12-21-2012, 12:19 PM
#196 |
Are you a Sheeple?
Nice job so far on the wheel!
12-21-2012, 05:19 PM
#197 |
Oddometer: 488
Thanks blaster! So here are a bunch of short clips covering truing, I compiled them into one long one but youtube didn't like it. Also here is my nice new Renazco seat.
![]() This is one method to true a rim/hub, I ask that if you do not like it or know a better way please keep it to yourself unless you are a professional. I have received many anecdotal tales on what to do, or "how I do it". Please post a series to illustrate the error of my ways. PS I also say alright a lot It was supposed to be my edit point but after youtube denied my compiled video I didn't edit them anymore.http://www.youtube.com/watch?v=wEzWCYD6dco http://www.youtube.com/watch?v=OS0meS9YQfk http://www.youtube.com/watch?v=BGlOh3fqzCI http://www.youtube.com/watch?v=SrbI9lI5yTM http://www.youtube.com/watch?v=jpXT39_MTUc http://www.youtube.com/watch?v=9OLWXJDwbuw http://www.youtube.com/watch?v=lycSLBETjsM http://www.youtube.com/watch?v=SWgFTIB2hx0 |
12-29-2012, 06:26 AM
#198 |
Oddometer: 488
I am currently working on the last two parts of the lacing/truing series, they just have to render and I will post them up. In the mean time I have been putting the rear of the bike back together and reworking a few things.
I have been working on my final product for the mud guard, it is a fairly labor intensive process for me as I have to fit, then modify, then re-fit etc... I am now doing the last couple layers of resin to get a nice finish and then I will build a mold of this so that I can make more in the future. ![]() In the mean time I have a flat piece curing that I will use as a license plate bracket (piggy backing off of Erlings idea). I am using a piece of 1 inch acrylic as top piece for the press and after letting it sit over night with about 40lbs on top I pulled the weight and am shining a heat lamp through it to speed up the curing process. I really like having the acrylic sheet to look through.
12-29-2012, 10:47 AM
#199 |
Oddometer: 2,786
Erling |
12-31-2012, 10:58 AM
#200 |
Oddometer: 488
The little things
01-01-2013, 08:39 AM
#201 | |
Oddometer: 2,786
Erling |
01-01-2013, 04:31 PM
#202 |
Oddometer: 488
Mud guard
01-01-2013, 05:00 PM
#203 | |
Oddometer: 2,786
Erling |
01-01-2013, 05:08 PM
#204 |
Oddometer: 488
A royal pain in my
that is what it was. I had to rework this piece 4 times due to that air bubble and my novice mistakes. I am going to run mine and let MotoRiley destroy his and see how they hold up before I make any more. It will be 3 months of testing so I figure that will be a good platform to figure out what works and what doesn't. That and I want to vacuum bag the next one, or come up with a better method to lay it up. I may have to run with many cutouts to eliminate pulling as the resin cured as well as minimize airpockets. I may not use carboard as well, that seemed to add to the problems. I figure if I run 5 sheets and 6-7 in the middle and on the mounting tabs that should be fine and eliminate the need of the cardboard. |
01-01-2013, 06:32 PM
#205 | |
Oddometer: 2,786
Erling |
01-01-2013, 06:37 PM
#206 |
Oddometer: 488
Good idea, now should I just make this clay myself or source something premade?
Further down the rabbit hole I go Alice!
01-01-2013, 07:01 PM
#207 | |
Oddometer: 2,786
![]() . Raid your med place, or scram to your local hobby lobby, and get a gallon for about $7. Mix the epoxy as normal, then degass it....pour it into a big bucket, and slowly stir in the plaster. You need to mix it on the hard side, because as it begins to set, teps elevates, and it begins to run a bit. I mix mine to the consistency of play dough. You want to sand the outside, after its done, and lay up a few layers of either glass or cf, to add strength. I have a few videos floating on photobucket. You can access then through my FB page. Look for " advanced mould making" from Thumpertalk.com. I will do anything to avoid vacuum bagging, thus saving that to the last resort. The above mentioned method will suit you fine.
Erling |
01-02-2013, 03:58 PM
#208 |
Oddometer: 488
Sounds great! I will knock this out when I get back in May for 3 weeks.
Besides that I just wanted to tell everyone if you are looking for anything F800 related definitely look into Renazco Racing! I have dealt with them for my seat and a few other items and gee whiz they go the extra mile!!!! That and their prices haven't been able to be be beat by anyone for the items I am looking at.! Seats http://www.renazco.com/ Parts http://www.renazcoracing.com/ runnin4melife screwed with this post 01-02-2013 at 04:05 PM |
01-02-2013, 04:40 PM
#209 | |
Oddometer: 2,786
Erling |
01-03-2013, 04:26 PM
#210 |
Oddometer: 488
Done for the winter!
Well I finished almost everything on the bike today, I drove it yesterday and wanted to bleed the brakes again and was wondering why it was squirrely on the road, 10-15 PSI in both tires... Fixed that, mounted my mud guard and took it for another quick spin. Everything looks good to go. I have a late arrival coming early next week, a scotts steering damper plus risers from Renazco Racing. This will conclude the bike for now, or at least till late summer.
Oh yeah I am waiting on some new rubber for the new rim... that might not make it in time though (will swap out old TKC to the new rim in that case).
