09-16-2012, 09:57 AM
#76 |
Pig ridin'
Oddometer: 173
Skid plate in place:
Fabrice TCAT traveler: If ever in need near Saguenay, Quebec; have tools, will help. PM me. http://www.fabricetremblay.ca My HPF: 21 inch-mx forks R11GS conversion |
12-21-2012, 07:54 AM
#77 |
Unicorn Wrangler
Oddometer: 216
Very impressive, lots of heart put into this one.
Forget it, drive on. 2009 GSA 2008 Husky TE450 2007 Ducati GT1000 Sold 2005 DRZ 400 SoldIBA 50407 |
12-21-2012, 08:41 AM
#78 |
motorcycle addict
Oddometer: 895
Fabrice,
If I have not told you already....you are an inspiration. I will NOT blame you if my build goes south at some point, but I will give you props for inspiring it and giving me many, if not most of my starting points. ![]()
it is easier to ask for forgiveness than permission |
12-21-2012, 09:29 AM
#79 | |
Pig ridin'
Oddometer: 173
Feel free to share a link to your build anytime.
12-28-2012, 09:34 AM
#80 |
motorcycle addict
Oddometer: 895
I just wanted to post in this thread so I can find it easier....great job.
I do have one question, I see you used the bearing mount for the telelever arm by cutting off the bearing end. I then see you ran up some 1" pipe and welded it to the rear frame stats. I am missing something I guess, but the rear stays are steel and the bearing ends for the Telelever are aluminum...did something change in there? Or is there a steel insert inside of the aluminum end that you used to weld the 1" steel support tubes to? Or wilder yet are the upright tubes aluminum and you have developed some cool way to weld steel to aluminum? ![]() If anyone is still watching, I am thinking of welding in an aluminum CR neck much the same as Fabrice did, but I am thinking of taking the Telelever arm and modifying it some, swinging upward and welding it to the bottom of my CR neck and then bracing it to the front frame on the bottom. Obviously this will take some playing with, but I think that will help transfer some of the rearward force that some of you were concerned with right back to the original point that the Telelever would have recevied the braking or forward impact force {meaning hitting a bump and pushing backwards on the steering neck}. This should also help with side forces as it widens the base mounting point of the bottom of the neck. Engineers or serious fabbers, what do you think?
12-28-2012, 12:57 PM
#81 |
Oddometer: 1,249
More pictures of the painter please.
94 DR 350 SE |
12-28-2012, 02:09 PM
#82 |
Oddometer: 2,206
where/what are the new headlights from?
aka BMWST?
12-28-2012, 03:03 PM
#83 |
Oddometer: 4,248
12-29-2012, 07:05 AM
#84 |
Pig ridin'
Oddometer: 173
Ebay, CBR 400. With xenon kit which I don't recommend. I would rather go with standard high output bulbs. Xenon messes up the RID and the light pattern is not great with the CBR400 housing.
12-29-2012, 07:06 AM
#85 |
Pig ridin'
Oddometer: 173
Unfortunately she's camera shy.
12-29-2012, 07:09 AM
#86 | |
Pig ridin'
Oddometer: 173
12-29-2012, 08:36 PM
#87 |
motorcycle addict
Oddometer: 895
Got it.
It sure looked like you were cutting an alumnium A-arm in the pic on the band saw. My bad though. Still lovin the build.
05-13-2013, 08:44 PM
#88 |
said in my best trading places jail cell voice " YEAH"
96 R1100GS, Ohlins shocks, V-Stream STD, Pro Tapers (Pastrana F/S bend), Trackside Grip Heaters, Cycra Pro bends, Pivot Pegs, Leo Vince, Anakee IIIs. 95 XR650L, Mikuni Pumper, Yosh, Baja Designs race Light, Pro tapers, Cycra Pro Bends, Magura 1/4 turn, Pirelli MT90s. |
05-15-2013, 05:23 PM
#89 |
a.k.a. Mr Rico Suave
No offense but personally I be scare shitless of riding that bike, that "Mast" is a aluminum casting, not even close to be strong enough to hold such a load on his own, not even mentioning the way the new steer tube is attach to it (as nice of a weld you as it is) is just to weak of a junction.
I just hope you don't get really hurt when the fork comes apart..
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore. |
