Old 12-26-2012, 10:59 PM   #5026
go::ahead
go::ahead's Avatar
Oddometer: 69
All good info, thanks man. My girlfriend works for a photovoltaic systems distributor and they have a solid electrician in house, I'm going to have him over to check the circuit. I hadn't realized that outlet was added as an after thought but now its obvious!
I finished insulating that wall tonight and picked up the sheet rock, I'll get the wiring squared away and start hanging rock tomorrow. I can't believe there were actually smoke stains around your electrical "handi-work", I know this wiring isn't up to today's standards but I haven't found anything as bad as 6 wires taped together
2000 KLR 650
2009 Surly Karate Monkey, rigid SS
2012 Specialized Camber 29
2012 Masi CX SS
go::ahead is offline   Reply With Quote
Old 12-27-2012, 10:54 PM   #5027
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 638
P1000756
This was the overnight parking I was offered at Backpackers we stayed at on our recent trip down south. (The milling machine is on the opposite wall)
I GS 1 is offline   Reply With Quote
Old 12-28-2012, 06:20 AM   #5028
ducnut
Oddometer: 3,306
Originally Posted by I GS 1 View Post
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 12-28-2012, 10:12 AM   #5029
go::ahead
go::ahead's Avatar
Oddometer: 69
Originally Posted by ducnut View Post
I wouldn't redo a rental, either. It might pay to get friendly with your landlord and have them consider hiring an electrician to help you and to protect the property and your life. If your city requires inspections of properties for sale, that property would have to be brought up to code.
Obvious stuff: There are no wire protectors on the wire running through the studs. The wires running to that switchbox(?), in the corner, aren't through the corner studs and unprotected. That particular circuit is clearly added into an existing circuit, by the way the left wall is cut into. If you're sheeting that back wall, the switchbox(?) must face out, as there can't be any type of box concealed by sheating. Also, you need to verify that circuit (how it's mated to the existing circuit, appropriate gauge wire/breaker, protection, etc). None of the wiring is secured to the studs with staples, as required in any code. Some codes have switch/outlet height restrictions.
Ok so I tore into the box last night and discovered this mess
Does that look like burns to you?
Back together
Conduit that feed through the wall doesn't reach all the way to the box, maybe 1.5" shy. I can't figure out what this these wires even run to, they go through the wall and down into the ground outside of the house.
Still no where near perfect but its the best I could do to just tidy up the wiring safely, I'll have my guy check it all this weekend. My real fear is that I'll find more birds nests like that in the house, I'm going to poke around and make sure...
Here is the first wall finished. No tape or mud, it would really throw off the aesthetic of the place
Those gaps aren't crooked cuts either, some sheets are unlevel at joints by a quarter inch depending on where the studs are
2000 KLR 650
2012 Masi CX SS
Old 12-28-2012, 03:09 PM   #5030
ducnut
Oddometer: 3,306
WOW!
'96 Ducati 900SS
Old 12-28-2012, 04:49 PM   #5031
SantaFeTrailer
Stromtrooper
SantaFeTrailer's Avatar
Oddometer: 316
Nice score. I've got two rolling red metal work carts that I don't really need, but might want to have back at some distant point in the future. If you want them in the new cave 'till that day - and that day may never come - PM me.
So here it is!
My girlfriend and I finally found an affordable rental in Santa Fe that has a garage, no small feat! The house is a 50's signature faux adobe, thus no insulation and sketchy wiring. On the plus side the ceiling is so high i couldn't get it into the frame of the crappy cell phone camera. Those shelves you see behind the garage door are hanging down a good 3' and wrap all the way around the space, endless storage!
Since this is a rental I'm keeping costs to a minimum, I'm giving myself a budget of $200 to make it a more enjoyable workspace. I think I have a free roll of fiberglass insulation which should take care of one wall, that just leaves me one other exterior wall to insulate. I'm thinking of hanging thin ply over that.
Last night I started by ripping out that nasty old peg board on the back wall, the 'workbench' is coming out today after I pick up a crowbar on my way home from work. I'll insulate that wall then put in a proper workbench, hopefully I can find a formica counter top to use
SantaFeTrailer is offline   Reply With Quote
Old 12-28-2012, 04:53 PM   #5032
SantaFeTrailer
Stromtrooper
Oddometer: 316
Hey go:ahead
I have a copy of the 2009 IRC (the current code that controls in Santa Fe) here at the office that you are welcome to thumb through if you can make heads or tails of it.
Thanks guys, I was thinking the same things. Just do it right
What looks (noticeably) bad about the wiring on the back wall? I'm pretty sure that's original work, not that that's a good thing... I'm not about to redo all the wiring on a rental!
Old 12-28-2012, 07:23 PM   #5033
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,270
Back together
I would cap the brownish wire too, just in case it gets hot later.
Looks much better!
Jim
Old 12-28-2012, 08:27 PM   #5034
jeep8
Oddometer: 279
You should buy a 1.5inch octagon box extension ring to allow you to get a locknut on the conduit in the back of the box. It appears to have only one bare ground wire from the romex, If so, tie that grounding wire to the junction box. Also the 2 white wires appear to be showing bare conductors, they need to be trimmed to the correct length, retwisted and wirenut reinstalled. When I am trying to do my best work I will wrap scotch 33 or 88 tape on all the conections over the wire nut and around the wires to help prevent the nuts coming off or the wires from seperating. Tape or wirenut all unused wires.The 1/2 inch knock out hole on the left side needs a pushpenny or plug in it to help contain a fire inside the box. Use diagonal cutter to trim cleanly the outer jacket on the romex. Other than all that, it looks good.
This last comment should be at the top of the page.
Change batteries in smoke detectors when you change your clock for daylight savings.
jeep8 screwed with this post 12-28-2012 at 08:35 PM
jeep8 is online now   Reply With Quote
Old 01-02-2013, 09:59 AM   #5035
go::ahead
go::ahead's Avatar
Oddometer: 69
Looks much better!
Jim
What kills me the most is I can't figure out what it goes to or why, the hunt continues!
2000 KLR 650
2012 Masi CX SS
Old 01-02-2013, 10:01 AM   #5036
go::ahead
go::ahead's Avatar
Oddometer: 69
Thanks! I'll open the box tonight and touch it up.
2000 KLR 650
2012 Masi CX SS
Old 01-02-2013, 10:04 AM   #5037
go::ahead
go::ahead's Avatar
Oddometer: 69
WOW!
You think that's bad? Wait till I get some pics up of the switch & outlet box I opened last night, pulling all that apart and redoing it correct is going to be its own project
2000 KLR 650
2012 Masi CX SS
Old 01-02-2013, 12:24 PM   #5038
aposaric
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Nice garage. I am not familliar wit US domestic electric schemes, since I am from EU, but to me it looks like an atempt of a 3 phase outlet, so you may want to check it out, I may be wrong but just an idea :-)
aposaric is offline   Reply With Quote
Old 01-04-2013, 09:27 AM   #5039
sierraoffroad
sierraoffroad's Avatar
Oddometer: 1,329
Looks much better!
Jim
there should be a 1/16 thich sheet metal plate covering the holes where wires pass through studs, and where the studs are notched shown in the pic (post #5040). just my 2 cents. i'm quoting the 2011 NEC from NFPA 70 the sheet metal plate is to prevent screws or nails from puncturing the wire assembly.
It's a Jungle out there.
2007 Blue Weestrom
2004 Yamaha Wr250f
sierraoffroad is offline   Reply With Quote
Old 01-04-2013, 01:07 PM   #5040
go::ahead
go::ahead's Avatar
Oddometer: 69
huh, hadn't seen that before
2000 KLR 650
2012 Masi CX SS
Times are GMT -7.   It's 02:00 PM.
