Old 01-01-2013, 01:31 PM   #6721
kanur
cu new er
kanur's Avatar
Oddometer: 744
PM sent on Tanks, will they fit an 09?
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is offline   Reply With Quote
Old 01-01-2013, 01:42 PM   #6722
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
08-11. All the same. The 2012 are different.. the evo 2 was designed to fit the 12 and the 08-11.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-01-2013, 03:39 PM   #6723
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
Thanks,
It's got a new fuel pump,
the TPS is correct,
I have tried the akro map.
Does the injector need to be cleaned in a ultra sound cleaner ?
Anyone have the part # for a new injector ?
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 01-01-2013, 03:45 PM   #6724
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Originally Posted by MAXVERT View Post
Thanks,
the TPS is correct,
Max
You have to actuate the injector. this video will give you an idea.
http://youtu.be/7aT4S1lIBAY
Old 01-01-2013, 04:21 PM   #6725
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
ultrasonic is really the only to get it really clean. you can blow out some crap with a carb cleaner filled tube under pressure but the vibs really clean it.
Thanks,
the TPS is correct,
Max
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 01-01-2013, 04:37 PM   #6726
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 267
Rally Raid Evo1 Front Fuel Tanks
Anyone in the UK who decides to upgrade to the Evo2 tanks give me a shout if you're thinking of selling your Evo1's
Cheers
Harty
I'll get me coat..............
Harty is offline   Reply With Quote
Old 01-01-2013, 05:41 PM   #6727
Bigbugberg
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 322
Originally Posted by Hoots View Post
Im thinking about the KTM gel seat, as one option for making long hauls a bit more humane ...
Is there someone out there who is using one, and could let me know how much more comfortable they are than the stock bread knife ... ?
I had gel seat on my 990. I would stay away, very far away from the gel seat. The seat holds heat like crazy. It feels like a nuclear reactor on your arse. It's not any more comfortable yet retains heat. Not good in AZ.
Bigbugberg is online now   Reply With Quote
Old 01-01-2013, 06:35 PM   #6728
Hoots
Hoots's Avatar
Oddometer: 1,516
Thanks Bigbugberg ...
Also Maurizio ...
Clearly not a deafening round of applause for the KTM gel seat ...
The heat thing would be a problem here also no rattlesnakes, and our cacti are generally less flamboyant, but otherwise a fair bit in common with Arizona ...
Not much wrong with the 690, other than its awful stock seat no problems when the ride is broken up by tight stuff (standing), but misery over 300km or so of the hard fast dirt roads ...
Will keep sifting through the options for rectification pun not intended ...
Hoots is online now   Reply With Quote
Old 01-02-2013, 09:21 AM   #6729
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
What do you think?
I was checking my clearance today and they are loose. So tomorrow I will shim them. On one of my intake rollers it has some funny wear or deposited that I have not seen before.
I have 1700 km to Tbilisi Georgia then I won't be riding for 4 months to rebuild the suspension and whatever else is needed. It seems like my only option would be to get to Georgia then order parts if this should be replaced. Your thoughts?
Old 01-02-2013, 09:28 AM   #6730
yuu
yuu's Avatar
Oddometer: 122
You sig confirms my thought that it's an 08 based on the pic alone. There was a bad run for bearings for the rockers that a lot of the 08 bikes got. Mostly it manifest as score marks, parallel to the rotation axis of the bearing. I don't see any there, but sure doesn't look right. Does the bearing turn freely?
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Old 01-02-2013, 09:46 AM   #6731
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Bearing turns freely... and theres no sign of heating. Also, the cam doesn't seem to have abnormal wear.
Old 01-02-2013, 09:51 AM   #6732
yuu
yuu's Avatar
Oddometer: 122
Which is a mercy... I'd be putting a new rocker on my parts list for ASAP replace. In the mean time, if it runs free and (as noted) the cam looks good then you might finish up the trip on it. Rockers are sub $60 (us) so no bad on the budget to replace and very easy as well.
Just keep an ear out for (extra) odd noises
Old 01-02-2013, 11:50 AM   #6733
NovaMoto
Oddometer: 133
Edit: What everyone else said! :)
Is your TPS adjusted properly? All your tuning is in vain if those two sensors are out of whack. I was down a similar road with my 690 recently..
My '08 690 has run like crap for the last year.
I've done all the tuning with TuneECU, tried different maps
etc.
The bike still stalls when off the throttle.
Can anyone recommend a tuner in the Tucson area who can help me
get this bike running right again ?
Max
NovaMoto is offline   Reply With Quote
Old 01-02-2013, 11:57 AM   #6734
yuu
yuu's Avatar
Oddometer: 122
Do you know the condition of your fuel filter? Mine was past done at 4K miles.
Have you cleaned the injector? Related to the fuel filters griming up early, the fuel injectors get an extra early does of nasty.
And just saying you've used TuneECU doesn't really give sufficient insight. It can be a tool for good or evil...
*Edit - looks like my questions were already addressed....
yuu screwed with this post 01-02-2013 at 12:31 PM
Old 01-02-2013, 12:23 PM   #6735
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,277
Thanks,
the TPS is correct,
Max
I'm heading down to Mexico sometime this next year on my 690R.
I have an extra fuel pump already and will purchase an extra injector for that JIC scenario.
The new part # is 75041023144. Cheap @ only $150 bucks for peace of mind.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Times are GMT -7.   It's 09:08 PM.
