yeah, I know, the ready-made version costs next to nothing but making something for nothing gives me a lame feeling of accomplishment
gn77b is offline   Reply With Quote
Old 10-12-2012, 12:16 PM   #875
airborndad
airborndad's Avatar
Oddometer: 2,516
Originally Posted by AK Oldman View Post
My hands get extremely dry, particularly in low humidity climates, and the ends of my fingers and thumbs split open on me. I use super glue to hold the split closed. It works very well on minor cuts as well.
works for larger cuts too ask O.J. Simpson
airborndad is online now   Reply With Quote
Old 10-12-2012, 06:33 PM   #876
ibafran
villagidiot
Oddometer: 1,289
The bucket that I look thru most is lined with an old towel. I pick the parts containing towel out of the bucket by grabbing the 4 corners laying on top. Open the towel by laying it out on the workbench. Get whatever parts I need and pick up the towel of stuff by the 4 corners and drop it back in the bucket. The only guy that I know who has a better method bought an old roll cab at a garage sale and sorts his loose fasteners and stuff in the drawers. If he wants a metric machine screw, he opens the marked drawer. I bought one of those 40 bin plastic parts things on sale to keep the stuff that I want to find quickly but not often. Thus, my salvaged woodruff keys and little set screws are found in those drawers and not with the usual clutter in the towel lined bucket.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 10-14-2012, 07:04 AM   #877
richarddacat
abnormal character
richarddacat's Avatar
Oddometer: 3,430
I had bought me a new roll around tool box and wanted to line the drawers.
My wife had a new yoga pad she never used, it was almost enough to do all the drawers. About an 1/8" thick, kinda sticky so tools won't slide and a nice blue color.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is offline   Reply With Quote
Old 10-14-2012, 07:32 PM   #878
Rd650
Rd650's Avatar
Oddometer: 238
Good one on the strom wheel Guy. Simple and very effective.
Rd650 is offline   Reply With Quote
Old 12-19-2012, 06:31 AM   #879
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 2,720
One of the sucky-ist jobs when working on cases is cleaning off the old gaskets, that have welded themselves to the covers/cases.
Go buy a 6" sharpening stone (oil stone) take the case over to the sink or parts cleaner to keep the stone wet and sand away, it melts off the gasket, and flattens the sealing surfaces
PFFOG screwed with this post 12-19-2012 at 08:15 AM
PFFOG is offline   Reply With Quote
Old 12-19-2012, 06:44 AM   #880
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Oddometer: 2,720
The other welder trick is just weld a bead around the inside (in the ball channel) of the outer race, as it cools it shrinks the race and it will fall out
Old 12-19-2012, 10:25 AM   #881
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,524
When I worked at a gas station the mechanic would take a thermostat housing put some water on the concrete floor, rub the housing back and forth on the floor milling it to a flat clean finish.
scooteraug02 is offline   Reply With Quote
Old 12-21-2012, 08:58 AM   #882
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,152
Good thread
I just discovered this thread. I'm just on pg 7...maybe this has been mentioned already.
I like to keep large scraps of Blue Board (foam insulating board) and also cardboard handy. I use them to sit, kneel, or lay on while working on my vehicles & bikes. The blue board is waterproof, cushions, and keeps your butt warm, which is great if your working outside and/or on gravel or damp ground. It's also easy to wipe clean if you get it dirty.
I use the large cardboard scraps for the same purpose, but it's more disposable.
I'm also a big fan of rubber bands, large office binder clips, and magnets in the shop.
GlennR is offline   Reply With Quote
Old 12-21-2012, 10:12 AM   #883
nuggets
Fries with that?
nuggets's Avatar
Oddometer: 1,819
I like that one.
I like to keep a disposable tyvek coverall with my spare tire in the cage. I can throw it in if I need to do a roadside tire change and keep my clothes clean.
I also reccomend carrying a small square of housewrap in your bike's toolkit. That way you can spread it out and lay your tools and parts on it, instead of losing them in the dirt.
2001 400 EXC "Punkin" | 2005 Sherco 290 "Tree Climber" | OSET 16.0 | OSET 16.0 hard tail
nuggets is offline   Reply With Quote
Old 12-21-2012, 10:49 AM   #884
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,509
Housewrap? What the hell is 'housewrap'?
I had a small canvas bag of tools in one of my cars. There was also a piece of plastic sheeting, *Visqueen*, about 18’ – 20” square in there. Dump the tools on the on the plastic sheet & roll 'em all back up in the plastic sheet when done. Worked real good.
Maybe that’s what you’re talkin’ ‘bout.
Tom S is offline   Reply With Quote
Old 12-21-2012, 11:11 AM   #885
groundrules
groundrules's Avatar
Oddometer: 1,776
light weight, tough, flexible, water proof, chemical resistant, easy to come by (especially if you have access to some first class mail envelopes).
groundrules is offline   Reply With Quote
Times are GMT -7.   It's 06:17 PM.
