Old 12-21-2012, 11:21 AM   #886
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 2,757
The best thing I did in my old garage was paint the walls in high gloss pure white exterior paint. Easy to wipe down, and it sure brightens things up.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 12-21-2012, 03:30 PM   #887
richarddacat
breaking wind
richarddacat's Avatar
Oddometer: 2,579
+1 on the house OR roof wrap. Use it for about everything that I use to use cardboard for.
* 05FJR/74R90s *
If we concentrated on the really important stuff in life, there'd be a shortage of motorcycles.
richarddacat is offline   Reply With Quote
Old 12-22-2012, 04:34 AM   #888
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 3,515
Housewrap
Originally Posted by groundrules View Post
light weight, tough, flexible, water proof, chemical resistant, .....
Well! I guess I’ll have to look into getting a chunk or two of that stuff. Probably could pick up some scraps being thrown away where there is some house construction going on.
Tom S is offline   Reply With Quote
Old 12-22-2012, 06:39 AM   #889
rdwalker
Oddometer: 2,440
Originally Posted by AK Oldman View Post
My hands get extremely dry, particularly in low humidity climates, and the ends of my fingers and thumbs split open on me. I use super glue to hold the split closed. It works very well on minor cuts as well.
Good idea.
I used to work outside; winter was very painful: in the cold, my finger tips would split open, too. It was quite painful to tighten wire nuts.
The wounds were very wide and glue might not have helped. My trick for such conditions was to tape finger tips with the white medical tape ("waterproof tape"). This would last most of the day, even with a lot of pressure applied to the fingers.
rdwalker is offline   Reply With Quote
Old 12-22-2012, 07:28 AM   #890
duck
PsyKotic Waterfowl
duck's Avatar
Oddometer: 9,968
Tyvek also works pretty well as a footprint for your tent.
93 K1100LT, 94 K1100RS, 86-97 K75F (K75/100/1100 Frankenbrick), 91 K1, 05 KTM 450 SMR
IBA #17739 (SS1K, BBG, 50CC)
http://home.comcast.net/~smithduck/BMW_Tours.htm
duck is offline   Reply With Quote
Old 12-22-2012, 10:14 AM   #891
groundrules
groundrules's Avatar
Oddometer: 874
Originally Posted by duck View Post
tyvek also works pretty well as a footprint for your tent.
+1
groundrules is offline   Reply With Quote
Old 12-22-2012, 11:50 AM   #892
tommu56
tommu56's Avatar
Oddometer: 784
And if you wash it in a washing machine it is more pliable and still waterproof but air dry it no dryer!!!!!!!
tommu56 is online now   Reply With Quote
Old 12-22-2012, 12:10 PM   #893
mark1150
mark1150's Avatar
Oddometer: 123
Originally Posted by rdwalker View Post
Good idea.
I work outside and I too suffer(ed) with split finger tips.
Now as soon as I feel the first onsets I use lip balm during the day, covered with insulation tape.
The balm works like magic moisturising and keeping the area soft and flexible therefore non dried out and split.
At night (at home ) a couple of applications of germaline (I don't know if the guys around the rest of the world have this, it smells of root beer) or similar medicated products keeps them nice.
mark1150 is offline   Reply With Quote
Old 12-22-2012, 12:46 PM   #894
ttpete
Rectum Non Bustibus
Oddometer: 3,525
Get a tube of anhydrous lanolin and try it. It's the active ingredient in a lot of the balms made for cracked fingers and hands. A little goes a long way.
09 Kaw Versys
"The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher
ttpete is online now   Reply With Quote
Old 12-22-2012, 04:27 PM   #895
mark1150
mark1150's Avatar
Oddometer: 123
Thanks mate,
I'll give it a go.
Old 12-22-2012, 05:06 PM   #896
richarddacat
breaking wind
Oddometer: 2,579
something else to try for dry hands.
soak your hands with your favorite lotion, Neutrogena is what I like. Do this before going to bed but wear a pair of gloves like brown jersey gloves.
I also do this when working on the vehicles but I wear nitrile gloves instead.
* 05FJR/74R90s *
Old 12-24-2012, 01:57 PM   #897
FMFDOC
Oddometer: 162
Cracked skin?
http://bagbalm.com/
http://www.viewpoints.com/Pfizer-Cor...Lotion-reviews
These are the two best things to keep around for cuts, scratches, dry skin, etc.
Illegitimi non carborundum!
Tell someone you love them today, because life is short...but shout it at them in German because life is also terrifying and confusing.
So much adventure, you can hear the theme from National Geographic playing in the background...
ANY WAY YOU CAN! http://youtu.be/Gg_G-NeSmW0
FMFDOC is offline   Reply With Quote
Old 12-25-2012, 07:58 AM   #898
stevemd
stevemd's Avatar
Oddometer: 81
Valve Adjustment Trick on Engines with Pushrods
I learned this working in the Guzzi shop back in the late '70's. After adjusting a valve, leave the feeler gauge in and twirl the pushrod with your fingers. You may find a tight spot where you can only pull the feeler gauge out with difficulty if at all. This is where you re-adjust the valve.
As an old timer said, a little valve noise is better than no noise.
stevemd screwed with this post 12-27-2012 at 06:38 AM Reason: Edit
stevemd is offline   Reply With Quote
Old 12-31-2012, 06:55 AM   #899
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,309
Good one! Thanks.
Here also some sage advice I learned from another Inmate. To get the feel of the clearance you wish to set during a valve adjustment, set a micrometer at the thickness of the feeler gage you are using. The gage should slide through the valve clearance with the same resistance as the gage through the pre-set mic.
Oh yeah, when a Guzzi is running well, it makes too much valve noise to hear the valve noise.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM,
fritzcoinc is online now   Reply With Quote
Old 12-31-2012, 07:30 AM   #900
fbj913
fbj913's Avatar
Oddometer: 1,842
Originally Posted by FMFDOC View Post
http://bagbalm.com/
also good if you have a dog you hunt a bunch. use the bag balm on their paw pads for cracks or cuts.
Ride 365 LLC
Braaaap!
fbj913 is online now   Reply With Quote
Times are GMT -7.   It's 07:46 AM.
