Old 05-05-2012, 01:50 AM   #106
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,127
Originally Posted by gefr View Post
I read:
14,2V no lights
13,8V lights on
13,2V heated grips
12,4V fan on but it is not stable and plunges occasionally under 12V.
The stock battery can't even start the engine when voltage drops below 12.4V
charge it up for a while, it gets to 12.7 and the engine fires up perfectly. There is a low voltage cut-off or something like that in the electronic circuitry but i might be wrong.
GO !!! Berglund brothers #148 #149
GO !!! CS Santosh #59
Vicks is offline   Reply With Quote
Old 05-16-2012, 02:52 AM   #107
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,873
The pump is operating flawlessly.
I had the chance to check my transformed chinese 3,0bar fuel pump and found a small leak in its casing. This led to pressure drop which resulted to engine starvation. So with careful trimming the universal 3.0bar chinese fuel pump suits our needs. It doesn't have to be trimmed to the extent Vicks's photos show, so holes on the casing could be avoided. I will have a go with a 3,5bar fuel pump, but the project Vicks started is doable and succesful.
Cheers.
gefr screwed with this post 09-04-2012 at 06:10 PM
gefr is online now   Reply With Quote
Old 07-13-2012, 06:44 AM   #108
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,127
I had the chance to check my transformed chinese 3,0bar fuel pump and found a small leak in its casing. This led to pressure drop which resulted to engine starvation. So with careful trimming the universal 3.0bar chinese fuel pump suits our needs. It doesn't have to be trimmed to the extent Vicks's photos show, so holes on the casing could be avoided. I will give have a go with a 3,5bar fuel pump, but the project Vicks started is doable and succesful.
Cheers.
congrats Gefr.
could you post some pics of the 3.0Bar and teh 3.5Bar fuel pump you are talking about
cheers
Old 09-04-2012, 06:12 PM   #109
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,873
No need to really.
The picture is exactly the same with your fuel pump. Both 3,0bar and 3,5bar pumps look the same with your fuel pump.
Cheers
Old 12-22-2012, 03:06 AM   #110
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,873
I finally have a product ready to sell!
Mission accomplished. The chinese fuel pump after some surgery ends up a nice fit in place of the original fuel pump. Rated at 3,5 bar at 90lit/h, pressure and quantity is going to be adequate at all times.
The elastic base which holds the fuel pump from turning when it starts and stops. The lower side of the fuel pump needs to fit to the rubber cavities. So some surgery was needed.
Modified Chinese fuel pump
Original fuel pump for comparison
Upper side of the pump had some extra plastic around the connections that needs removing, in order to fit in the cage.
The shape of the original fuel pump is slightly different to the Chinese imitation so the shorter supporting cage is not functional. The outer larger cage needs some spacers in order to reach the aluminum pump nest, so longer bolts and nuts rectify that imperfection.
So a complete set includes 2 longer bolts 1.5cm M5, 2 nuts and and an o-ring 60X3 viton since it usually gets damaged. I also include a small o-ring at the intake of the pump and an alouminum spacer to be installed at the bottom of the bronze pipe.
For more go to:
http://advrider.com/forums/showthread.php?t=850343
Cheers
gefr screwed with this post 03-10-2014 at 10:08 PM
Old 12-30-2012, 07:56 PM   #111
srad600
srad600's Avatar
Oddometer: 649
Wow, looks like you two have been doing some serious research into these fuel pumps. My 990 is starting to act up and I'm betting the fuel filters are clogged causing the issue. I'm curious if you guys are using the stock filters with the aftermarket pumps, or aftermarket filters or homemade filters (I saw somewhere someone cobbled one together)? Thx.
srad600 is offline   Reply With Quote
Old 12-30-2012, 09:42 PM   #112
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,127
Fot the moment there are no alternative (after market) options available for the white sock filter.
I used the stock KTM filters (both sock and the roung paper filter) alongwith non-KTM fuel pump unit. Homemade filters using different filter material have also worked.
Old 12-31-2012, 02:08 AM   #113
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,873
O.K. guys, here is the situation.
I have ordered a batch of aftermarket filters to a Chinese filter manufacturer. The filters have been tested and there are two preproduction sets installed right now and operating satisfactorily. However I do not have the production batch delivered yet. So I am waiting and will let you know as soon as I receive the filters. Price will be reasonable.
Cheers and happy new year.
Old 12-31-2012, 02:53 AM   #114
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,118
I'm in need of them now :) any idea about the waiting time still required? I'll run an external fine filter but will need the in tank one. Want to make a large one and put the whole pump in it but seems hard to find that filter material in that size!
Perhaps anyone knows what material i could use to make the pre-filter's?
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 12-31-2012, 04:41 PM   #115
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,127
good new Gefr. and thanks for all your efforts
i'm definitely interested in the aftermarket filter.
Old 12-31-2012, 04:49 PM   #116
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,964
So is anyone still interested in a EXTERNAL filter/ pump/ regulator setup for the 990 ADV/SD?
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 12-31-2012, 04:59 PM   #117
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 3,012
YES! Not necessarily for the 990, but definitely to convert my SE to EFI!
Yardstick is online now   Reply With Quote
Old 12-31-2012, 05:15 PM   #118
Hootowl
Oddometer: 1,254
so is anyone still interested in a external filter/ pump/ regulator setup for the 990 adv/sd?
yes!!
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 12-31-2012, 05:29 PM   #119
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,939
At a reasonable cost yep (say $200-$300).
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 12-31-2012, 06:03 PM   #120
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,964
Sounds good, I'll keep the project on the board and continue R&D work in January. I might need to add some nobbies to the SD if we get more snow.
Times are GMT -7.   It's 10:11 PM.
