12-26-2012, 10:16 AM
#16 |
Oddometer: 759
I know there are some who push "you have to have these grips" and such. B.S. The only thing you need Oxford wise is a pair of shoes to get laughed at when you wear them on your bike.
Don't overthink it. $30 bucks, maybe less, maybe more. Go to ebay motors and look for a grip kit that uses the elements under your existing grips....if you can get them off without cutting. Install the sticky back heaters, put grips back on. Pretty simple. Left will be a bit cooler than the right due to no plastic twist grip insulating the heater but, TADT (they all do that). To not have the left side cooler, you change the left bar by gluing a twist grip onto the bar, grip heater on the plastic, and then putting on two right side grips for each side. Gets a bit more expensive that way. For 10 to 15 minute duration commute, most people will find that you're good with just grip heaters unless it is just too cold for them....everyone is different though. Longer durations bring in other factors that are more individual and bike/environment dependent. As the last guy said, you can always double dip and add warmer gloves to make it easier to take a leak when you get to work.
R1200RT (R1100RT gone) KLR650 Don't be the guy who needs to pee on the fence to figure out that it's electrified. |
12-26-2012, 10:33 AM
#17 |
PsyKotic Waterfowl
Oddometer: 9,970
Symtec heated grips (the motorcycle version of them) have different heating elements for the throttle and clutch sides to accommodate the difference between the plastic throttle tube on the right and a metal handlebar on the left. To lessen the heat sink effect on the left you can wrap the handlebar with a layer or two of electrical tape before installing the heated grip element.
93 K1100LT, 94 K1100RS, 86-97 K75F (K75/100/1100 Frankenbrick), 91 K1, 05 KTM 450 SMR IBA #17739 (SS1K, BBG, 50CC) http://home.comcast.net/~smithduck/BMW_Tours.htm |
12-26-2012, 06:00 PM
#18 |
Oddometer: 3,320
I wouldn't want to own a bike without heated grips
If I wasn't here, I'd be somewhere else |
12-26-2012, 08:29 PM
#19 |
Blargh!
Heated grips are awesome. I love mine. Really takes the edge off the cold.
My second favorite solution to the cold is glove liners. Also handle bar guards if you dont have them. I've found that a lot of gloves use the same insulation, and it doesn't really help me much, probably due to bad circulation. I've yet to try heated gloves though.
ALL ADDERS ARE PUFFS! 2012 BMW R1200 GSA, 2009 Kawasaki Versys (sold), 2001 Yamaha XT225 (sold) PC Gamer? Support Star Citizen! Save PC Gaming and bring back Space Sims! Pledge today! Service guarantees citizenship. @ http://www.robertsspaceindustries.com Thanks. |
12-27-2012, 07:30 AM
#20 | |||
Oddometer: 6
duck posted these cortech gloves which look 95% the same as these bilt gloves that I tried on in a store and hated how stiff they felt. Quote:
12-27-2012, 12:00 PM
#21 |
Oddometer: 347
Grips and gloves
After riding a buddies bike with the Heated Grips and Lee Parks PCI gloves, I made them a top of my list for Christmas. Can't wait. The gloves have a conductive liner in them to help distribute the heat from the grip throughout your hand. My wonderful wife got me the HotGrips heated grips and I will be installing them using a Heat troller from Warm and Safe to control them. Should be really comfy.
President and Founder of Superhero Proving Grounds "Where dreams are made and egos are checked" |
12-29-2012, 08:12 PM
#22 |
Oddometer: 1,093
I have Symtec heaters on my VFR and KLR. They are inexpensive and easy to install under just about any standard grip. I have factory blasters on my Wing.
My Order of Preference for heat is: 1. Warmer gloves for short trips. I also use them with grip heaters. 2. Grip Heaters 3. Grip Heaters and Electric liners for frigid conditions ![]() I also keep wool liners in reserve. |
12-29-2012, 08:32 PM
#23 | ||
Disgruntled Student
Oddometer: 1,581
I ended up buying Gerbings T5 heated gloves and LOVE them! They're warmer than the Scarabs without them even plugged in, way less bulky, and they keep my hands warm no matter the temperature. With you living in Phoenix, these would probably be overkill for you if you don't travel farther north often. If you only stay around your area and only need them for your short commutes, my vote would be heated grips. |
12-29-2012, 08:34 PM
#24 |
Oddometer: 186
Hand Guards are great...
block the wind and rain.. it rains when cold sometimes right? Heated grips, there are many tutorials and maybe someone here would help you locally.. I have lee parks gloves with outlast, and man they are warm and do seem to pull the heat from the grips and distribute the heat.. will be out on the Husky Demo with no heated grips or handguards, acid test of the Lee Parks, high of 45, rolling out in 29 degree.. stay tuned..
919 NC |
12-29-2012, 08:45 PM
#25 |
Oddometer: 147
Here is another reason for HGs. When it rains your hands can get wet with regular gloves that would normally be OK. The heated grips will help warm up the hands and dry the gloves, making evaporative cooling less of an issue.
___________________ help end slavery. ride for freedom. www.2endslavery.org
JadeRider [ Biker chains breaking chains of modern day slavery ] -- John 1:4-5 | Luke 17:24 ___________ 2002 BMW R1150GS |
#26 |
Oddometer: 1,213
I used to have Gerbings gloves. For such a short commute, you would spend too much time just hooking up the damn gloves (at least in my experience), so I would be another vote for heated grips.
2003 Suzuki Bandit 1200S 2009 KLR650 |
12-30-2012, 06:03 AM
#27 |
Oddometer: 369
I use both and like it has been said, short trips above freezing grips are fine. Long rides beelow freezing definatly heated gloves or even both as the best gloves dont have heat on the palms.
2007 R1200GS almost farkeled to perfection! |
12-30-2012, 10:59 AM
#28 |
Oddometer: 1,547
as mentioned, gloves are too much trouble for a 15 min ride. you have a jacket with wiring inplace?
get some goretex gloves for <$100. grips are nice if you ride through a big drop in temps. for instance it is 60F here but ride up the mountains and it drops 20 deg. I see them as a good way to keep from freezing on short stints
Alan 2011 KTM RC8R 2012 BMW S1000RR 2000 Kawasaki ZRX1100 |
12-30-2012, 11:08 AM
#29 |
WeaponOfMassDestruction
Oddometer: 1,695
I've had both.
Heated grips rock! Sometimes just enough to take the chill away (not just your hands) when you duck into the shadows or hit a stretch at higher altitude.
Every day I break my previous record of consecutive days still alive. |
12-30-2012, 05:48 PM
#30 |
Oddometer: 186
Lee Parks with Outlast and no handguards or heated grips
started out at 28 degrees.. Lee Parks with Outlast, naked Husky terra 650.. no heated grips, no handguards.. seriously missed my heated grips and handguards.. gloves were not cutting it at 70 mph.. stopped and put in my metallic liners from REI much better...
Coming home in a balmy 46, gloves were fine. I have had them on my heated gripped hand guards bike , actually warm at 28 degrees ... so... Lee said these were good to about 40 and he is correct.. HTH
919 NC |
