Old 12-30-2012, 10:37 AM   #8326
woofer2609
woofer2609's Avatar
Oddometer: 723
Originally Posted by pnw View Post
"1996 Canadian spec bike as having a 122.5 main, 42.5 pilot, 2 turns out, along with a few other differences between carbs. Maybe it changed on later models.
I personally found that this equates to good all round performance with 2 turns out on the pilot screw"
Meaning that you stayed with the 122.5/42.5 but only did the two turns? Maybe the 130 was on a different version rather than Canadian spec, I have read so many threads and spec sheets it is hard to keep them straight. Back to work in the garage, the fragility of some of these plastic parts has me a little concerned because the hoses area really fused on.
Thanks.
I have stayed completely stock. I haven't had the carb off because I do not want to screw it up, nor have I adjusted it. The original owner told me the same thing; he hadn't touched it! Not tinkering with it is hard for me) If the jets are as published,they are a great starting point, as the bike runs really well 99% of the time
I am going from a 1996 Yamaha service manual, note that model 4BE3 is the canadian spec.
woofer2609 screwed with this post 12-30-2012 at 11:06 AM
woofer2609 is offline   Reply With Quote
Old 12-30-2012, 03:26 PM   #8327
maverick1
maverick1's Avatar
Oddometer: 31
I find that the engine is screaming and I'm only doing 60mph.
Can someone please let me know what the stock sprocket numbers are so I can determine if my bike is stock or modified?
cheers
maverick1 is offline   Reply With Quote
Old 12-30-2012, 03:37 PM   #8328
KamperBob
Recreation Engineer
KamperBob's Avatar
Oddometer: 254
cheers
15 front, 45 rear
Kamper Bob
(read about Half Pint's adventures at Recreation Engineer)
KamperBob is offline   Reply With Quote
Old 12-30-2012, 06:01 PM   #8329
dav_dman
dav_dman's Avatar
Oddometer: 818
Originally Posted by KamperBob View Post
15 front, 45 rear
lots go to a 16 front , i did, and like it better for the street. takes about 15mins to swap. i've gone with bigger tires now tho so i might go back down to 15
dirt bikes, vstrom, cruiser, etc.
"what hurts, instructs" - ben franklin
dav_dman is offline   Reply With Quote
Old 12-30-2012, 07:27 PM   #8330
KamperBob
Recreation Engineer
KamperBob's Avatar
Oddometer: 254
I'm still stock 15/45 gearing but upsizing the rear from 120 to 140 (/80-18) which means 4.9% longer legs. Instead upsizing from 15 to 16 front would've been 6.7% higher geared. It'll be interesting to see the impact. I may hold off to wring every last mile out of this tire. It's not dead yet.
We'll see if my Murphy Insurance pays off or not. LOL
Kamper Bob
Old 12-31-2012, 06:18 AM   #8331
Travis28715
Travis28715's Avatar
Oddometer: 31
Tom S, shims are .5mm or just a hair under .02”, (0.01968498”), thick.
This from the ANSI site: American National Standard ( ANSI)
Spenard (SBS) has a pretty good assortment in their bins. They don't have the impressive orange vests but are worth a try.
Nominal
Size Decimal
Equiv. Size
Series
Inside
Diameter
Outside
Diameter
Thickness
No. 0 0.060" N 0.0680 0.1250 0.0250
R 0.0680 0.1880 0.0250
W 0.0680 0.2500 0.0250
No. 1 0.073" N 0.0840 0.1560 0.0250
R 0.0840 0.2190 0.0250
W 0.0840 0.2810 0.0320
No. 2 0.086" N 0.0940 0.1880 0.0250
R 0.0940 0.2500 0.0320
W 0.0940 0.3440 0.0320
No. 3 0.099" N 0.1090 0.2190 0.0250
R 0.1090 0.3120 0.0320
W 0.1090 0.4060 0.0400
No. 4 0.112" N 0.1250 0.2500 0.0320
R 0.1250 0.3750 0.0400
W 0.1250 0.4380 0.0400
No. 5 0.125" N 0.1410 0.2810 0.0320
R 0.1410 0.4060 0.0400
W 0.1410 0.5000 0.0400
No. 6 0.138" N 0.1560 0.3120 0.0320
R 0.1560 0.4380 0.0400
W 0.1560 0.5620 0.0400
for those already confused
Travis28715 screwed with this post 12-31-2012 at 09:39 AM
Travis28715 is offline   Reply With Quote
Old 12-31-2012, 07:44 AM   #8332
dav_dman
dav_dman's Avatar
Oddometer: 818
Originally Posted by Travis28715 View Post
this from the ANSI site: American National Standard (ANSI)
Type B Plain Washers
from home depot:
small
med
large
big hole
little hole
skinny
fatter
hey...we are talkin washers, right? not only confused but dont take long before my mind goes elsewhere
Old 12-31-2012, 07:45 AM   #8333
dav_dman
dav_dman's Avatar
Oddometer: 818
dude make UPS buy u a new tire, after that run....
Old 12-31-2012, 07:47 AM   #8334
Speedo66
Transient
Oddometer: 6,691
Sorry 'bout that. In my defense everything looked peachy in preview mode then barfed with unhelpful "Database Error" from AdvRider. I couldn't even see it was making a bunch of dufus posts. So I just nuked those. In AdvRider's defense I now suspect it was barfing on preview not published images on the Flickr side. I'm gonna give it one more try now that I finally think I got a handle on it...
I see they're up now, thanks for re-posting!
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is online now   Reply With Quote
Old 12-31-2012, 07:56 AM   #8335
WayneJ
LFC/CCCCC
WayneJ's Avatar
Oddometer: 5,616
from home depot:
small
med
large
big hole
little hole
skinny
fatter
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
I got a chill standing outside wiggling wieners.. - LadyDraco
There is no odometer when it comes to pie - VACommuter
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 12-31-2012, 08:33 AM   #8336
Speedo66
Transient
Oddometer: 6,691
Anybody offhand know the diameter in mm of the front and rear axles?
Old 12-31-2012, 09:11 AM   #8337
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,207
I didn't measure mine, but since they take 6202 bearings, it has to be 15mm since that is the i.d. of the bearings.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 12-31-2012, 09:20 AM   #8338
Travis28715
Oddometer: 31
PNW wrote: A small diameter hose that runs from a small plastic elbow from the left side of the carb near where the fuel hose attaches to the carb broke off with the tiny plastic nipple in the hose, it must have been very brittle as I didn’t realize that I even bumped it at all. The parts diagram in the manual doesn’t list the function of this hose, maybe a vent? I doubt if the plastic elbow fitting is replaceable, it isn’t listed in the parts diagram. Anyone have any ideas what to do with it?[/SIZE][/FONT]
I believe that to be the overflow hose. Does it come from float bowl area?
Travis28715 screwed with this post 12-31-2012 at 10:45 AM
Old 12-31-2012, 11:24 AM   #8339
Travis28715
Oddometer: 31
Fmf pc-4 + qc
I have a Powercore 4 pipe on my bike. It is loud and obnoxious for my needs of a little 225 backwoods runner. Has anyone inserted the quiet core and could give me some performance observation?
Old 12-31-2012, 11:50 AM   #8340
TwilightZone
Oddometer: 2,954
>"I have a Powercore 4 pipe on my bike. "
I have installed the Powercore noise-reduction spark arrestor on a WR250R, it quiets down pretty nicely.
About $34 bucks I think.
(Note: This was installed in a Q4 pipe, had to bend the spark arrestor screen to get it to go in.)
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Times are GMT -7.   It's 11:51 PM.
