Old 12-10-2012, 11:42 AM   #376
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 869
Originally Posted by r2wtrials View Post
As i can just about move my knee again i have started to get the SWM ready for winter hibernation... this includes fitting a tubeless rear rim. I hate tubes, and after many many years of riding modern bikes and being able to slam the back wheel into things i can't break the habit and tubes aren't lasting long!!
I am lucky enough to have a free supply of tubeless Michelin X-Lights so a 36 hole tubeless rim from an Aprilia Climber was obtained and is now being laced on.
Once the knee is back up to strength and the worst of the winter is over i will still have a bike to play on :)
Good to here that your knee is getting better.
BTW. if you haven't tried yet, the tubless X-Lights holds on the standard Acront rims pretty well, (with an additional tube), even in very rocky terrain and low air pressure, (the pic shows the "autobahn" part during the trip).
PSchrauber is offline   Reply With Quote
Old 12-10-2012, 06:37 PM   #377
Ymirtrials
Ymirtrials's Avatar
Oddometer: 49
What do you mean with an additional tube? Do you wrap another tube around the other? So far I have not been able to keep a tubeless type tire beaded all the way around the akron rim on my Bultaco.
Jay
2010 Montesa 4RT, 1972 Bultaco Sherpa T 250, 00' Kawasaki Super Sherpa 250 (Wife's)
Ymirtrials is offline   Reply With Quote
Old 12-11-2012, 04:31 AM   #378
PSchrauber
PSchrauber's Avatar
Oddometer: 869
The innertube, (in German: Schlauch), that you have to use for tube tires.
So I use the tubeless tire with a tube. The inner tube holds the tublesstire very good in place even with low air pressure. You still loose a lot of weight and gain flexibility compared to a standard tube tire (with tube).
Old 12-11-2012, 05:14 PM   #379
Ymirtrials
Ymirtrials's Avatar
Oddometer: 49
I have tried two different michelin tubeless tires with tubes on the Bultaco and I could not get either to stay up on the bead all the way around the rim once I drop the pressure down. Is there a trick I'm missing?
Jay
Old 12-11-2012, 07:40 PM   #380
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,591
Did you clean the rim spotlessly? I use a wire brush followed by rubber cleaner (the stuff you to prep a tire carcass for a patch),
Beaten paths are for beaten men.
lamotovita is offline   Reply With Quote
Old 12-12-2012, 01:32 AM   #381
PSchrauber
PSchrauber's Avatar
Oddometer: 869
Yes cleaning up the innerside of the rims is necessary.
I also ride the bikes an hour or so with about 1 bar pressure, this helps the tire to set properly (all kind of tires),
I have the same "outfit" mounted to the Bultaco the bike has too Acront / Llanta red label rims (old TR Type) like the SWM mounted.
The tubeless tires will not stay on original Yamaha TY twinshock rims if you have mounted them to your bike,
the bead of the rim is different in shape, (there are no hump's inside the rim).
Old 12-12-2012, 08:17 AM   #382
r2wtrials
Oddometer: 136
Have you guys tried the tubliss system... several around here say they are very good. Use on a standard rim but makes it tubeless so you can run at lower pressures and use the modern tyres.
http://tubliss.com
r2wtrials.co.uk
r2wtrials is offline   Reply With Quote
Old 12-12-2012, 12:11 PM   #383
Will Hesch
Oddometer: 41
I've got a T-Lock System http://www.t-lock.se/index.html for 18" and 21" tires for sale, $200 plus shipping here in the lower 48. Get rid of rimlocks and no more flats! will@centralcoastbassfishing.com
Will Hesch is offline   Reply With Quote
Old 12-12-2012, 12:17 PM   #384
PSchrauber
PSchrauber's Avatar
Oddometer: 869
Both system sounds very nice, but at least where I live sadly not allowed for classic competitions.
Our guidelines for classic specify that only tires with tubes are approved.
Old 12-23-2012, 07:29 PM   #385
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,591
New Old Ride
I just got this one. I want to set it up for competition. First things I think I need are lower foot pegs ( I see Sammy Miller and B and J Racing have them). Are there any others and can anyone comment on any of them?
Also shocks, I have NJB experts on my Bultaco and want something better than those. I'd like to hear some recommendations. Any recommendation as to what length shocks would also be appreciated.
Old 12-23-2012, 07:32 PM   #386
Brewtus
Buffoonery, Inc.
Brewtus's Avatar
Oddometer: 3,161
Looks huge. I'd go with a TY80 meself....
Seriously though, nice score. Have fun with it!!
Work hard. Play hard.
Team Dead End. The drinking team with a Trials problem.
2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ.
Brewtus is online now   Reply With Quote
Old 12-24-2012, 08:08 AM   #387
lineaway
Oddometer: 3,091
I can`t quite tell, it looks like the pegs are too forward. Yamaha and the dealers tried to make the ty more user friendly by changing the footpeg location.
lineaway is offline   Reply With Quote
Old 12-24-2012, 10:25 AM   #388
Old Geezer
Old Geezer's Avatar
Oddometer: 179
I agree on the footpegs, a set of MS pegs and some rockshocks would do wonders!
Old Geezer on a Old Weezer
76 TY175
Whitehawk 80
Old Geezer is offline   Reply With Quote
Old 12-24-2012, 02:28 PM   #389
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,591
What are "MS pegs"?
Old 12-24-2012, 04:28 PM   #390
Old Geezer
Old Geezer's Avatar
Oddometer: 179
What are "MS pegs"?
Sorry fat fingers should be SM pegs (Sammy Miller). My bad!
76 TY175
Whitehawk 80
Times are GMT -7.   It's 07:12 AM.
