Thread Tools Search this Thread Rating: Thread Rating: 437 votes, 4.94 average. Display Modes
Old 12-30-2012, 07:00 PM   #6451
ramz
Professional Trail Rider
Oddometer: 2,022
Guys, get the CD - it installs on the PC/Mac and GPS receiver!
Other - the directories are invisible.
ramz is offline   Reply With Quote
Old 12-30-2012, 07:17 PM   #6452
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
Originally Posted by Albie View Post
Hmm, where does it leave those directories? I've never stumbled across them.
You see them when you connect the device to a Windows computer.
Emmbeedee is online now   Reply With Quote
Old 12-30-2012, 07:18 PM   #6453
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
Originally Posted by ramz View Post
Guys, get the CD - it installs on the PC/Mac and GPS receiver!.
Just for the record, it's a dvd.
Old 12-30-2012, 07:41 PM   #6454
tundradirtbiker
Oddometer: 342
If the PC will take either DVD or SD disk, would the SDd be preferred for el speedo?
'05 450 EXC
tundradirtbiker is offline   Reply With Quote
Old 12-30-2012, 07:49 PM   #6455
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
The dvd is still better in many ways. You can't upgrade the SD version without buying it anew. No Lifetime Map Updates for the SD version.
Old 12-30-2012, 07:50 PM   #6456
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
THIS!
atlas cached is offline   Reply With Quote
Old 12-30-2012, 08:08 PM   #6457
tundradirtbiker
Oddometer: 342
Tx MBD
'05 450 EXC
Old 12-30-2012, 09:43 PM   #6458
eddyturn
Wannabe
Oddometer: 2,107
Good doG awlmighty.... I thought that I was close to getting what looks like a new release of the unit but having to soak all of this in is baffling me and keeping me with 2 478's and one of those for back up. Maybe after the first of the year and have my wife drive me everywhere. Dang scary for a computer set up phobe. Looks like a college course that changes frequently. Somebody should scan this all and put together a comprehensive book for this and make GMan look more foolish than they already do.
All things being equal... fat people use more soap
eddyturn screwed with this post 12-31-2012 at 11:17 AM
eddyturn is offline   Reply With Quote
Old 12-31-2012, 01:05 AM   #6459
advNZer?
advNZer?'s Avatar
Oddometer: 2,925
Originally Posted by leftystrat62 View Post
This kind of helped,but I'm still falling short of success. Here's what I have:
This is a screen shot of DockingPilot's TAT section -the exact same section I'm trying to load up
I am pretty sure DP has explained how he does(did this) Somewhere
edit here read the thread its about the problam you are facing(i think)
aka BMWST?
advNZer? screwed with this post 12-31-2012 at 01:14 AM
advNZer? is offline   Reply With Quote
Old 12-31-2012, 04:32 AM   #6460
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
So you're willing to judge the Montana based on one person's problems with BaseCamp? You don't need to be a "Rocket Doctor" to use the Montana. It's an awesome device, with a learning curve, but once you've used it for a while you will never go back to an antique gps.
Old 12-31-2012, 06:17 AM   #6461
mass-klr
mass-klr's Avatar
Oddometer: 179
Originally Posted by mass-klr View Post
It was as if it could not keep up. I was turning left on 6th and it was still stuck on saying that I should turn on 6th. Not sure if it could not see the satellites? I hope that was the case...
I had it in the Garmin car mount. The speed limit did not show even though I could see it before on the Amps mount where it goes red if I go over the speed limit.
Thanks,
I found the problem yesterday why my Montana was acting to strange and thought I would share.
Problems:
Speed limit did not show in CN maps
While navigating, I turn and that turn's text stays on the screen for another 15 to 30 seconds before showing the next turn.
Answer:
I noticed that the profile I am using for CN also had all of the other maps enabled, 100K, 24K, etc. I disabled the other maps and only left the CN maps enabled and all of the problems above disappeared. Yeah!!!
_____________________________
Leon
'11 KLR650 ... '04 DRZ400S
Paved Roads are just another example of wasted Taxpayer Dollars
mass-klr is offline   Reply With Quote
Old 12-31-2012, 07:18 AM   #6462
Rocky TFS
Rocky TFS's Avatar
Oddometer: 590
Answer:
Many folks do not realize that when they add another map to the SD card or the unit by MapInstall, ALL the maps get enabled again in ALL the profiles!!
Very irritating behavior to someone like me who has individual state 24K maps (free at GPSFileDepot) that I swap in and out depending on the trip.
Rocky TFS is offline   Reply With Quote
Old 12-31-2012, 07:45 AM   #6463
Rocky TFS
Rocky TFS's Avatar
Oddometer: 590
Photos on the 600
I may be a bit slow, but I finally figured out that just because the 600 does not have a camera it doesn't mean that you can't put geotagged photos on it or in BaseCamp.
I have a Panasonic Lumix with GPS that I never enabled because of battery life, so I just tried it. Took some pics with the GPS enabled, popped the camera card into the computer with BaseCamp running, BC recognizes card and the pic, copied the pic to a list, it shows up correctly on the BC map, sent it to the Montana.
Enable the photo viewer icon in a profile, the pics are there, click one, see it, use options menu to show on map, and Lo and Behold, my photo is right there on the topo map where I took it!
Another way to use up a lot of disk space in the computer and the GPSr....
Interesting to note that even if the photo has already been loaded into the computer via a photo editor/organizer, BC makes a copy of it in it's own folder, and even if the photo has GPS info in the EXIF, it has to make a little file to tell itself where to place the photo on the map.
Presumably the Montana does not, and is just reading the EXIF tag.
AND, you can drag any photo on your system, geotagged or not, onto the BC map from your photo editor/organizer, and place it where the pic was taken....(if you can remember.....)
Presumably lots of you already know this, but I'm old and slow, so it took me 10 months.
Old 12-31-2012, 07:57 AM   #6464
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
My experience, and I checked it just the other day when I re-added Metroguide Canada V4, was that since that was the only map I added, and it was in a separate file of its own, MGV4 ended up enabled in all my Profiles, but it didn't change anything else with the existing maps/profiles.
Old 12-31-2012, 09:18 AM   #6465
atlas cached
OX Ambassador
Oddometer: 688
I have repeatedly complained about this to Garmin since the Oregon models were new.
This is a very old issue Garmin refuses to correct.
I suggested they (at minimum) add an option to disable all maps, as most of us only use a map or two in each profile, but may have a dozen or more loaded. Having to go through multiple profiles and manually disabling more than a dozen maps in each profile EVERY TIME I update or add a new map is maddening!
Garmin Refuses to correct this issue for years now...
Times are GMT -7.   It's 12:43 AM.
