Old 12-29-2012, 12:39 AM   #1
Navin OP
Unwounding
Navin's Avatar
Oddometer: 4,326
How to test a stator???
My Burg 570 is giving me a single spark at turn over, then nothing from the plug wire. I've pulled off the cap at this point to eliminate it from the equation. It will not spark again till I shut the ignition off/on and spin it again, where it shoots a single spark once again.
I've replaced the coil pick up on the advive of the dealer who had similar symptoms on a few F.I. KTMs but no difference. Next suspect I'm told is the stator itself. I have a multimeter but no idea what to check here.
Thanks for any advice. Bike has about 1000 miles on it. Started having starting troubles and devolved to this stage.
Navin is offline   Reply With Quote
Old 12-29-2012, 04:20 AM   #2
greener556
Oddometer: 92
Should not have continuity to ground on either of the stator leads.
There should be continuity between the stator leads.
Is there any kind of ignition box??
greener556 screwed with this post 12-29-2012 at 04:33 AM
greener556 is offline   Reply With Quote
Old 12-29-2012, 04:37 AM   #3
concours
WFO for 41 years
concours's Avatar
Oddometer: 3,995
As stated, PLUS there is a resistance value for the stator circuits, listed in your factory shop manual.
2007 Tiger 1050
2005 Royal Star Tour DeLuxe
1973 Yamaha TX750
1974 Norton 850 Commando Roadster
Old 12-29-2012, 10:23 AM   #4
Beezer
Oddometer: 4,419
does not sound like a stator problem to me.
Beezer is offline   Reply With Quote
Old 12-29-2012, 12:03 PM   #5
vtduc
Oddometer: 80
This.
vtduc is offline   Reply With Quote
Old 12-29-2012, 12:13 PM   #6
Navin OP
Unwounding
Navin's Avatar
Oddometer: 4,326
Thanks guys, any clue where to look next? I've been unplugging stuff and trying it again with the same result, single spark on first turn over and dead.
Times are GMT -7.   It's 03:46 PM.
