Old 12-31-2012, 05:20 PM   #8
worwig
Oddometer: 1,304
Originally Posted by Leodis41 View Post
If the camera gear is warm inside and out you will not get condensation forming when you remove it from the top box and case.
A lot of people appear to have this reversed.
A warm camera into a cold environment means it is LESS likely to fog up.
Of course the cold camera placed into the warm case might fog.
If you really need to do something, and I don't think you do, just put a light bulb in there and wire it to the ignition switch. A 35 watt bulb on a big METAL socket (to spread the heat) may do what you want. Anything on a small 9 volt battery will only give you heat for a few minutes.
Hog mountain Weather
worwig is offline   Reply With Quote
Times are GMT -7.   It's 12:15 AM.
