12-21-2012, 01:46 PM
#16 | |
Motorcyclist
Oddometer: 576
It seems that many riders approach cold weather riding by layering up and then, when that's still not enough, they add the heated gear. I think that approach is backwards. I put on my summer riding gear. If it's too cold for that, then the next thing I add is my heated liner(s). If it's still too cold, with the heated gear at max, THEN I think about adding long johns and/or fleece or whatever. I hate feeling like a stuffed sausage casing when I'm riding.
- Stu '09 R12GS, '05 GSX-R1000 (x3), '05 KTM 525EXC (plated) Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member Racer, Drummer, Bassist, Software Engineer |
12-23-2012, 08:47 PM
#17 |
Oddometer: 11
I have the 65W jacket liner and gloves running off the same controller - which isn't the best setup. The gloves run really hot when I crank up the controller enough to make the jacket warm enough. Next time I'll go for the 90w jacket liner.
I recently added a pants liner and socks and another single controller. I also now have a built in controller on the 'strom. So any ideas on what is the best way to set things up when using all four items? (keeping an eye on the voltmeter of course...) |
12-24-2012, 02:28 PM
#18 | |
Oddometer: 426
-dman |
12-25-2012, 08:32 AM
#19 | |
KK
Oddometer: 554
You can run the jacket on your TU, I run all of my stuff on mine. I have this power point on the handle bars. ![]() and bought this handy plug in volt meter at wally world ![]() I mount the volt meter on my tank bag ![]() the voltage drops when the gear cycles on but I can ride in stop and go traffic and it still does alright. I always shut the heated gear off about a mile from my stop so the battery is fully charged.
Raymond |
12-25-2012, 10:58 PM
#20 |
Motorcyclist
Oddometer: 576
My philosophy is, if my heated gear fails, I'll find the nearest Walmart or equivalent and buy some sweats, etc, to get me home. If I'm going to be riding where I'll be too far from civilization (and I use that term loosely when I'm using it to mean "someplace with a Walmart") to risk having no heat, then I'll pack along the long johns and fleece, just in case.
12-26-2012, 04:42 PM
#21 |
Scary Jerry
Oddometer: 2,206
I have the CycleGear heated jacket and gloves.
The jacket only has to run on bottom 2 of 5 settings to be toasty. The gloves are a little bulky, but they may break in some. Best investment I've made in riding gear. http://www.cyclegear.com/eng/landingpages/hotwired.cfm
X the DY.
12-29-2012, 08:56 PM
#22 |
Oddometer: 273
I finally got around to doing my little watt load test on my jacket and 'troller. First I have the transportable 1 zone heatroller and the FG 90W jacket. I removed the ring terminals and soldered on a set of "stackable" banana jacks. I can put them in line and run my GPS and jacket. That probably voided some warranty, but works for me and my multi bike portability. I hooked it up to a watt meter and a 30A power supply @ 13.8v.
I first turned on the controller and the meter read 91W and 6.8A. After a couple of minutes it dropped to 88W and 6.5A. After it was warmed up, I turned the knob down to half. Then it could be seen cycling on and off in about 1 second intervals. I didn't know if it would draw half the current all the time, or full current in short cycles, which is what it does. I then took it out to the 'Strom, and tried it out. It plugged in and worked as expected. Unfortunately, it was late, and I had no place to go, so I still haven't had a chance to try it on an actual ride. Maybe tomorrow, if things go right. Ryan
07 DL650, blue 07 DRZ400, also blue 11 TU250X, not blue former rides: 98 KLR650, 01 SV650 (another blue bike),89 KLR650, 92 Bandit 400 ( For Sale) |
12-30-2012, 04:24 AM
#23 |
Oddometer: 159
[QUOTE=rycomm;20355085]I finally got around to doing my little watt load test on my jacket and 'troller. First I have the transportable 1 zone heatroller and the FG 90W jacket. I removed the ring terminals and soldered on a set of "stackable" banana jacks. I can put them in line and run my GPS and jacket. That probably voided some warranty, but works for me and my multi bike portability. I hooked it up to a watt meter and a 30A power supply @ 13.8v.
I first turned on the controller and the meter read 91W and 6.8A. After a couple of minutes it dropped to 88W and 6.5A. After it was warmed up, I turned the knob down to half. Then it could be seen cycling on and off in about 1 second intervals. I didn't know if it would draw half the current all the time, or full current in short cycles, which is what it does. I then took it out to the 'Strom, and tried it out. It plugged in and worked as expected. Unfortunately, it was late, and I had no place to go, so I still haven't had a chance to try it on an actual ride. Maybe tomorrow, if things go right. Ryan[/QUO TE] You really have to do that test while riding, I notice a big increase in wattage (voltmeter drops) when the wind is blowing hard and when I get on the highway. But the modern PWM controllers do a good job of keeping the current draw to a minimum. My 200 watt Stator does OK in supplying enough juice for my jacket and gloves. Ron W.
DRZ 400SM DL-650 Gone but not forgotten |
12-30-2012, 05:58 AM
#24 |
Oddometer: 369
I have a 90w jacket on the same circuit as my gloves, the socks and pants are on the other circuit. If I turn the controler up enough for my hands to be warm than the jacket is way to hot for me. Pants and socks together are fine. It was sugested that I get a second controler but I'm not ready for that yet. I think I should have gotten the 65w jacket. Just my 2 cents.
2007 R1200GS almost farkeled to perfection! |
