Old 12-30-2012, 09:39 PM   #72331
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by blk-betty View Post
What the heck!
Repleced the snapped head pipe with a FMF PowerBomb. After the install and a short ride retorqued the header bolts. Admit I don't know the tq spec but thought they were damn tight.
Rode little over 100 miles today and when bike cooled checked the status of the header as someone mentioned that things may have been too tight without enough flex as a reson the OEM snapped at 6000 miles.
Well the new header was loose, no problem just tighten back up...except one of the bolts is missing.
So....what is the tq spec and why did one vibrate completely out?
I don't know the torque spec ... but if in doubt tighten it up where you had it on the install ... but this time USE LOC TITE! It will stay put.
Old 12-30-2012, 09:42 PM   #72332
TrophyHunter
Oddometer: 2,166
Funny - I found a def for "Murcan" and slang uses 'mercan (American) but PC's Merkin looks a lot more entertaining. I didn't see one listed on their site, thank goodness....
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 12-30-2012, 10:32 PM   #72333
JagLite
JagLite's Avatar
Oddometer: 1,114
Question Loc Tite ???
Loc Tite on the header bolts?
I use anti-seize so I can get them out.
How many use Loc Tite in this application?
And do you use blue or red Loc Tite on the extremely hot exhaust header bolts?
I do use Loc Tite just about everywhere else.
blk-betty - did you put in a new gasket with the new pipe?
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 12-30-2012, 10:43 PM   #72334
BergDonk
BergDonk's Avatar
Oddometer: 3,351
I've used both, but tend to go with Blue Loctite. Don't need it every time as it'll clag up a bit with the residue in there and do the job. Something, Loctite, or antiseize, reduces or eliminates the corrosion and bonding, so both work, but low strength Loctite is good.
Its also possible that the header didn't quite snug up, and after a heating cooling cycle, did, and there was then no tension on the bolts. A new gasket can exacerbate this behaviour.
Heat also weakens Loctite, so if you are trying to pull something apart, especially small screws, some heat can assist by not only expanding things, but weakening the Loctite.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Old 12-31-2012, 12:28 AM   #72335
canoli
human
canoli's Avatar
Oddometer: 1,666
Originally Posted by VooDooDaddy View Post
Thanks for posting, I was looking at the Safari over the IMS, but the truth is, I'll never go that for and thus need the extra range. I appreciate your scientific research.
Scientific
No worries. If I was back in the states I would totally go with the IMS. Adds just the right amount of range and looks right on the bike.
Cheers,
Canoli
canoli is offline   Reply With Quote
Old 12-31-2012, 02:45 AM   #72336
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,127
Am i a traitor ?????
Went out the other day and bought a Yamaha XTZ 660 and just love it
https://picasaweb.google.com/lh/phot...eat=directlink
BUT THERE AINT NO BEATTING THE DR650 FOR PROPER FUN
A friend of mine from the UK was down here in France so we had to go and play !!!! he jumped on my DR250 and i took the 650 ....................next time we'll do it the other way round she's a big old girl in clay mud
http://www.youtube.com/watch?v=-gMOwZ9A6w4
http://www.youtube.com/watch?v=PJfv_lu2Yew
Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 12-31-2012, 03:29 AM   #72337
dljocky
Oddometer: 857
That XTZ 660 is a good looking bike! How does it compare to the DR650?
Phil
dljocky is offline   Reply With Quote
Old 12-31-2012, 05:06 AM   #72338
PHILinFRANCE
Oddometer: 1,127
Cheers dljocky
Haven't off roaded her properly yet , too shinny !!!!! but put it this way "the DRs staying" simple, tough and fits me perfect horses for corses !!
I've bought the Tenere for a planned tour dsown the West Coast of Africa in 2014 so need to spend loads on her yet. I wanted to take the DR but she's a 96 and i fancied something a little newer for the trip, that being said i my not have it in a year !!!
I will be dropping the motor on the DR and doing the 3rd and possibly other gears this year so MAYBE she'll go back to Africa , done Morocco twice on her without a hickup.
Phil
Old 12-31-2012, 06:56 AM   #72339
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,379
Thanks for the suggestions.
I tend to use blue loctite regularly but never used it on exhaust header bolts. I did use a new gasket so I think maybe the intital run didtn't get things hot enough for a proper re-torque. Will pick up some new bolts and will add a little blue locktite.
Any day on a dirt road is a great day
blk-betty is online now   Reply With Quote
Old 12-31-2012, 07:21 AM   #72340
neo1piv014
ADV in training
Oddometer: 619
Originally Posted by Feelers View Post
Most hand warmers use 20-30 watts which is only 1.75 - 2.5 amps. The switched thing in the dash harness would handle that just fine. But, don't also use it for a full jacket liner and pants or generally load it up.
The only thing I have on that switched pair is a 12v cigarette outlet for charging my cell phone. I don't think a 5v USB charger is putting much of a strain on my electrical system, but I can always just not use them both at the same time. If I remember Webbikeworld's DR650 project bike, the electrical system was a bit under powered. I don't know if I would want to run heated grips and heated clothing at the same time anyways. If that pair can handle it, then I'm going to move the grips over to it. The less I have to worry about it, the better.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 12-31-2012, 09:11 AM   #72341
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,984
Happy New Year everyone.
My resolution; RIDE MORE
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 12-31-2012, 10:21 AM   #72342
gbmaz
Power Newb
gbmaz's Avatar
Oddometer: 401
Originally Posted by rusty rocket View Post
happy new year everyone.
My resolution; ride more
+100.
George Marsden
Los Alamos, NM
"You have never really lived until you have done something for someone who can never repay you."
gbmaz is offline   Reply With Quote
Old 12-31-2012, 11:11 AM   #72343
doug s.
Oddometer: 1,313
dr650 engine on ebay
seems a mite expensive, but still cheaper than installing new nova racing 3rd gear set, for you paranoid types...
http://www.ebay.com/itm/130825591884
doug s.
doug s. is offline   Reply With Quote
Old 12-31-2012, 12:08 PM   #72344
Adv Grifter
Oddometer: 6,128
Cheers dljocky
Phil
She's a beaut Phil! In the US we've been proper cheated by Yamaha's reluctance to import this bike. She is a bit heavy though ... but I'd bet a good traveler.
A couple mods I thought about if I ever got hold of one would be:
1. Go with a single exhaust
2. Eliminate one front brake rotor.
Right there you've knocked off about 20 kgs. (+ -) Brake rotors/calipers are super heavy ... as are stock mufflers.
I'm thinking those two Mods would trim the BIG Tenere' down into DR650 territory.
You are one Hell of a Mud rider! I'd have been on my ass in that stuff!
(on my DR anyway) Cheers mate!
Old 12-31-2012, 12:14 PM   #72345
Adv Grifter
Oddometer: 6,128
I believe there is high temp loc tite. Vague memories from A&P school. Don't over torque ... let the Loc tite hold things. Did you use a new Copper ring/washer in there? (I think it's Copper?) re-anneal the old one if you haven't done that. (Heat up to cherry red, let cool ... done)
Times are GMT -7.   It's 07:54 PM.
