12-31-2012, 08:19 AM
#16 | |
Old guy
Oddometer: 1,362
nut. There is a picture on that website. The tapped wire only ends up with a very small hole in the insulation.
"What could possibly go wrong? " The Jerk2012 TE 250 2010 F 650 GS 1983 R 80 G/S |
12-31-2012, 08:20 AM
#17 | |
Oddometer: 2,439
I always strip a short, quarter-inch section of tapped wire, wrap the tapping wire around and solder the junction. Yes, it takes a bit more time - but now it is off-season anyway, no? Time for bike farkling.I have had my share of IDC (insulation displacement connector) failures. OTOH, I have never had a solder splice fail on me, even if sloppily made. And you would not believe the amount of add-on wiring on my bikes - I am a hopeless gadget freak. Good connections are a must. Robert.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT -->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour -->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour |
12-31-2012, 08:49 AM
#18 |
GS"eh" rider
Oddometer: 352
Posi taps look very practical in that they are very invasive. I would stick apply electrical tape around to secured the nut( that motorbike/hockey tape...ya know what I mean)
"Dear MCGuyver enclosed is a paperclip an elastic band and a toothpick, please save my dog" |
12-31-2012, 10:07 AM
#19 | |
"Cool" Aid!
Oddometer: 41,488
, and do it on the parking lamp or the running lamp for the tail light.Jim
12-31-2012, 10:09 AM
#20 | |
"Cool" Aid!
Oddometer: 41,488
Jim
12-31-2012, 10:44 AM
#21 | |
Oddometer: 2,439
12-31-2012, 11:02 AM
#22 |
Oddometer: 41
when using the tailight as 'turn on', should I tap into wire at plug right before bulb? Also, do I need to have voltmeter out to make sure which wire is positive? Or, is one color always the 'hot'?
12-31-2012, 11:11 AM
#23 |
Old guy
Oddometer: 1,362
![]() A voltmeter would be a good idea. You can tap into the wire at any point. I don't have my 1150 anymore but I believe all the grounds are brown so you wouldn't want one of those.
"What could possibly go wrong? " The Jerk2012 TE 250 2010 F 650 GS 1983 R 80 G/S JRP screwed with this post 12-31-2012 at 11:17 AM |
01-01-2013, 02:45 AM
#24 |
Oddometer: 21,547
This is the wire I use for my switched power relays, it won't be live until the idiot light on the dash is off.
01-01-2013, 02:52 AM
#25 |
Oddometer: 21,547
Tap into it somewhere you can reach and easily work on, should you have to. Tapping into a tail light wire near a socket won't make a measurable difference in volts/current going to the relay, so why force yourself to work in the tiny space with very little wire slack and no chances to correct an error?
01-01-2013, 06:16 AM
#26 |
Oddometer: 41
Done. I used the tail light and everything works great. I removed factory spade connector at tailight, wired 'turn on' to tail light wire and installed new spade connector. Topped off with shrink tape. I used a posi-tap for tapping into high beam for my overriding dimmer from ADVmonster. Very pleased with the dimmable model 60s.
