Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 12-31-2012, 09:19 AM   #57241
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,841
Originally Posted by mouthfulloflake View Post
guess I better head home then
wife said the central heat is out again
guess ill be under the house today
I hate this house
][/B]
Just call your landlord and have....................... oh wait, you OWN your house.
Guess what doofus, nobody reads your lame blog.
Old 12-31-2012, 09:22 AM   #57242
DRZ Charlie
Old & beat up
DRZ Charlie's Avatar
Oddometer: 11,084
Heck Albie, if it's a light bulb out on a ceiling fan I call the office to have it replaced. Though I have had to do the ones in lamps all by myself....
Ride, Crash, Visit the ER, Get a splint, Recuperate, Assess your mistakes, Repair Motorcycle, Gather courage to ride again, Ride, Rinse & Repeat
My SPOT - No tracks = not riding | Mapsource Tutorial | Rides
DRZ Charlie is online now   Reply With Quote
Old 12-31-2012, 09:50 AM   #57243
Scribe
£Bob£
Scribe's Avatar
Oddometer: 4,489
Originally Posted by JaiDee View Post
Same here on Mt. Seq. with rain since early a.m. Trees are starting to ice and get longish icicles. If it gets colder this could get really nasty.
-JD
Where are you at on Mt. Sequoia? I'm on Fletcher Avenue. If you are any higher up you probably ride right by my house to get to yours.
Grammar: It's the difference between knowing your shit, and knowing you're shit.
Scribe is offline   Reply With Quote
Old 12-31-2012, 10:03 AM   #57244
mdawg12
Old and Slow
mdawg12's Avatar
Oddometer: 509
Hell yeah! I will admit, after eating dust again yesterday, I'm happy that we're getting some very much needed rain. Just hope it doesn't all ice up.
There was dust???
‎"May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds. May your rivers flow without end."
- Edward Abbey (1927-1989), American author, from "Desert Solitaire" (1968)
mdawg12 is offline   Reply With Quote
Old 12-31-2012, 10:05 AM   #57245
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 11,254
ok just got back from under the house.
when heater is turned on this happens.
inducer fan starts blow
hot surface ignitor begins to glow
after 20 seconds, ignitor is turned off, and it starts over again.
no gas flow I guess?
there is a pressure valve diaphragm thingy on the side of unit with hose going to inducer fan, could this control the gas output valve?
I guess Ill verify gas flow into the gas valve first, then go from there.
any ideas are appreciated.
"A little inaccuracy sometimes saves a ton of explanation."
- H. H. Munro (Saki) (1870-1916)
mouthfulloflake is offline   Reply With Quote
Old 12-31-2012, 10:11 AM   #57246
wayno
wayno's Avatar
Oddometer: 4,812
Thermocoupler????
RIDE SAFE
wayno screwed with this post 12-31-2012 at 11:42 AM
wayno is offline   Reply With Quote
Old 12-31-2012, 10:18 AM   #57247
DRZ Charlie
Old & beat up
Oddometer: 11,084
Old 12-31-2012, 10:21 AM   #57248
Spanky15
Dirt Slider
Spanky15's Avatar
Oddometer: 516
Yeah...if it's a newer unit ...flame detector....or what Wayno and Charlie suggest...! No signal to main valve.
Spanky XV
'08 KLR 650 Stock...mostly.
'73 360 Astro
'82 XR-500R
'74 Ossa
...all Flattrackers
Spanky15 is offline   Reply With Quote
Old 12-31-2012, 10:21 AM   #57249
mdawg12
Old and Slow
mdawg12's Avatar
Oddometer: 509
Originally Posted by DRZ Charlie View Post
What Wayno said
Ditto!
Old 12-31-2012, 10:46 AM   #57250
mouthfulloflake
Not afraid
Oddometer: 11,254
hot surface ignitor and thermo couple were rplaced last year.
the thermo couple senses flame and lets the gas keep flowing.
its never opening the gas on start up to allow any flame.
I just cleaned the NPC and verified with a meter, inducer flow switches it.
its a 10 year old unit, im looking up the honeywell control unit, to try and see whats out of the loop here.
Old 12-31-2012, 10:53 AM   #57251
Valentino Magoo
Like a speeding slug
Valentino Magoo's Avatar
Oddometer: 1,728
I suggest starting with cheapest, most easily broken part. My guess is the sensor for the ignitor. If it says the ignitor surface is not hot enough, it won't open the gas valve. Our commercial boiler at the farm gets a new sensor about every-other-year due to it's failure. Same symptom. I'd crawl under the house with you, but I didn't stay at a Holiday Inn last night.
12 WR 250R
05 Burgman 650
00 HD softtail
Valentino Magoo is offline   Reply With Quote
Old 12-31-2012, 10:57 AM   #57252
mouthfulloflake
Not afraid
Oddometer: 11,254
maybe I am not understanding what sensor you are referring to?
there are only 2 things in the burner area
a hot surface ignition ( glowey thing)
and a thermocouple ( flame sensor)
from my understanding, the control module opens gas valve for 4 seconds or so, if the flame sensor detects flame, then it leaves the valve open until the thermostat is satisfied.
In my situation, the valve is never opening.
glowey thing glows, then it goes out.
no flame
Old 12-31-2012, 11:04 AM   #57253
Spanky15
Dirt Slider
Spanky15's Avatar
Oddometer: 516
I might swap thermocouple first... Do you get a primary flame....like a pilot flame...then the main in normal operation?
Spanky XV
'73 360 Astro
'82 XR-500R
'74 Ossa
...all Flattrackers
Old 12-31-2012, 11:12 AM   #57254
terrascout
Oddometer: 1,357
LOL, I was like what the hell, why's this guy driving like 1 MPH.
Well everyone else keeps telling me to "slow down" so I thought I would try it. I slowed down enough to wave and point out the odd fellow on the motorcycle with "Eat Me" across the brim of his helmet to my passenger.
terrascout is offline   Reply With Quote
Old 12-31-2012, 11:22 AM   #57255
GMJinARK
GMJinARK's Avatar
Oddometer: 23
Originally Posted by tokyoklahoma View Post
I've got some roofing and sheet-rock work that I need done.
Anybody know of someone good and honest?
Hey Tokyo,
If you find someone willing to do roof repairs, let me know. Everyone I have contacted claims to be too busy for repairs (or just flat turns away that type of business). However, they have plenty of time to replace my entire roof (to the tune of $10k).
GMJinARK is offline   Reply With Quote
Times are GMT -7.   It's 12:44 PM.
