12-29-2012, 10:24 AM
#72421 | |
on the road o'dreams
Oddometer: 5,510
There are plenty of good reasons to buy new. Sure, there are good deals around on used DR's if you're patient ... and lucky. They are reliable bikes for the most part ... but they do have one or two SHOW STOPPER issues. Main advantage of buying NEW is the warranty ... and the ability to buy an Extended Warranty up to 5 years. This covers things like 3rd gear failures. Rare as they are ... if it happens in 5 years ... you get a NEW motor. That's a lot of riding. Next is a zero interest loan with a LOW monthly payment. This just works for some folks. But for the OP, "New" may not be his best choice. Impossible to know if he'll even like the DR650. If you buy NEW, add a warranty, add $1000 in extras, then decide you don't like the bike ... well when you go to sell it off you'll take a major hit. What the OP needs to know is that a showroom stock DR650 is no where near what a modified DR650 can be. So whatever DR you get ... to get the best out of it plan to do some modifications and adding some extras. There are THOUSANDS of posts here detailing what those extras are ... and what they do for you. Good luck! My Advice: TEST RIDE TEST RIDE TEST RIDE!!! |
12-29-2012, 11:08 AM
#72422 |
Asperger
Oddometer: 2,142
If that's the case, I'd got with cartridge emulators over intimators.
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
12-29-2012, 11:57 AM
#72423 |
Oddometer: 20
Tire Boo Boo?
Well I put on a D606 on the front of my bike today using the Ziptie method. I thought everything went great until I started on the rear (the front is back on the bike) and I notice that the tube stem has a beveled washer and nut on the inside of the rim and a nut on the outside. The new tubes I put in only came with one nut and the beveled washer, so I used the beveled washer on the inside of the rim and the nut on the outside. No nut on the inside.
Is this a problem or should I just wait until I wear out the front to install a nut on the inside of the rim? Or should I go ahead and pull the front and make it right? |
12-29-2012, 11:59 AM
#72424 |
Finding Touge
Oddometer: 97
regarding the IMS tank earlier.
It's confirmed indeed it was an IMS tank. The seller wants me to mail him a cashier check first. he ships it, then i will send him a second check to cover the shipping cost. I've done paypal, but never done cashier check before. Plus he gave me an po box address. to be honest, I am skeptical now as he was when I called him stating I am from a different state. This deal probably save me about 70 dollars than buying new from justgastank. Worth taking the chance? I still like the acerbis tank better. |
12-29-2012, 12:17 PM
#72425 | |
Oddometer: 1,179
in this case, what's $70, especially if it's not what you really want? that's about $1.35/week for a year... doug s. |
12-29-2012, 12:18 PM
#72426 | |
Armature speller
Oddometer: 6,847
I came into off road via road riding and like the front to be firmer and higher than traditional off road suspension. I don't like brake dive. NordieBoy screwed with this post 12-29-2012 at 12:27 PM |
12-29-2012, 01:02 PM
#72427 | |
barko1
Oddometer: 2,513
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1, 77 Goldwing 1000, V11 Rosso Mondello Guzzi |
12-29-2012, 01:09 PM
#72428 | |
Kool Aid poisoner
Oddometer: 5,061
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
#72429 | |
Oddometer: 264
A couple years ago a DR owner posted (on Thumpertalk) his bike blew 3rd gear and apparently did a lot of damage. His bike was still under the factory warranty but the cost to repair exceeded the bike value, so they were going to total it. The owner was pissed because he financed the bike and owed more than book value. Eventually the thread disappeared so Suzuki must have provided a satisfactory solution. |
12-29-2012, 02:44 PM
#72430 | |
Oddometer: 141
12-29-2012, 03:02 PM
#72431 | ||
Oddometer: 1,708
I got rid of the internal filters from the taps, and the one to the carb. I still have a servicable in line filter, which is also positioned vertically to no air traps in it either. Having a swivelling inlet on the FCR helps for sure too. On the BST, I cut off the original pipe and threaded in a straight fitting. When I tried to turn it, I thought it might break the carb. |
12-29-2012, 03:12 PM
#72432 |
Oddometer: 1,708
6 oclock would be even better, then there is no fuel line above the bottom of the tank or the float bowel.
12-29-2012, 03:16 PM
#72433 | |
Oddometer: 1,708
Ride it. |
12-29-2012, 04:28 PM
#72434 |
Oddometer: 929
Absolutely NOT. But I'm cynical from working financial crimes for the past 12 years. Besides, go buy what you really want. 10 years from now, you're not going to slap yourself on the back over saving a few bucks. But you will look at pics - or your bike - with the "that's exactly how I wanted it" satisfaction grin.
www.dualsportmoto.com 2005 DR650 2013 HD Road King "It's a small amount of gas, but it represents a long walk" My Dad... |
12-29-2012, 04:29 PM
#72435 |
Asperger
Oddometer: 2,142
New Bars, Choke Lever ?
I got new bars and everything else seems to go on, fit fine except the choke lever. The bars are checkered on the left side and the inner diameter of the choke lever seems smaller than the outer diameter of the bars and won't go on. I could dremel it but seems it should just go on like on the stock bars. This couldn't have been an issue for everyone, right? Or, what did you do? They are Fly Aero tapered bars from Procycle by the way.
BTW, it slides right over the other side (the wrong side). Are the bars soft enough I can sand the checkered part on the left?
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. acesandeights screwed with this post 12-29-2012 at 05:19 PM |
