Old 12-28-2012, 01:47 PM   #72211
Ren20
Finding Touge
Oddometer: 111
Yea, Spoken with the seller. He confirmed it's an acerbis. Only wish He posted pictures of different angles.
Ren20 is offline   Reply With Quote
Old 12-28-2012, 01:52 PM   #72212
acap650
acap650
acap650's Avatar
Oddometer: 712
Originally Posted by ren20 View Post
is this an ims or acerbis tank? Seller claimed to be acerbis. But look ims to me. I think acerbis is more angular, correct?
ims
acap650 is offline   Reply With Quote
Old 12-28-2012, 01:57 PM   #72213
canoli
human
canoli's Avatar
Oddometer: 1,729
Originally Posted by Phreaky Phil View Post
This seems to be a common problem. When I fitted mine I had it the same as yours and when I hit reserve the bike would die even though I had changed to reserve. I had to blow down the tank vent to get fuel into the carb before it would go again.
What you need is a longer hose between the T piece and the carb and it needs to loop down and back up to the tank. This cures it. Straight in like you have it seems to cause an airlock. With the hose going down hill there is always some fuel in it.
Thanks I'll put a "loop" back in it.
Canoli
canoli is offline   Reply With Quote
Old 12-28-2012, 02:00 PM   #72214
doug s.
Oddometer: 1,348
that looks like an ims to me; not an acerbis.
acerbis:
ims:
if it's an acerbis, it's some older type...
doug s.
doug s. is offline   Reply With Quote
Old 12-28-2012, 02:14 PM   #72215
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 571
Originally Posted by trailrider383 View Post
This post makes me appreciate my simple DR all the more. http://www.advrider.com/forums/showp...3&postcount=33
Every time a new thumper comes out I get excited and think it might be something to replace the DR. Then I read posts like this. All that just to change the oil.
And I thought changing the oil on my old 520exc was a PITA. Love my dr though suspension no where near that of the old 520...
Slideways#96 is offline   Reply With Quote
Old 12-28-2012, 02:15 PM   #72216
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,140
Is this an IMS or Acerbis tank? Seller claimed to be acerbis. But look IMS to me. I think acerbis is more angular, correct?
Def an IMS.
NordieBoy is offline   Reply With Quote
Old 12-28-2012, 02:20 PM   #72217
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,349
I so badly wanted to put my DR650 engine in the chassis of my 2000 KTM 250 exc. That would've been a fun bike.
Now I think I would just get a 2007 525exc and call it even.
DR is easier to change oil on.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 12-28-2012, 02:25 PM   #72218
Kommando
Kommando's Avatar
Oddometer: 7,389
That looks just like my IMS 4.9. The Acerbis 5.3 is more angular. The Acerbis 6.6 for older DR650s looks different.
Kommando is offline   Reply With Quote
Old 12-28-2012, 02:26 PM   #72219
Kommando
Kommando's Avatar
Oddometer: 7,389
Originally Posted by neo1piv014 View Post
Looking at my Acerbis4.9 tank, it appears that the petcock actually sits below the level of the intake on my carb. Anyone else notice this? I can't actually hook up the fuel line without there being a bit of an uphill climb to it or a bend.
The OEM Suzuki petcock on my IMS 4.9 was just a hair lower than my carb inlet. Then I turned the inlet.
Old 12-28-2012, 02:32 PM   #72220
Slideways#96
scooter trash
Oddometer: 571
Dr oil change is a breeze. Newly purchased 79 xr600 framer should be just as simple. Gotta love simplicity fer sure. Your 250 is a stroke right? Got a 300xcw but she doesn't get ridden much since purchase of the dr and now the track bike in the works. I need to find a way to retire so I can ride em all.... :)
Old 12-28-2012, 02:33 PM   #72221
Ren20
Finding Touge
Oddometer: 111
Interesting. I also think that's an ims tank. may just have to call the seller again.
I like the angular acerbis more.
Ren20 screwed with this post 12-28-2012 at 09:56 PM
Old 12-28-2012, 02:39 PM   #72222
Slideways#96
scooter trash
Oddometer: 571
Looks like the IMS on my dr.
Old 12-28-2012, 02:45 PM   #72223
Rusty Rocket
Life behind "Bars"
Oddometer: 9,349
Yeah, 250 was 2T. For what I sold it for, ($900), I should've kept it and put the forks on my DR.
I'm 59 and been retired 2 years now. ( RichBebe)
Still don't ride as much as I'd like.
2009 DR650
Old 12-28-2012, 03:16 PM   #72224
Cobain
night owl
Cobain's Avatar
Oddometer: 132
Originally Posted by Cobain View Post
Thats the one on craigslist right, in spokane?
U live in spokane area?
Cobain is offline   Reply With Quote
Old 12-28-2012, 03:21 PM   #72225
neo1piv014
ADV in training
Oddometer: 619
Oxford Heated Grips
My lady got me the Oxford heated grips from Twisted Throttle for Christmas, so I thought I'd share a few quick words on them:
1 - the build quality leaves a bit to be desired. When reading through the installation instructions, they actually tell you that you will likely need to take a metal file to the inside of the grips because their rubber molding process may not leave the grips with the correct inner-diameter. This was definitely true in my case. They aren't pretty on the inside, but since the inside is now glued to my bars, I guess that doesn't matter.
2 - the wiring harness for my left grip completely fell apart as soon as I plugged them in. I wound up just soldering the wires together, and it works fine now.
3 - those two points out of the way, these grips heat up in a couple minutes, and they get damn hot. I cannot wait to try these out on the road.
4 - Right now, I just followed the instructions and wired the things straight into my battery. This does mean that any joker can come by in the parking lot, push the ON button, and kill my battery. It also means that I have to be vigilant about turning them off when I turn off the bike. Does anyone else run heated grips off that switched ignition pair that resides under our headlight shrouds? They have a 5A inline fuse, and I don't think the wattage was actually all that high.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Times are GMT -7.   It's 01:27 AM.
