Old 12-27-2012, 05:28 AM   #3211
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,524
Gotta subscribe to this thread so I don't lose it!
Did my first welding the other day. Spent three hours watching youtube instructional vids amidst another three hours of practising.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 12-28-2012, 10:50 PM   #3212
Megadeus
Motorcycles are therapy
Megadeus's Avatar
Oddometer: 221
I'm futzing my way through fabricating a few parts for my sidecar project and I have a question for the masses.
When butt welding two 3/4" steel rods end to end, do you grind a flat taper on each end to be welded? Or would you grind a conical taper ?
I can see the ease of welding into a flat tapered void versus a conical. Just pondering the difference.
Megadeus screwed with this post 12-28-2012 at 11:20 PM
Megadeus is offline   Reply With Quote
Old 12-29-2012, 04:51 AM   #3213
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,445
Chisel point is easier. after the first weld double check straight. When done and its still hot, check for straight again.
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6,
There is a seat for everyone.
David R is online now   Reply With Quote
Old 12-29-2012, 04:57 AM   #3214
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,542
Originally Posted by ridepjride View Post
Bolt backed out of the rear sprocket and gouged the swingarm. For a proper repair, can this be built up by welding?
I'm far from an experienced welder but I did this for a buddy of mine on a DRZ
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 12-30-2012, 12:22 AM   #3215
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,420
The Kiwi summer weather has been pretty good for sheltering in the shed & abusing some metal aye? What sort of machine have you got?
I've just been busy TIGging together some pannier racks for Nic's XT, tube is a bit fiddly but it's coming out ok for a learner. Not super pretty but I couldn't break my test welds so I must be doing something right.
This is 5/8 dia .065 wall 4130, the larger dia bits are just black pipe.
Lots to work on in terms of technique I know, but for my first serious tube welding project I'm fairly happy with 'strong & looks ok from a distance'
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz screwed with this post 12-30-2012 at 01:59 AM
clintnz is offline   Reply With Quote
Old 12-30-2012, 07:33 AM   #3216
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 308
nice work
ridepjride screwed with this post 01-02-2013 at 07:42 PM
ridepjride is offline   Reply With Quote
Old 12-30-2012, 04:26 PM   #3217
mikejohn
mikejohn's Avatar
Oddometer: 1,157
Hoping to get a house with a garage this summer, Which Tig welder is good for home use, looking to weld aluminum , 4130 steet and so on, mostly bike related stuff, I'll get a stick welder for mild steel
mikejohn is online now   Reply With Quote
Old 12-30-2012, 05:17 PM   #3218
David R
David R's Avatar
Oddometer: 2,445
Laugh
To tig aluminum you need AC. Mild steel and alloys need DC. Most any DC welder will tig.
get as big as you can afford. :)
David
Old 12-31-2012, 02:17 AM   #3219
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,524
I did it quite a few weeks ago, I needed to repair my trailer once I got the 200 fixed in order to take it out. If I had a spare minute I'd be happier riding not sheltering no matter the weather. Here it's been quite hot and extended dry so some forests are closed due to drought-induced fire risk.
Borrowed innathyzit's arc welder to start, but both he and Topo also offered Tig. I think I need Topo's fancy helmet or a different glass, as I just couldn't see where I was aiming to start. Main project next year is to rebuild my trailer, but I do have a couple of little jobs to do on the 640, such as pannier rails like yours.
Cheers,
Colin
The Stable
Old 12-31-2012, 02:47 AM   #3220
Twin-shocker
Oddometer: 1,673
Unless you have a 3phase power supply, its probably better to be looking at an inverter type 240v AC/DC set. I would suggest 200 amp if you want to work with aluminum, and while a Chinese set will probably be fine for occasional use, its worth paying more for a name brand if you are looking at anything other than occasional use. Remember you will also need argon gas, and that using CK "gas saver" front end torch parts, will mean you use quite a lot less gas.
Old 12-31-2012, 07:04 AM   #3221
Zoolion
Zoolion's Avatar
Oddometer: 58
As stated above, the chinese stuff is ok for occasional use. Miller, Lincoln and ESAB are supported well here in the US and have serviceability and reputation behind them. Also check our Thermal Arc. I have an Arcmaster 185 Inverter that has arc property controls as good as the Miller inverter and was about half the price. The thermal arcs are imported. Mine is Japanese but I think they are made in china now (the exception for chinese machines since they still have a great rep for reliability). The Thermal Arcs are used in a lot of industrial machine controlled welding processes.
Also as stated above, buy the biggest most featured machine you can justify. Used Miller Synchrowave 250 is a great machine for everything, although large and heavy and you need a 60 amp 220v circuit.
The inverter machines are also very efficient. The big transformers like the synchrowave can be pricey to run if you weld a lot.
"I'd hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." - Hunter S. Thompson
Zoolion is online now   Reply With Quote
Old 12-31-2012, 09:39 AM   #3222
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,119
Actually welding Aluminum with DC is more common than many realize. Space-X is building rockets & space craft with aluminum that has been DC Tig welded. Of course they also do some really fancy stuff like friction-stir welding
"I couldn't wait for success, so I went ahead without it."
Strong Bad is online now   Reply With Quote
Old 12-31-2012, 10:05 AM   #3223
mikejohn
mikejohn's Avatar
Oddometer: 1,157
I plan to save and get the good stuff, right now I do my welding where I work ( I'm a machinist). Just hoping to set up a small, very small side business, I want to add a LeBlonde lathe and Sharp/Brigdeport mill
Old 01-01-2013, 08:24 AM   #3224
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
I have a pretty interesting question that my brother-in-law posed to me last night...
He is a gun collector and restores old guns that previous owners have drilled for scopes, etc.
On late 1800 to early 1900 Winchester sporting arms, he has had weldors in his area fill the non-factory holes with TIG. Then he takes the factory blueing down to bare metal and then re-blues the entire gun. The repair cannot be seen in bare metal, but is very evident after blueing. Plus, he says that the filled hole is a harder metal than the proof steel of the rest of the gun.
So, anyone run across this? What would be a proper TIG filler to take the blueing like the rest of the metal?
kirkster70 is offline   Reply With Quote
Old 01-01-2013, 10:04 AM   #3225
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,537
Edit:
I have posted pictures of broken bolts. This one was a little tougher.
88 Suzuki 600 broken exhaust bolt. I welded a few nuts to it with the SP-100 one of the first Lincoln 110 Volt Mig welders.
No joy, they kept twisting off.
Today we attached the front wheel to the fork lift and picked the bike up. I used a tig torch and some 316 stainless filler.
David
Next time use extracting rod, you have a tig, assuming it can do stick too.
Look for X-Tractalloy rod, I use it all the time and the stuff is like pure voodoo magik.
Times are GMT -7.   It's 11:52 AM.
