Old 12-26-2012, 04:08 PM   #3031
hoss314
hoss314's Avatar
Oddometer: 135
Black is beautiful...
Sent from my ADR6350 using Tapatalk 2
08' KTM 690 Enduro (Black Rally)
06' CRF450X Plated
hoss314 is offline   Reply With Quote
Old 12-26-2012, 05:31 PM   #3032
Wentjo
Wentjo's Avatar
Oddometer: 420
Originally Posted by Night Crawler View Post
Anyone have the part number for the little pop in plastic clip that holds the vent tube from the gas tank against the frame? Seems like a never ending pain in the ass. I was just going to switch to a shorty with a one way valve, but have heard from too many people having problems with them.
In have the shorty with the one way valve. What kind of problems are people having? Mine seems to be working fine, it the one from KTM hard parts. Drips out a little fuel when you tip it over, but not to bad. I have the same tank and love it.
Wentjo is offline   Reply With Quote
Old 12-26-2012, 06:31 PM   #3033
Night Crawler
Night Crawler's Avatar
Oddometer: 103
http://m.youtube.com/#/watch?v=UEIS9...%3DUEIS9f3X4DY
Night Crawler screwed with this post 12-26-2012 at 06:37 PM
Night Crawler is offline   Reply With Quote
Old 12-26-2012, 07:42 PM   #3034
Wentjo
Wentjo's Avatar
Oddometer: 420
Hmmmm, that's not good. Guess I'll have to pay closer attention to my vent. Thanks
Old 12-27-2012, 04:06 AM   #3035
kjooseppi
Oddometer: 8
Want bigger tank!
Hello
I've been planning to install a bigger tank to my bike (500 EXC -13).
I want to more than 250 km range so I have planned acerbis 20l tank.
But ... I wonder, If the bike handling will suffer, because all of the weight will come as far forward (may also install some navtower).
Another alternative is of course to install 13l tank, and a rear tank in addition. But it is a more expensive option, and harder to do. (getting fuel from the reartank to front).
If anyone has tried one or both options, so thank you!
2008 KTM 950 Superenduro R
2009 KTM 200EXC
kjooseppi is offline   Reply With Quote
Old 12-27-2012, 07:29 AM   #3036
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,749
Originally Posted by kjooseppi View Post
Hello
The bigger tank definitely effects handling when you want to turn or are in the technical stuff. Other than that it is quite manageable. With that said I am almost always running the bigger tank these days, even if I have technical riding to do.
toddler is offline   Reply With Quote
Old 12-27-2012, 11:26 AM   #3037
RSinBC
Oddometer: 185
the cup is half full
Hello
I have the 20 L Acerbis and if you are not on a long distance ride just fill it half way, this way you don't feel it.
RSinBC is offline   Reply With Quote
Old 12-27-2012, 05:41 PM   #3038
PatrickM
Oddometer: 366
Has anyone put more dual-sport oriented tires on their KTM?
I'm thinking along the lines of the Heidenau K60's.
"Why?" you may ask... Well, we have had a butt load of snow in the past week (6' give or take) and my new bike sits in the garage. I want to take her out for the 1 hour break in, and to put her through some moderate paces w/o hitting full tilt dirt and rocks. At least until Spring.
Am I off base? Should just grind off the knobbies (even w/ crazy cagers slipping and sliding on the roadways) or just wait?
Anyone put K60's on their bike, and if so, how long did they last?
PatrickM is offline   Reply With Quote
Old 12-27-2012, 05:49 PM   #3039
SoilSampleDave
Oddometer: 2,161
Air filter maintenance...
The sticker on my '13 says the filter has Motorex/TwinAir Bio Oil on it. That stuff is a lot more expensive than the No Toil version. I am assuming the No Toil cleaner will work fine to remove the existing oil and I can go forward using the No Toil products, right?
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is offline   Reply With Quote
Old 12-27-2012, 05:53 PM   #3040
SoilSampleDave
Oddometer: 2,161
I swear I read most of this thread before buying my EXC, but I didn't think to MAKE ANY NOTES! So, hopefully someone will take pity on me. Looking to install my heated grips. I need a switched wire for the coil of the relay. Is there an unused one in the bundle behind the headlight? I am also assuming there isn't a spare heavy gauge wire right from the battery laying around for the actual load...
'08 530EXC
Old 12-27-2012, 05:55 PM   #3041
SoilSampleDave
Oddometer: 2,161
I would just "use up" the stock knobbies. I actually like knobbies on the street; they break traction very easily and predictably. I get in more trouble on stickier tires that have me over my head by the time they let go.
'08 530EXC
Old 12-27-2012, 06:58 PM   #3042
Honkey Cat
Tailights Fade!
Oddometer: 1,123
Tank vent
Had my tank vent fail also. The little bee b was stuck down.
Honkey Cat is offline   Reply With Quote
Old 12-28-2012, 05:52 AM   #3043
Wentjo
Wentjo's Avatar
Oddometer: 420
The oil on the twin air filter won't come off with No Toil cleaner, you have to use the twin air's cleaner. I tried that on mine and it didn't work very good.
Old 12-28-2012, 06:27 AM   #3044
Upsandowns
Oddometer: 24
Thumb Re Heidenau K-60's for 500EXC
To Patrick M, Post #3039 Yes, I bought an extra set of wheels and put the K-60's on my 500EXC for the summer when I tend to run a lot more on the asphalt and hard, dry dirt. I have several thousand miles, including a lot of dirt/gravel in Ohio, and they have held up incredibly well, hardly showing any wear at all. They are extremely good on pavement, wet or dry, and on hard dirt and rock, not so good on slick, wet dirt. I run them with about 25psi rather than the recommended 36psi but you should not air down much below the 25 and it won't help enough anyway. Don't make the mistake of thinking they're knobbies as they just don't have that kind of grip, but they are wonderful tires and I also run them on my BMW R1200GS Adventure and ride that 2-up much of the time. I am extremely happy with them on the big bike and have ridden a lot of Forest Service type roads on the big bike with no issues of any kind and superb wear - like almost NONE !!! I had trouble believing comments I read elsewhere on ADVRider from guys saying they got as much as 8,000 - 10,000 miles out of them on a 600lbs+ bike, but I'm quickly becoming a believer !!! I'm 68, 6'3" and about 225 at the moment, so you know this isn't coming from the more normal 160 lbs guy the 500EXC is designed for !
Upsandowns is offline   Reply With Quote
Old 12-28-2012, 09:13 AM   #3045
garrett
garrett's Avatar
Oddometer: 469
Both oils work well in my experience but Twin Air oil is a beeyotch to clean. You have to use HOT water to help break down the oil. Hotter than you can touch. I got some Twin Air oil at a closeout for cheap, but none of the cleaner. I've been using TSP.
I also use Filter Skins to prolong the service interval of the filter.
Garrett
I like bikes...
garrett is offline   Reply With Quote
Times are GMT -7.   It's 10:47 PM.
