Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 12-28-2012, 06:41 AM   #15226
Kawidad
Kawidad's Avatar
Oddometer: 5,074
Originally Posted by mint julep View Post
yes, use it with Oxford heat grips, easy plug & play.
eastern beaver makes a great plug that fits oem triumph harness.
Me too
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 12-28-2012, 06:50 AM   #15227
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,897
Originally Posted by fbj913 View Post
All of the tiger info is so spread out now. I can't keep track of where to post... anyway,
A little sneak peak!!!
Whilst I acknowledge that you'd be covering up the bling and hiding the pose factor but I'd be wrapping that in a shock sock straight away to help preserve it.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 12-28-2012, 07:32 AM   #15228
fbj913
I ride
fbj913's Avatar
Oddometer: 2,402
not a bad idea.
fbj913 is offline   Reply With Quote
Old 12-28-2012, 07:59 AM   #15229
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,332
not a bad idea.
Not a big fan of shock socks so....I'd sooner put one of those Acerbis flaps on before I put a shock sock on. YMMV....
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 12-28-2012, 07:59 AM   #15230
KildareMan
KildareMan's Avatar
Oddometer: 692
Originally Posted by IndyTiger800 View Post
You can order the switch and sum- harness from Bike Bandit
http://www.bikebandit.com/2012-trium...4257#sch739346
Don't think the oxford grips will work with the triumph switch - that's where the logic is
Sent from my Tiger 800
KildareMan is offline   Reply With Quote
Old 12-28-2012, 08:04 AM   #15231
IndyTiger800
Oddometer: 168
You could splice the switch harness into the controller. Or run the control wires to the hot side of the harness before the relay, and not get the switch.
IndyTiger800 is offline   Reply With Quote
Old 12-28-2012, 08:32 AM   #15232
elan
Oddometer: 132
handguards
I want handguards for my roadie to block the wind and rain. I was prepared to pay for the barkbuster storms, but most places are out of stock from what I've seen.
Is there any reason why I couldn't just order some of the MUCH cheaper moose aluminum handguards with the fat bar mounts and mount them on my tiger? What am I missing here? Why are the barkbuster / touratechs so freaking expensive?
I have the moose setup on my motard CRF 450, so maybe I'll try swapping them over to see...
elan is offline   Reply With Quote
Old 12-28-2012, 08:37 AM   #15233
andoulli
CAJUN
andoulli's Avatar
Oddometer: 2,114
Originally Posted by OmenF1 View Post
I have the heated grips otion and they warm up very good.
BUT : I have the feeling my throttle handle is harder to turn when the heat in on..... Somebody also experience this ;.?
br
Omen
My throttle stuck so bad when my heat was on it acted like a throttle lock. I placed a small stainless washer between grip and hand guard mount, problem solved.
andoulli is offline   Reply With Quote
Old 12-28-2012, 08:41 AM   #15234
fbj913
I ride
fbj913's Avatar
Oddometer: 2,402
I'm really not either. All Ohlins is lifetime warranty so that helps. I already have the Acerbis flap. I'm going to roll with that for a while unless I see a need for more protection.
Old 12-28-2012, 06:48 PM   #15235
doxbike
Oddometer: 291
I tried the Ascerbis, but the aluminum bar was hitting the brake reservoir, don't know about the Mooses (Meese?)
doxbike is offline   Reply With Quote
Old 12-28-2012, 07:38 PM   #15236
pilot3
Oddometer: 429
I'll just add a quick comment. I actually researched the whole hand guard issue at length before I bought my Barkbusters. I couldn't figure out why BB through TwistedThrottle were so much more than buying from BB.
I emailed BB and they spelled it out for me. Basically the Tiger has a different bar contour along with the placement of its controls so all the normal configurations don't match up. BB designed a special set to simply bolt up to the Tiger bars. That's what you're paying for.
I bit the bullet and bought them and it was worth every penny. I also got the bar end weights which are awesome too but did require me to purchase some additional bolts. I'll try to elaborate more later.
p3
pilot3 is online now   Reply With Quote
Old 12-29-2012, 07:29 AM   #15237
Kawidad
Kawidad's Avatar
Oddometer: 5,074
Originally Posted by burgerking View Post
Or buy one of these things
http://www.triumph-sbf.de/Dateien/pr...76ba9ee1ae732e
seems a neat solution and not as prone to breaking as the larger huggers.
Holy crap 149 Euros!!!
Old 12-30-2012, 02:26 AM   #15238
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 297
p3
I have bark busters on my tiger and I completely, utterly HATE them. They don't fit unless you bend them a bit here and there, and then they are tight as buggery and require moving the banjo on the master brake cylinder -- no answer for the kink in the clutch cable. You can either run your levers too high or too low or else wedge the clutch cable over the mount.
Perhaps the fact that they suck on Tigers is why there is this "special set". DO NOT BUY THEM otherwise unless you're a short person perhaps things might line up for you then. I've been close to buying a second set of HDB guards and I'm still suffering because I don't want to throw away my investment. And I feel like I should use the Aussie product but it's hurting me let me tell you.
Lusting for: Currently Sated with the new XCx
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2015 Tiger 800 XCx -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster, 2011 800 XC
Mr_Chris is offline   Reply With Quote
Old 12-30-2012, 05:23 AM   #15239
mjr
mjr's Avatar
Oddometer: 29
Send them my way if you don't want them.........
mjr is offline   Reply With Quote
Old 12-30-2012, 06:51 AM   #15240
fbj913
I ride
fbj913's Avatar
Oddometer: 2,402
mine works fine. you can move the reservoir.
Times are GMT -7.   It's 11:03 AM.
