Old 12-21-2012, 12:21 PM   #886
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,394
The best thing I did in my old garage was paint the walls in high gloss pure white exterior paint. Easy to wipe down, and it sure brightens things up.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 12-21-2012, 04:30 PM   #887
richarddacat
helmet full of Blues
richarddacat's Avatar
Oddometer: 3,306
+1 on the house OR roof wrap. Use it for about everything that I use to use cardboard for.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is offline   Reply With Quote
Old 12-22-2012, 05:34 AM   #888
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,402
Housewrap
Originally Posted by groundrules View Post
light weight, tough, flexible, water proof, chemical resistant, .....
Well! I guess I’ll have to look into getting a chunk or two of that stuff. Probably could pick up some scraps being thrown away where there is some house construction going on.
Tom S is offline   Reply With Quote
Old 12-22-2012, 07:39 AM   #889
rdwalker
Oddometer: 2,538
Originally Posted by AK Oldman View Post
My hands get extremely dry, particularly in low humidity climates, and the ends of my fingers and thumbs split open on me. I use super glue to hold the split closed. It works very well on minor cuts as well.
Good idea.
I used to work outside; winter was very painful: in the cold, my finger tips would split open, too. It was quite painful to tighten wire nuts.
The wounds were very wide and glue might not have helped. My trick for such conditions was to tape finger tips with the white medical tape ("waterproof tape"). This would last most of the day, even with a lot of pressure applied to the fingers.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is offline   Reply With Quote
Old 12-22-2012, 08:28 AM   #890
duck
duck's Avatar
Oddometer: 10,403
Tyvek also works pretty well as a footprint for your tent.
duck is offline   Reply With Quote
Old 12-22-2012, 11:14 AM   #891
groundrules
groundrules's Avatar
Oddometer: 1,654
Originally Posted by duck View Post
tyvek also works pretty well as a footprint for your tent.
+1
groundrules is offline   Reply With Quote
Old 12-22-2012, 12:50 PM   #892
tommu56
tommu56's Avatar
Oddometer: 1,328
And if you wash it in a washing machine it is more pliable and still waterproof but air dry it no dryer!!!!!!!
tommu56 is offline   Reply With Quote
Old 12-22-2012, 01:10 PM   #893
mark1150
mark1150's Avatar
Oddometer: 187
Originally Posted by rdwalker View Post
Good idea.
I work outside and I too suffer(ed) with split finger tips.
Now as soon as I feel the first onsets I use lip balm during the day, covered with insulation tape.
The balm works like magic moisturising and keeping the area soft and flexible therefore non dried out and split.
At night (at home ) a couple of applications of germaline (I don't know if the guys around the rest of the world have this, it smells of root beer) or similar medicated products keeps them nice.
mark1150 is offline   Reply With Quote
Old 12-22-2012, 01:46 PM   #894
ttpete
Rectum Non Bustibus
Oddometer: 5,749
Get a tube of anhydrous lanolin and try it. It's the active ingredient in a lot of the balms made for cracked fingers and hands. A little goes a long way.
15 BMW RnineT
09 Kaw Versys
Old 12-22-2012, 05:27 PM   #895
mark1150
mark1150's Avatar
Oddometer: 187
Thanks mate,
I'll give it a go.
Old 12-22-2012, 06:06 PM   #896
richarddacat
Oddometer: 3,306
something else to try for dry hands.
soak your hands with your favorite lotion, Neutrogena is what I like. Do this before going to bed but wear a pair of gloves like brown jersey gloves.
I also do this when working on the vehicles but I wear nitrile gloves instead.
Mid-TN Tag Riders
Old 12-24-2012, 02:57 PM   #897
FMFDOC
Oddometer: 438
Cracked skin?
http://bagbalm.com/
http://www.viewpoints.com/Pfizer-Cor...Lotion-reviews
These are the two best things to keep around for cuts, scratches, dry skin, etc.
Illegitimi non carborundum!
Tell someone you love them today, because life is short...but shout it at them in German because life is also terrifying and confusing.
So much adventure, you can hear the theme from National Geographic playing in the background...
ANY WAY YOU CAN! http://youtu.be/Gg_G-NeSmW0
FMFDOC is online now   Reply With Quote
Old 12-25-2012, 08:58 AM   #898
stevemd
stevemd's Avatar
Oddometer: 81
Valve Adjustment Trick on Engines with Pushrods
I learned this working in the Guzzi shop back in the late '70's. After adjusting a valve, leave the feeler gauge in and twirl the pushrod with your fingers. You may find a tight spot where you can only pull the feeler gauge out with difficulty if at all. This is where you re-adjust the valve.
As an old timer said, a little valve noise is better than no noise.
stevemd screwed with this post 12-27-2012 at 07:38 AM Reason: Edit
stevemd is offline   Reply With Quote
Old 12-31-2012, 07:55 AM   #899
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,809
Good one! Thanks.
Here also some sage advice I learned from another Inmate. To get the feel of the clearance you wish to set during a valve adjustment, set a micrometer at the thickness of the feeler gage you are using. The gage should slide through the valve clearance with the same resistance as the gage through the pre-set mic.
Oh yeah, when a Guzzi is running well, it makes too much valve noise to hear the valve noise.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 12-31-2012, 08:30 AM   #900
fbj913
I ride
fbj913's Avatar
Oddometer: 2,353
Originally Posted by FMFDOC View Post
http://bagbalm.com/
also good if you have a dog you hunt a bunch. use the bag balm on their paw pads for cracks or cuts.
fbj913 is offline   Reply With Quote
Times are GMT -7.   It's 04:10 AM.
