Old 01-01-2013, 10:12 AM   #6751
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 903
clean/new injector and set tps voltage
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 01-01-2013, 11:44 AM   #6752
777
Oddometer: 90
To clean the injector, can I use injector fluid as used for cars that you add to the petrol, TPS reset is the 10 min udkes reset?
777 is offline   Reply With Quote
Old 01-01-2013, 12:30 PM   #6753
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,003
Happy New Year everyone!!!!
If anyone is looking for a set of RR EV0 1 tanks, drop me a PM, Just the tanks.
I figure someone might be looking for a cheaper way to have these tanks on their bike and save a little money at the same time. You can buy the fuel tank adapter fitting on the RR UK site separately, the rest is fuel lines and a main mounting stud(threaded rod).
Just say'IN
crankshaft is offline   Reply With Quote
Old 01-01-2013, 12:45 PM   #6754
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,768
+1 on the TPS. I don't know how it's set on these bikes but on my carb'ed 950 it ran like crap if the TPS was off.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 01-01-2013, 01:51 PM   #6755
Woundflatout
Woundflatout's Avatar
Oddometer: 476
Yup. What are you asking?
Jason Slutsky
PROUD TO BE RIFF RAFF
'09 Husaberg FE570
Rallymoto #159
Woundflatout is offline   Reply With Quote
Old 01-01-2013, 02:31 PM   #6756
kanur
cu new er
kanur's Avatar
Oddometer: 713
PM sent on Tanks, will they fit an 09?
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is online now   Reply With Quote
Old 01-01-2013, 02:42 PM   #6757
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,661
08-11. All the same. The 2012 are different.. the evo 2 was designed to fit the 12 and the 08-11.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-01-2013, 04:39 PM   #6758
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,024
Thanks,
It's got a new fuel pump,
the TPS is correct,
I have tried the akro map.
Does the injector need to be cleaned in a ultra sound cleaner ?
Anyone have the part # for a new injector ?
Max
Da oggi la strada
senza limiti
MAXVERT is online now   Reply With Quote
Old 01-01-2013, 04:45 PM   #6759
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,661
Originally Posted by MAXVERT View Post
Thanks,
the TPS is correct,
Max
You have to actuate the injector. this video will give you an idea.
http://youtu.be/7aT4S1lIBAY
Old 01-01-2013, 05:21 PM   #6760
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 903
ultrasonic is really the only to get it really clean. you can blow out some crap with a carb cleaner filled tube under pressure but the vibs really clean it.
Thanks,
the TPS is correct,
Max
Ride the DEZ
76 CB750
Old 01-01-2013, 05:37 PM   #6761
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 264
Rally Raid Evo1 Front Fuel Tanks
Anyone in the UK who decides to upgrade to the Evo2 tanks give me a shout if you're thinking of selling your Evo1's
Cheers
Harty
I'll get me coat..............
Harty is offline   Reply With Quote
Old 01-01-2013, 06:41 PM   #6762
Bigbugberg
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 323
Originally Posted by Hoots View Post
Im thinking about the KTM gel seat, as one option for making long hauls a bit more humane ...
Is there someone out there who is using one, and could let me know how much more comfortable they are than the stock bread knife ... ?
I had gel seat on my 990. I would stay away, very far away from the gel seat. The seat holds heat like crazy. It feels like a nuclear reactor on your arse. It's not any more comfortable yet retains heat. Not good in AZ.
Never half-ass anything, always use your full ass
2010 KTM 690 Enduro
2009 KTM 400XCW Plated
Bigbugberg is online now   Reply With Quote
Old 01-01-2013, 07:35 PM   #6763
Hoots
Hoots's Avatar
Oddometer: 1,376
Thanks Bigbugberg ...
Also Maurizio ...
Clearly not a deafening round of applause for the KTM gel seat ...
The heat thing would be a problem here also no rattlesnakes, and our cacti are generally less flamboyant, but otherwise a fair bit in common with Arizona ...
Not much wrong with the 690, other than its awful stock seat no problems when the ride is broken up by tight stuff (standing), but misery over 300km or so of the hard fast dirt roads ...
Will keep sifting through the options for rectification pun not intended ...
Hoots is offline   Reply With Quote
Old 01-02-2013, 10:21 AM   #6764
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,661
What do you think?
I was checking my clearance today and they are loose. So tomorrow I will shim them. On one of my intake rollers it has some funny wear or deposited that I have not seen before.
I have 1700 km to Tbilisi Georgia then I won't be riding for 4 months to rebuild the suspension and whatever else is needed. It seems like my only option would be to get to Georgia then order parts if this should be replaced. Your thoughts?
Old 01-02-2013, 10:28 AM   #6765
yuu
yuu's Avatar
Oddometer: 122
You sig confirms my thought that it's an 08 based on the pic alone. There was a bad run for bearings for the rockers that a lot of the 08 bikes got. Mostly it manifest as score marks, parallel to the rotation axis of the bearing. I don't see any there, but sure doesn't look right. Does the bearing turn freely?
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Times are GMT -7.   It's 01:15 PM.
