Old 12-25-2012, 07:58 PM   #6271
snow4brains
snow4brains's Avatar
Oddometer: 3
Question DR200 Carb Question
Hello fellow DR riders!
I picked up an 06 a couple of weeks ago and have the rest of winter to make it mine. Other than fluid changes and a general check up I'll be cleaning and adjusting the carb, maybe... Thats where my question comes in. Has anybody changed to a slide type carb or something else to get away from the C.V. carb? My understanding is the CV carbs give better drivability & fuel economy while sacrificing some performance.
Anybody tried it?
snow4brains is offline   Reply With Quote
Old 12-25-2012, 08:56 PM   #6272
Codyp1814
Oddometer: 11
Anybody tried it?
Keietech makes a pretty good jet kit which you can buy here http://www.kientech.com/ Don't need to change anything just new jets and a needle. It runs richer and more responsive. Also I have a DG slip on exhaust which helps more. You don't need to rejet either if you have the jet kit and the exhaust.
Codyp1814 is offline   Reply With Quote
Old 12-25-2012, 09:06 PM   #6273
Codyp1814
Oddometer: 11
Originally Posted by AleXtz View Post
Here... the screw where oil is comming out is just under the spark plug cable, see if you can take a look
You can be easily fooled on where it is exactly leaking. I had the same leak up around there and I thought first it the camshaft plug, then the front valve cap seal, then rear valve cap seal, so I just replaced all 3 seals. I still don't totally know which one it was.
http://www.powersportsplus.com/parts...EAD/parts.html
Buy #16 (comes with both front and rear seals) and #17 (cam plug).
If this doesn't fix it it may be the valve cover gasket.
Old 12-25-2012, 09:27 PM   #6274
FlyingFinn
Oddometer: 1,121
Anybody tried it?
The little DR is a pretty low performance bike so not many go through the trouble of sourcing, installing and tuning a direct-lift carburetor for it.
That said, I have a Mikuni TM31 on our DR200. The TM31 was a stock carb on couple year models of Suzuki dr250 dirt model.
That carb works really well on the 200 but they are almost impossible to find.
I've played with TM33 and TM36 on my KLX250, I'm pretty sure the 33 would be too big for the 200.
Mikko
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn is online now   Reply With Quote
Old 12-26-2012, 05:15 PM   #6275
snow4brains
Oddometer: 3
Mikko
Thanks, I'll look in to those. I was poking around on ebay and see carbs off rmz125 and 250 . But so far havent found many specs on them. Hmmmmm. lol
Old 12-27-2012, 12:41 PM   #6276
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,474
Tire Compendium
So, I've combed the last 419 pages. Here are the 19 tires that are mentioned being used on the DR200.
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito screwed with this post 12-31-2012 at 05:05 PM
Dorito is offline   Reply With Quote
Old 12-27-2012, 12:44 PM   #6277
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,750
I've got Shinko 705s on mine now.
Old 12-27-2012, 12:48 PM   #6278
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,474
What size Klay? Has anyone run the Kenda 760s in a 120 rear?
BlastOff Adventures
Old 12-27-2012, 01:09 PM   #6279
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,750
I'll check when I get home.
Old 12-27-2012, 01:49 PM   #6280
snow4brains
Oddometer: 3
Picked up a set of Bridgestone TW301 TW302 in 3.00-21 and 4.10-18 should have them mounted in a few weeks. Use to have the same tires (different size) on a KLR250 and really like them on road and they felt better off-road than the OE 50/50's. I'll try to get some pics once theyre on the bike.
Old 12-27-2012, 06:23 PM   #6281
Joelness
Joelness's Avatar
Oddometer: 85
I've run a Bridgestone ED04 Gritty 120/90 in the rear and a Kenda Trakmaster II 80/100 in the front. The Gritty was awesome, on and off-road, and outlasted the stock deathwing, but the Trakmaster has been pretty sketchy on the road and is very near the end of it's useful life at just over 3000 mi.
"You all know how Roman emperors are." -Dennis Degener
Joelness is offline   Reply With Quote
Old 12-28-2012, 07:42 PM   #6282
pozo
Oddometer: 7
Yes, could you please let us know which size you are running on the front and rear? (Particularly the rear, as I didn't recall seeing a matching size on their website...)
I have the 705s on my KLR650 and like them very much. Currently I'm running the Shinko 244s on my 2001 DR200SE, but would like to know the proper size for the 705s on this bike for future reference.
pozo is offline   Reply With Quote
Old 12-28-2012, 07:53 PM   #6283
pozo
Oddometer: 7
Thanks for compiling this info! The accompanying images and tire specs are very useful.
One small note: according to the Shinko website (shinkotiresusa.com), the street/dirt ratio for the 700's are 60/40, the 244s are 50/50, and the 520s are completely off-road tires (DOT legal?).
Hope that info is useful, and thanks again for putting this together.
Old 12-28-2012, 09:34 PM   #6284
alejandro1254
Oddometer: 2
Hello everybody, Ive been reading this post for a few months and now that Im registered too I want to ask you a question.
I have a 2009 DR200 with 1900 miles (almost new), and I want to know how to upgrade the generator of my bike.
Look, I'm a little picky about lights, so Ive installed the cyclope with a HID system and now Im adding two more lights but my little DR cant do with all the three HIDs.
Anybody have an idea?
By the way, Im from Mexico and Im 26
Nice to write to you
Alejandro
alejandro1254 is offline   Reply With Quote
Old 12-28-2012, 09:39 PM   #6285
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,750
Alejandro
Send a message to Ladybug0048. She had her stator rewound for more power. The post is here:
http://www.advrider.com/forums/showp...postcount=2785
Times are GMT -7.   It's 11:38 PM.
