Old 12-28-2012, 11:06 AM   #1
trailrider383 OP
867-5309
trailrider383's Avatar
Oddometer: 3,269
How Should I Insulate My Pole Barn Ceiling?
Winter is finally here and I need a project to relieve the boredom. I have a 30 x 40 pole barn with nothing on the ceiling for insulation. I need help on figuring out the proper way to insulate it.
I have read about different ways to do it and I can't make up my mind what to do. I would prefer something easy to install. I am thinking about some kind of foam board. But then I start reading about vapor barriers, etc. I don't need a real high R value, just something to keep it a little cooler in the summer and to hold the heat in a little longer in the winter when I fire up the 110,000 btu space heater (kerosene torpedo heater.)
What I do now is go out and crack a window and fire up the space heater for 10 or 15 minutes til the temp comes up to around 50 and shut it off til I get cold. Sometimes I will let it run and cycle off the thermostat if I'm going to be out there a long time. But not usually, because it is so loud. One thing you should know if you haven't used one of these heaters is they introduce a lot of moisture into the air which then condenses on the metal roof and drips.
This is what I have to work with:
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 12-28-2012, 11:27 AM   #2
SilkMoneyLove
SilkMoneyLove's Avatar
Oddometer: 2,188
Hmm
That is a lot of space, maybe install a drop ceiling with foam panels? It shouldn'e add too much weight and should add a few Rs. Might also quiet it down a bit for when you are working with equipment.
SilkMoneyLove is offline   Reply With Quote
Old 12-28-2012, 11:33 AM   #3
troidus
Oddometer: 14,645
I'd have a contractor spray it with A-B foam. Do the walls, too.
troidus is offline   Reply With Quote
Old 12-28-2012, 11:43 AM   #4
trailrider383 OP
867-5309
Oddometer: 3,269
I can't do a drop ceiling because I have lights hanging 6" below the rafters. And an I beam for a hoist is up there also. Here is another view:
Old 12-28-2012, 12:04 PM   #5
troidus
Oddometer: 14,645
I still think spray foam is your best bet. It's self-supporting and rot-proof, as long as you keep UV light away. If you're going to weld in there, you might need a portable barrier around your project.
Old 12-28-2012, 01:05 PM   #6
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,286
I used this "TekFoil" product on the walls and ceiling of my garage, I don't see why it wouldn't work in your barn.
http://www.teksupply.com/farm/suppli...nsulation.html
Staples up quick & easy, is virtually fireproof (I tried on a sample) and keeps the heat in (in the winter) and the sun's heat out (in the summer).
The interior of the garage is way brighter, the lighting is much more effective.
I liked it so much, I used it behind the sheetrock on an addition to my house.
A similar product is available at Home Depot.
http://www.homedepot.com/webapp/wcs/...1&distance_1=5
HapHazard is online now   Reply With Quote
Old 12-28-2012, 02:01 PM   #7
trailrider383 OP
867-5309
Oddometer: 3,269
Which one did you use? That link shows about four different types.
Old 12-28-2012, 03:50 PM   #8
dmftoy1
dmftoy1's Avatar
Oddometer: 241
If you didn't do the foil/insulation when you put the roof on then the best bet is spray foam followed by normal insulation with a ceiling hanging off the bottom of your trusses. I had to spec that in the design on mine though so if you didn't then I'd go foam. Ymmv
Have a good one,
Dave
dmftoy1 is offline   Reply With Quote
Old 12-28-2012, 04:10 PM   #9
darenative
Oddometer: 206
Have it sprayed with 2 part foam. BTDT, money well spent.
darenative is offline   Reply With Quote
Old 12-28-2012, 04:58 PM   #10
trailrider383 OP
867-5309
Oddometer: 3,269
What did it cost?
Old 12-28-2012, 07:56 PM   #11
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,757
Closed-cell spray foam, about 1" should do what you need it to do. It's flammable, so you would want to sheath the walls with drywall or metal.
It acts as a vapor barrier, so if you ever wanted to increase your R-value you can go with regular fiberglass batt right over it.
A vented heater would be a good investment, too.
We used foam in the house we built a couple years ago and have been very happy with the results.
Laconic is offline   Reply With Quote
Old 12-28-2012, 08:59 PM   #12
trailrider383 OP
867-5309
Oddometer: 3,269
The walls are already insulated and sheetrocked. Thanks for the info.
Old 12-28-2012, 09:08 PM   #13
dave186
Oddometer: 179
I have a friend that does spray foam. I dont know much of anything about it but could pass along his number if your interested, Im not far from you.
dave186 is offline   Reply With Quote
Old 12-28-2012, 09:19 PM   #14
trailrider383 OP
867-5309
Oddometer: 3,269
That would be helpful. Thanks.
Old 12-29-2012, 03:47 AM   #15
RonkoRider
Wrong Island, NY
RonkoRider's Avatar
Oddometer: 1,576
Forgive my ignorance, do you use this in place of insulation or in conjunction with it?
Rob VB
Two roads diverged in a wood, and I I took the one less traveled by, And now where the fuck am I?
Long Island Tag o Rama II 2014 - Click Here
Long Island BMW Riders Club- Click here for our website
RonkoRider is offline   Reply With Quote
Times are GMT -7.   It's 06:22 AM.
