Old 12-26-2012, 09:01 PM   #3766
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 353
Originally Posted by YetiGS View Post
That connection is usually connected to the smog stuff. If you or the previous owner de-smogged it, there's nothing connected to it. Some people connect their gas cap vent to it...
From what I've been told the XCR-W never came with smogg equipment which is why I had to get it titled and etc. so did it just come from factory not connected? Anyway so that hose really has no importance at all except if I hook up the coolant recovery kit? I'm unsure if I ordered the Moose Racing or C.R.T. coolant recovery kit and KTMcyclehut has proved me right once again that they are the slowest site ever to order from......If only Motorcyclesuperstore.com carried all parts for KTM's.
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450 (260 hrs)
antpatterson is offline   Reply With Quote
Old 12-28-2012, 08:33 AM   #3767
Foot dragger
beat up ex flat tracker
Foot dragger's Avatar
Oddometer: 6,926
A friend swears by Munn Racing for all his KTM parts,they have it in stock and they ship quick,thats what Ive heard but havent tried em yet myself.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 12-28-2012, 08:36 AM   #3768
Foot dragger
Oddometer: 6,926
Originally Posted by treestrom View Post
Hi, Folks
I just finished reading the entire thread and a big thanks to everybody for all the great info!
I'm in the process of removing the valve cover and tranny vent from the carb and routing to the top of the frame and have read were there is and inline filter or vent?
Can someone clear this up, a pic or part # would be great.
Thanks in advance for your help
RH
Many people leave those vents just as they are from the factory,mine seems to have no problem with stock hose routing. On my DR650 I stuck the mini filter on the crankcase vent,looks like a little K&N filter.
Old 12-28-2012, 08:56 AM   #3769
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,258
Hi, Folks
RH
Here is the vent in my airbox.
-Scott-
Semper Fi
'04 BMW R1150GSA, '08 KTM 450EXC-R, '04 KTM 625 SXC
No Pride and Even Less Sense - A Ride Report
YetiGS is offline   Reply With Quote
Old 12-28-2012, 10:04 AM   #3770
trailjammer
trailjammer's Avatar
Oddometer: 191
I ordered mine directly from RLR Products. rlrproducts dot com, the maker of that particluar kit. It arrived quickly. KTMcyclehut has taken awhile to get before, too.
TRAILJAMMER DESIGNS -KTM PROTECTION! www.facebook.com/trailjammer408
trailjammer screwed with this post 12-28-2012 at 10:04 AM Reason: mispelling
trailjammer is offline   Reply With Quote
Old 12-28-2012, 02:43 PM   #3771
wvridgerider
wvridgerider's Avatar
Oddometer: 354
Originally Posted by WVa Dualsport View Post
If we get enough cold weather, sure. I've ridden sleds on Deep Creek years ago.
If it freezes let us know. That would be a fun trip. My brother has a house there.
wvridgerider is offline   Reply With Quote
Old 12-28-2012, 07:24 PM   #3772
antpatterson
XR650L_High_Runner
Oddometer: 353
Figured I'd give the forum some color as pictures of the lovely KTM's are scarce latetly (I love seeing others bikes). Appreciate the help guys and the websites suggested are now book marked for future orders.
Image and video hosting by TinyPic
XR80r
Old 12-30-2012, 11:59 AM   #3773
biopig
biopig's Avatar
Oddometer: 26
Ktm 530 using oil
My 09 530 with 140hrs started using 2 to 3oz every 2 to 3 hrs of hard riding. I decided it was time for rings and valve stem seals. The only thing found on tear down was some buildup on piston under intake valves, the seals on these seemed a little loose. Would this be an indication that my intake seals where infact leaking? This is my first time this far into a motor, so bear with me.
Heres what the intake valves looked like.
What's the best method for cleaning the valves and head. I'm guessing I need to stay away from anything abrasive. Do I need to do anything special when installing my new rings a far as oiling rings and cylinder wall. I'm also looking for break-in advice, I've read a little about the Motoman procedure. Thanks for your help
biopig is offline   Reply With Quote
Old 01-01-2013, 07:52 AM   #3774
Foot dragger
Oddometer: 6,926
Maybe soaking the valves in some sort of super cleaner would soften the buildup. That looks about normal I think for an engine with those hours on it. Ned may chime in and he knows whole bunches more then most of us about these engines. (2 to 3 oz's isnt much)
Happy New Years!
This has been a very helpful thread for us newish 530 owners.
Old 01-01-2013, 08:40 AM   #3775
neduro OP
Tuareg 2013
neduro's Avatar
Oddometer: 11,354
We use a parts washer, and don't get abrasive. Soak, wipe and scrub (nothing harder than scotchbrite) and repeat. If you're worried about what you're doing to clean, don't do it, it'll look pretty similar to how it does now an hour after it goes together.
Right on for digging in and getting it done.
For Sale: FJ60, or Defender 90,
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 01-01-2013, 08:42 AM   #3776
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 1,702
I use a Harbor Freight Ultrasonic cleaner filled with Simple Green. You have to run it through quite a few cycles over a day or so but the valves will eventually come out looking like new with no need to scrub them with anything. You can get the cleaner on sale quite often, look for their coupons online.
Valves after 200 hrs
And after a bath in the Harbor Freight ultrasonic cleaner. You don't want to use a wire brush since you can damage the factory applied coating on the valves, the ultrasonic cleaner does a great job and no touching/scrubbing necessary.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy screwed with this post 01-01-2013 at 09:12 AM
Hodakaguy is offline   Reply With Quote
Old 01-01-2013, 08:49 AM   #3777
biopig
biopig's Avatar
Oddometer: 26
Thanks for the advice guy's. I'll get things cleaned up and back together as soon as the kids get back to school and my parts come in. I'll keep everybody posted on the results. Thanks again
Old 01-01-2013, 08:51 AM   #3778
biopig
biopig's Avatar
Oddometer: 26
Hodakaguy
I'll have to check that out, there's an HF store not far from me. Thanks
Old 01-01-2013, 10:16 AM   #3779
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,258
My wife has an ultrasonic jewelry cleaner I've used for small parts a couple of times. I just make sure she's going to be out for a while....
-Scott-
Semper Fi
Old 01-01-2013, 11:41 AM   #3780
NAVIGATOR
Wanderer
NAVIGATOR's Avatar
Oddometer: 1,646
Happy New Years!
+ 1 on the helpful thread,
now seeing those valves and piston would it be wise to use some of those gas additives that decarbon engines before tearing the top down? as a preventive action
NAVIGATOR is online now   Reply With Quote
Times are GMT -7.   It's 05:34 PM.
