Old 12-12-2012, 06:49 AM   #16
jgrady1982 OP
jgrady1982's Avatar
Oddometer: 781
I thought about that, but I wanted something that I could move this mill around in my garage with. If I needed to clean out around the machine to pull it out of the garage to get at something behind the mill, or where ever, I wanted it to be mobile.
The cherry picker would have been easier and cheaper, but I thought that this was cool and plus, to me at least, a mobile base makes a vertical mill much more valuable if I ever go to sell it. Who knows I may be wrong, but I would be more tempted to buy one of these if it is on wheels as opposed to not on wheels.
jgrady1982 is offline   Reply With Quote
Old 12-13-2012, 06:37 AM   #17
LexLeroy
Aging Gracelessly
LexLeroy's Avatar
Oddometer: 1,962
Great idea and nice work. I friend did the same thing years ago when he was starting his own mold shop. Everything was in his garage, on dollies, and two rows of 220 v. 3 phase busway were suspended from the ceiling. Worked out OK until he was able to afford commercial property.
Thanks for the inspiration - I've got the same problem.
"That's MISTER Crash to you, sonny...."
LexLeroy is offline   Reply With Quote
Old 12-13-2012, 04:31 PM   #18
groundrules
groundrules's Avatar
Oddometer: 1,661
so how much weight do you have to put on the leveling screws? seems like everything is real beefy except where the nuts are welded on. Do the casters still hold the weight when it's set in a working position?
groundrules is offline   Reply With Quote
Old 12-13-2012, 07:39 PM   #19
P B G
Oddometer: 10,001
The engine crane/pickers aren't great for mills, I tried that with mine, I had to assemble the legs to the crane around my mill, then the hook when set on the boom length appropriate for the weight of my mill meant that the ankle of the arm going to the lift eye was so sharp when the arm was high enough to clear the mill, that the arm was going to swing my mill, so I had to use the longer 1 ton hole, which was sketchy in terms of load capacity.
Then once you lift its hard to push with out the mill swinging, so I had to ratchet strap the mill to the body with a block of wood to keep the knee from banging.
Ultimately I just fork lifted it.
Old 12-22-2012, 01:19 AM   #20
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,938
I have a 2T picker with extendable legs, it's a little beefier than normal. I bought a 60's Kondia that is about 2ton, so I had to pick off the upper ram to move it. The smaller bridgeports run only about 1600 lbs, so it should work looking at it from my armchair.
I also picked a early 60's MKL lathe that was easily 2T. I had to jack it up and then push it a foot before it blead down, still did the job.
Nice job on the base though. Looks tough.
"Son, you can't do both"
Old 01-11-2014, 06:48 PM   #21
dblacknj
Master of the Obvious
dblacknj's Avatar
Oddometer: 290
Originally Posted by sailah View Post
I think we should have a contest....
This was pre new bike too
I give, what is the black bike on the left ?
Beware 10-289
dblacknj is offline   Reply With Quote
Old 01-12-2014, 07:26 AM   #22
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,553
2004/2001 Yamaha fz1 modified slightly.
Btw my garage is much cleaner now. Still can barely walk around.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 09-08-2014, 10:41 AM   #23
Daryl_Stamp
Daryl_Stamp's Avatar
Oddometer: 785
That mobile base is nice, made one almost 20 years ago to move a B-port from one end of a garage to another so I could load it on a truck to move it three blocks. Then my wife said, 'why don't we just push it the three blocks to our house?'
So we did, three stop signs, 1 set of railroad tracks and one 4-lane street later it was entering my drive-way; :) :) :)
Used the same setup 3 or 4 years ago with a CNC knee mill (no pics of that) and this past spring to move a nice Harrison M300.
Going onto the trailer
The nice retired German machinist I bought it from and his family and me
Coming off the trailer
Now all 3 are in my basement; small spaces can be advantageous for the sake of making you stay organized and limiting your collection to things being used now vs things being saved for 'someday' (but I am still working on that part)
Nice work on those mobile bases, you'll probably never regret making them. And two thumbs up on painting them; paint always makes thing like that look professional.
Sent from my iPad using Tapatalk
Live while you're alive.
Daryl_Stamp is offline   Reply With Quote
Old 09-08-2014, 02:12 PM   #24
groundrules
Oddometer: 1,661
Originally Posted by Daryl_Stamp View Post
T
hold on now. either you've got a walk out basement, or the rest of these trailer photos and stuff are just the tip of the iceberg.
Old 09-08-2014, 02:17 PM   #25
jgrady1982 OP
jgrady1982's Avatar
Oddometer: 781
yeah!
Got any pics of that????
Old 09-08-2014, 02:35 PM   #26
Daryl_Stamp
Oddometer: 785
Std house door to 5' of straight hall, down 4 steps, low overhang above steps. Will shoot some pics when I get home :) :) :)
Old 09-08-2014, 04:57 PM   #27
Daryl_Stamp
Oddometer: 785
Basement entrance pics;
Made the hoist support on the first move, but it was all free standing and a pita, when the lathe went in I bolted it to the floor. Lathe was most challenging, as there was no convenient means to dis-assemble.
Old 09-08-2014, 08:09 PM   #28
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,670
That hauling and rigging deal can be a real chore in itself. Makes getting creative quite the challenge sometimes.
As a nOOb I dropped/tipped over a lathe once. Boss wasn't very happy.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 09-09-2014, 04:36 AM   #29
rarepartbuilder
rarepartbuilder's Avatar
Oddometer: 344
you may be interested in this to complement moving machinery especially if you want to save prime floor spacein a small shop.. for fabrication etc.. its a 3 phase plug with a strain relief... verrry effective for use on things especially a cut off saw... even without unplugging the saw i can move it 8 feet in any direction from where the plug hangs from the ceiling...
20140909_072627 by freewillieklr, on Flickr
feeding this thing with hospital bed casters at $5.00 a pop
20140909_072716 by freewillieklr, on Flickr
best of luck with your shop
Bill
RPB
Reaching for far less side stand rocks.... the PISTON MOD
rarepartbuilder is offline   Reply With Quote
Times are GMT -7.   It's 08:24 AM.
