12-17-2012, 08:37 AM
#1 |
Restless
Oddometer: 211
Zacatecas, Mexico
I am having carburetor problems and need a good mechanic. My bike is an '09 DR 650 and is currently not running. I am in Zacatecas, Mexico. My email is jrstaedler@gmail.com, and Mexican phone # is 612-153-8582. I don't speak Spanish. The bike was delivered to the Suzuki dealer on Saturday. I was told to return at 9am today (which is did) and was then told that the mechanic may be in later today. If someone knows of a good mechanic in the area, I'd appreciate receiving his contact info.
Jim |
12-18-2012, 12:40 AM
#2 |
Seezer
Oddometer: 349
carb
I used to have that problem too. Fiddle with it till it works and don't know why it works. Finally threw it away and got my hands on a flat slide carb. Problem solved ! buena suerte !
seezer |
12-18-2012, 12:54 AM
#3 |
Oddometer: 21
12-24-2012, 04:46 PM
#4 |
Oddometer: 3,313
What is it doing or not doing, besides not running ? Will it run if you hold the throttle open ?
If I wasn't here, I'd be somewhere else |
12-27-2012, 01:30 AM
#5 |
Oddometer: 21
Thanks for all the reports guys, nice to hear that
12-31-2012, 01:47 PM
#6 |
Oddometer: 56
dr650
for what is worth i am on my 2nd dr650.65k on fist and 45k on 2nd. only trouble ever had was the pickup coil[aka pulse coil].i belive lone rider had 2 go out on his. they are like a light bulb work good when operating but fail when starting. very simple to check. continuty and ohm check. if this is the problem suzy wants 200 plus dollars for part but trere is an alternant part that works for about 40 bucks.i am leaving tomorrow for mexico for 3 weeks, if you need any more info contact my son at bgunn100@yahoo.com. saludos burt
12-31-2012, 01:52 PM
#7 |
Oddometer: 56
dr650
i carry a coil with me and will be in the puerto vallarta,guadalajara area for 2 weeks burt
12-31-2012, 03:37 PM
#8 |
Sand seeker
Oddometer: 1,104
I seen your other thread http://www.advrider.com/forums/showthread.php?t=849711
The mechanic said the spark was good, but this may be worth checking. Look on page 6-20 in manual. IT shows the CDI box and what wires to check on the plug in. PLUG#1: BLACK wire and WHITE wire are listed as the "Power Source coil". This is the coil in the engine to supply power to the Coil connected to the spark plugs. CHeck that there is 0.1-0.2ohm resistance between the 2 wires. The BLUE and GREEN wires are the "Pick-up coil" wires, this reading should be 170-256ohms Would guess a pick up coil is more likely to fail than the CDI. Its happened to a few folks on here. No spark no start. Here is a link to an aftermarket pick up coil that requires cutting and soldering. No affiliation, and there is probably other sources too. http://www.ebay.com/itm/PICK-UP-PULS...9359bb&vxp=mtr
Everybody's on the run |
01-01-2013, 05:31 PM
#9 | |
Restless
Oddometer: 211
Thanks for your advise and offers to help...they're much appreciated. One question for now...is it possible to have spark with a bad pick up coil? Jim |
01-01-2013, 06:16 PM
#10 |
AKA Invisible Dave
Oddometer: 2,464
Hey Jim, did you get the text I sent today about the carb idle screw?
Dave
Why are we stopping? We don't have time for that! http://share.findmespot.com/shared/f...8pP8skl622N3ri |
01-01-2013, 07:26 PM
#11 |
Sand seeker
Oddometer: 1,104
I believe it would be a no spark situation. Never heard of one intermittently working. Good luck, and we will be watching for the final solution....
01-03-2013, 05:43 PM
#12 |
Restless
Oddometer: 211
01-03-2013, 05:44 PM
#13 |
Restless
Oddometer: 211
01-09-2013, 03:16 PM
#14 |
Restless
Oddometer: 211
Problem identified
Although my bike still isn't running, the problem is identified. To save me the work of explaining things in multiple places, please check out my pics and explanation on my RR...http://advrider.com/forums/showthrea...8#post20439568
Again, my thanks go out to all of you for your help and support! |
