Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 12-24-2012, 03:26 PM   #15211
Riot
Tiger Rider
Oddometer: 105
pretty much.
FWIW they will shut off if your battery level gets low, they have a voltage cut off inbuilt ... also they will appear to not work well if the battery is not in good order.
Riot is offline   Reply With Quote
Old 12-25-2012, 08:09 AM   #15212
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by Riot View Post
pretty much.
LOL not so sure about that, I managed to drain the battery enough that I had to charge it a couple of hours to get it going.
UtahFox is offline   Reply With Quote
Old 12-25-2012, 08:23 AM   #15213
ducnut
Oddometer: 3,320
pretty much.
They claim that (#6). Maybe, the voltage cutoff is too low for the Tiger or EFI bikes, in general.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 12-25-2012, 11:52 AM   #15214
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 903
Voltage cutoff on the 'premium' grip only. Flip a couple pages to the right and on the standard grip they don't make that claim.
XCRider803 is offline   Reply With Quote
Old 12-25-2012, 12:54 PM   #15215
ducnut
Oddometer: 3,320
Ahhh, got it. Good to know.
'96 Ducati 900SS
Old 12-25-2012, 07:11 PM   #15216
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 903
The real question is do they plug into the OEM plug, anyone?
James
Old 12-26-2012, 06:02 AM   #15217
Kawidad
Kawidad's Avatar
Oddometer: 4,903
James
No. But, you can buy an adapter from Eastern Beaver to make it plug n play.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is online now   Reply With Quote
Old 12-27-2012, 04:09 AM   #15218
motolocopat
When in doubt gas it!
motolocopat's Avatar
Oddometer: 519
What do you attribute the ability for that Harley to run those roads. Is it the low center of gravity, frontend geometry, something else? I can't give all the credit to the rider, as some bikes are easier to ride in some conditions than others.
Mostly a set of Brass Balls
I can guarantee you that any full sized Harley was a handfull on that road
Steaks Medium Rare, Red Wine, V-Twin Road-Bikes, 4-Stroke Dirbikes, V8 RWD Cars, American 4X4 Trucks...Endless Roads with Motoing Amigos
Un Moto Abrazo
Keep the Shiny Side Up
www.moto-loco.com
motolocopat is offline   Reply With Quote
Old 12-27-2012, 08:04 AM   #15219
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,807
pretty much.
You can wire them into the switched circuit on the OE plug under the tank for the Triumph grips. Then it's no problem but.....That's all well & good but how do you turn them on and off while you're riding?
3 black Tigers. 955i+800XC+800XC=113000 miles of fun.
blacktiger is online now   Reply With Quote
Old 12-27-2012, 09:09 AM   #15220
dirtconnector
erythematic nucha
dirtconnector's Avatar
Oddometer: 769
I reckon this is the link:
http://www.easternbeaver.com/Main/Bi...umph.html#thgk
Does anyone have this system in use?
I'm a low brow but I rock a little know how - Red Hot Chili Peppers
dirtconnector is offline   Reply With Quote
Old 12-27-2012, 01:20 PM   #15221
slobinski
Inept adventurer
Oddometer: 434
Yes, that's exactly the one I'm using on my Roadie, with a Heat-Troller wired into a pair of Hot Grips. Works perfectly.
slobinski is offline   Reply With Quote
Old 12-27-2012, 09:10 PM   #15222
mint julep
mint julep's Avatar
Oddometer: 186
yes, use it with Oxford heat grips, easy plug & play.
eastern beaver makes a great plug that fits oem triumph harness.
mint julep is offline   Reply With Quote
Old 12-28-2012, 04:58 AM   #15223
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,395
Yep. Flawless like all of Jims kits.
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 12-28-2012, 06:24 AM   #15224
IndyTiger800
Oddometer: 167
You can order the switch and sum- harness from Bike Bandit
http://www.bikebandit.com/2012-trium...4257#sch739346
IndyTiger800 is offline   Reply With Quote
Old 12-28-2012, 06:32 AM   #15225
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
All of the tiger info is so spread out now. I can't keep track of where to post... anyway,
A little sneak peak!!!
fbj913 is offline   Reply With Quote
Times are GMT -7.   It's 06:40 AM.
