Old 12-22-2012, 08:29 AM   #2956
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,633
Originally Posted by RoundOz View Post
I believe my eyes may be more sensitive than others to this but I find anything bright in my peripheral vision kills my night vision (I even cover the blue high beam indicator on long trips!). Understand this is just me...I haven't found too many who share this opinion. .
+1 here
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 12-23-2012, 08:16 AM   #2957
BigDogAdventures
Fart Letter
BigDogAdventures's Avatar
Oddometer: 4,965
LED Model 60's mounted to my Husqvarna Terra 650
I'm not dodging those deer in the dark anymore----stock headlight is OK-------I want more---don't we all !!!!
The finished Install------Awesome !!!
I mounted these to a 2013 Husqvarna TR650 Terra
Models 60's with the rotary dimmer.
I mounted them to the Cycra Pro-bend handguards. The higher you mount these the better you'll be able to see.
I've seen lot's of guy mount them down low to the fork tubes----I don't like that install.
As an added benefit the wiring is much easier.
Dimmer location -----this made easy access to the wiring.
Without a bunch of blah, blah, blah, blah about lumens and density of light rays and a bunch of other technical bull that
I am not smart enough to understand-------- let
me just say they make daylight out of dark. I've got this same setup on my KLR.
BigDog is a happy camper once again.
BigDog
2008 Yamaha WR250R---by far my main bike.
2006 KTM 450EXC
2014 KTM690 Enduro--we'll see how good it is after 70,000 miles.
2013 Husky 650 TR650 Terra
I'm good--but I ain't no Dingweeds
BigDogAdventures is offline   Reply With Quote
Old 12-25-2012, 06:22 AM   #2958
geotherm
geotherm's Avatar
Oddometer: 90
new light bar installed
Someone mentioned light bar plans in a similar thread recently so I thought I'd post. I just got Sanjoh's lights last week and can't wait to try them out. Man..those Model 60's look awesome!
I used scrap aluminum flat bar I had in the shop, but a 1/4" x 1-1/2" x 24" pc can be purchased for less than $10(ebay has plenty of stock or local hardware store). The rest of the hardware ran me a little over $8(M6 bolts/1/4" alum tube for standoffs/etc.). For those not used to working with aluminum, I used my cordless grinder to cut/shape and then bench top sander to finesse. My cousin has the same bike and just spent $100 on the 'GS' light bar from Turkey, but I like the character/sturdiness of this one.
geotherm screwed with this post 12-25-2012 at 06:35 AM
geotherm is offline   Reply With Quote
Old 12-25-2012, 09:26 PM   #2959
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,292
Nice work! One question: Why not use a single bar that is longer and mount the lights below it? The bar would be stronger, and simpler, and the lights would work the same.
BTW I have made a similar light bar for the 1100:
I'm going to make a bar for the R1200GS with a friend. I will post it here.
Jim
JimVonBaden is online now   Reply With Quote
Old 12-26-2012, 01:00 AM   #2960
WindSailor
WindSailor's Avatar
Oddometer: 666
Jim
Good. I've got a GSA and really don't want to mount the aux lights to the crash bars - and I'm thinking the higher the better. So I am all ears on how this is going to work and if it will be adaptable to the GSA.
In my case I've got an aluminum plate underneath the beak that already holds my HID ballasts and my radiator fan for hot and slow days - that space is pretty much already taken up; to the point that I'm doubtful that a light bar will work with what area I have left. But I'm game to see it for sure, and other ideas too.
WindSailor screwed with this post 12-26-2012 at 01:13 AM Reason: spelling - geeee...
WindSailor is offline   Reply With Quote
Old 12-26-2012, 05:51 AM   #2961
geotherm
geotherm's Avatar
Oddometer: 90
Jim - I'm still wet behind the ears with the gs. I originally thought I might need additional lights(spots/floods) down the road and would do an over/under scenario. I didn't want the over lights to be too close to the turn signals. That was before I found the ADVmonster Model 60s. They handle it all. This one is surprisingly sturdy, but I'm with you, the straight bar would probably be best way to go.
Jim
Old 12-26-2012, 09:32 AM   #2962
JimVonBaden
"Cool" Aid!
Oddometer: 52,292
On the GSA with the factory uppers there is no room for a bar. You can, however, attach them like I did some Kristas to a friend's GSA. Just use bar clamps and position them where you want right off the GSA upper bars. His has the stock fogs as well. I'll see if I can round up a photo or two.
Edit, here is what I have now.
Maybe better later.
Jim
JimVonBaden screwed with this post 12-26-2012 at 09:38 AM
Old 12-26-2012, 03:54 PM   #2963
WindSailor
WindSailor's Avatar
Oddometer: 666
I hit Google hard last night searching on mounting alternatives for aux lighting situations on the GSA.
One of the hits was from here, which is interesting; R1200GS/GSA Hi-Mount Light Brackets
I like how these are mounted high and forward; not exactly sold on this yet - but good for discussion and another example or idea.
Here's a picture:
Old 12-26-2012, 04:37 PM   #2964
JimVonBaden
"Cool" Aid!
Oddometer: 52,292
Here are a couple better GSA shots:
Jim
Old 12-26-2012, 04:53 PM   #2965
NoVa Rider
Oddometer: 2,849
And with thanks to JVB's most excellent install, some available light patterns:
HID low:
HID/OEM fogs:
HID/Kristas (low power):
HID/OEM fogs/Kristas (low power):
HID Low/High beams/OEM fogs/Kristas full blast:
NoVa Rider is offline   Reply With Quote
Old 12-26-2012, 05:52 PM   #2966
Hikertrash
Oddometer: 2,834
Here's a picture:
I really like those, but it appears they're no longer in business.
Hikertrash is offline   Reply With Quote
Old 12-26-2012, 06:25 PM   #2967
WindSailor
WindSailor's Avatar
Oddometer: 666
Yea... the previous links were no longer valid, but I PM'd the guy to see if he had a few left. I'll let you know if I get a response.
Here's the front:
This shouldn't be too hard to make - the only thing that worries me now is how to make them adjustable enough to be truly useful.
WindSailor screwed with this post 12-26-2012 at 10:16 PM
Old 12-26-2012, 08:10 PM   #2968
JimVonBaden
"Cool" Aid!
Oddometer: 52,292
Hey,
How is the wine fridge?
Jim
JimVonBaden screwed with this post 12-26-2012 at 09:07 PM
Old 12-26-2012, 11:43 PM   #2969
NoVa Rider
Oddometer: 2,849
Doing very well, I just need to wire it into the fuze block. . ..
Old 12-27-2012, 10:36 AM   #2970
WindSailor
WindSailor's Avatar
Oddometer: 666
That should make the "100 THREADS all GS/GSA owners should read." thread...
Top ten anyway...
Times are GMT -7.   It's 10:42 AM.
