Old 12-31-2012, 11:00 AM   #16
Boats313
Boats313's Avatar
Oddometer: 35
Originally Posted by guiri View Post
Dirt is not a problem as I will ride mostly on the street and like you said, I could always clean it.
Hi Viz it is. IF available in whatever jacket I find 'cause the size is going to be a problem.
Any suggestions for a waterproof jacket (preferably one that is well vented so I can use it all year round)
that accomodates huges guts and HOPEFULLY that doesn't cost too much?
Unfortunately, I have found that a well ventilated jacket is not going to be water proof. Unless they start using drysuit style zippers, every vent is a place for water to enter. I bought what was called a water proof jacket and it is for a light shower. But for my normal 40 minute ride to work in a heavy rain it leaks at all of the "waterproof" zippers. The fabric itself is fine. In a crosswind it is even worse, gets right under the flap on the main zipper, runs down the front and into my pants. And in the heat it is just a little too warm.
My next jacket will be 2 jackets, one for the nice summer weather and another for the winter. Or I'll just add a cheaper rain jacket to the top as needed.
Boats313 is offline   Reply With Quote
Old 12-31-2012, 11:02 AM   #17
guiri OP
Looking for a good home..
guiri's Avatar
Oddometer: 1,141
Yeah, I SHOULD get a white helmet as it's hot as hell in the summer here in NC but dammit, I just can't stand the white color. I may have to draw the line there.
However, the helmet I'm getting has an led light in the back so that should help.
guiri is offline   Reply With Quote
Old 12-31-2012, 11:09 AM   #18
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,900
Originally Posted by Mudcat View Post
I think it’s a personnel choice, hi viz might be marginally safer. I like black or gray myself
Me too. HV gets dirty fast, and cleans poorly. I am not convinced it helps all that much. People cut off fire engines all the time, and they are hardly low viz.
Jim
Old 12-31-2012, 11:13 AM   #19
JimVonBaden
"Cool" Aid!
Oddometer: 52,900
I've had both. The black and white are not all that different in heat transfer. Remember there is an inch of high density insulation so any absorbed heat from the color will still be blocked. Better is to find one with good ventilation. Your head is 98.6° and most heat comes out of your head.
Jim
Old 12-31-2012, 11:17 AM   #20
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
Jim
Yeah.
If you're running any kind of windscreen they can't see anything other than that and your headlight anyway. If they're behind me, I really don't care because I'm probably pulling away from them, anyway.
If you want to really increase your visibility, get some good, bright auxiliary lights.
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Old 12-31-2012, 11:57 AM   #21
acejones
acejones's Avatar
Oddometer: 5,217
Originally Posted by Xeraux View Post
Yeah.
Can't argue with lights for sure. I'm still wearing Hi Via and white. I want every advantage I can get even if it is perceived.
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 12-31-2012, 12:12 PM   #22
guiri OP
guiri's Avatar
Oddometer: 1,141
THINKING it's better for you is not a bad thing either.
Auxiliary lights ARE coming up and the bike I got has some kind of lights
on the luggage which will most likely be on all the time
so that should be good.
How dirty does the hi viz get on regular roads? Exhaust, dust and what not?
The last thing I need is something getting filthy and really showing up
AND being hard to clean.
Not only am I lazy and a procrastinating mofo, if it's hard to clean, it probably
won't even happen.
For a clean look, I would assume a grey or brown would be the best color?
My bike is grey or silver by the way. Helmet is black and although black is
slimming, I don't there's a black out there that'll make ME look slim and I'm not
all that big on black stuff anyway.
Old 12-31-2012, 12:38 PM   #23
JimVonBaden
"Cool" Aid!
Oddometer: 52,900
Road grime and time.
Jim
Old 12-31-2012, 12:44 PM   #24
guiri OP
guiri's Avatar
Oddometer: 1,141
Damn, that's pretty crummy looking.
So, how do you clean it and how long did it take to get that dirty
and is this on regular paved roads?
Defeats the hell outta the Hi Viz when it's like that, huh?
Old 12-31-2012, 12:48 PM   #25
JimVonBaden
"Cool" Aid!
Oddometer: 52,900
Not mine, nor riding gear, but I have seen some similar. It can be partly cleaned, but over time they look similar.
Jim
Old 12-31-2012, 12:58 PM   #26
guiri OP
guiri's Avatar
Oddometer: 1,141
Boo, boo, that sucks.
So, black, grey or brown if I don't want to wash or clean'em.
Are these even washable or do they lose their waterproof properties?
Old 12-31-2012, 01:03 PM   #27
abnslr
rides a motorcycle
Oddometer: 228
Looks like the old-school nomex firefighters' turnout gear -- after a few fires...
Jim
abnslr is offline   Reply With Quote
Old 12-31-2012, 01:19 PM   #28
p0diabl0
Oddometer: 561
I got a Tourmaster Transition 2 this black friday from cycle gear and have ran it through the rain a couple of times now - no issues. It's main thing is having vent scoops which open via zippers, but the zippers are protected when closed. Here's hoping it stays waterproof.
p0diabl0 is online now   Reply With Quote
Old 12-31-2012, 01:43 PM   #29
NoVa Rider
Oddometer: 2,870
I'm a hi-viz fan, and wear a yellow helmet. But truth be told, the helmet is the highest point on the bike, so from a visibility perspective, that's what I'm concerned with most. And more important than that, especially for night riding, are reflective panels on the suit, and I use some red reflective tape on the helmet. Really helps to be seen at night.
NoVa Rider is offline   Reply With Quote
Old 12-31-2012, 02:14 PM   #30
acejones
acejones's Avatar
Oddometer: 5,217
I found the easiest way to clean this stuff is take it in the shower with a nylon brush and detergeant of choice. Unless you're a pig, it doesn't get that dirty.
Times are GMT -7.   It's 12:46 AM.
