Old 12-30-2012, 09:09 AM   #46
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,521
Originally Posted by roger123 View Post
What happened to that garage door? Look at the angles!
Jim
Old 12-30-2012, 09:28 AM   #47
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,288
Jim
You can install the track like that to wedge the door in the closed position
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 12-30-2012, 09:40 AM   #48
the_gr8t_waldo
Oddometer: 2,159
spent yesterday tranfering down into my diy top quilt(hammock camping gear). sewed that up, cleaned up the garage, and moved out some things to make room for taking plastics off of the st1100 for winter maintance. long list of things to do this time around.
the_gr8t_waldo is offline   Reply With Quote
Old 12-30-2012, 10:08 AM   #49
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,288
I answered one of the big questions of life itself.
I don't know about you guys but I have always wondered what the oil coller inside a Sicon XB radiator looked like.
And why is it that whenever the weather turns cold some device contianing water fails?
The radiator in my kids XB shit the nest and I decided to cut it up and see whats inside.
It's tubular. Well made for sure. Thinking about trying it as an oil cooler.
Regards
Fritzcoinc
Old 12-30-2012, 10:25 AM   #50
Vincenthdfan
Oddometer: 520
Cut up a bunch of tile for this project (total master bath remodel). Poor Wee Strom is buried under remodel supplies and the FJR has been kicked out to make room for all stuff that was brought in for the re-do. Geeting close to the end though.
Blasphemy! Please dont lean stuff against a living/breathing motorcycle like that.
They have feelings too ya know?
Vincenthdfan is offline   Reply With Quote
Old 12-30-2012, 12:41 PM   #51
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,934
Went for a 30 mile ride on the sled. Worked great! The old body isn't like it used to be though.
Consuming beer now and going to the living room to watch the Vikes kick Green Bays ass.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 12-30-2012, 06:22 PM   #52
JimVonBaden OP
"Cool" Aid!
Oddometer: 54,521
Jim
Old 12-30-2012, 06:42 PM   #53
RickS
RickS's Avatar
Oddometer: 612
Watched the roof leak. Dang flat roofs and ice build up. Think it is leaking from the drains that go to gutters. I hate flat roofs
RickS is offline   Reply With Quote
Old 12-30-2012, 07:48 PM   #54
racer1735
Oddometer: 375
Re-jetted the carb in my son's CR85R (for the cold weather). And noticed a bad leak in the sink in my garage.
racer1735 is offline   Reply With Quote
Old 12-31-2012, 04:45 AM   #55
roger123
roger123's Avatar
Oddometer: 1,634
Must be an optical illusion, door works fine!
'14 Tenere ES
COG 5903
roger123 is offline   Reply With Quote
Old 12-31-2012, 04:47 AM   #56
roger123
roger123's Avatar
Oddometer: 1,634
I know I feel so bad. Not sure what's worse, using the Wee as a stand or making the FJR sleep outside for the last two weeks. Please don't call child protective services! I'll get better, I promise.
'14 Tenere ES
COG 5903
Old 12-31-2012, 06:29 AM   #57
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,288
Right thats what I mean. The track can be installed in a taper towards the floor. This makes the door fit tight in the track when closed. This keeps it from rattling in the wind.
Regards
Fritzcoinc
Old 12-31-2012, 06:07 PM   #58
arcanum
Oddometer: 317
Started working on a 8 HP briggs on a rear engine Snapper rider. This is an early 300 series mower that a tenant left when she moved. Once I found that it had spark,took off the carb and soaked it in an old coffee maker with heated Krud Kutter solution. Put some carb cleaner and compressed air thru it and with a gasket or two,it is ready to test.
arcanum is offline   Reply With Quote
Old 12-31-2012, 07:12 PM   #59
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,728
Changed the oil and filter on the Ulysses, replaced the serpentine belt on the Chevy, started working on freeing up the engine of the Stinger.
http://www.advrider.com/forums/showt...204237&page=15
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 01-01-2013, 05:37 AM   #60
Guy Young
Guy Young's Avatar
Oddometer: 8,585
Not today - yet - but going through the process of trying to get a '79 Guzzi V1000 G5 running again:
Heads retorqued, valves adjusted, points cleaned/adjusted, (static) timing set, new battery installed, and getting ready to dig into the carbs and replace the throttle cables. Waiting on parts, so can only go but so far.
Local NYD ride cancelled due to yukky weather, so will probably get out there a little later and play in the (cold) grease. .
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/Garage-Project
Guy Young is offline   Reply With Quote
Times are GMT -7.   It's 12:39 PM.
