01-02-2013, 08:23 AM
#6526 |
Oddometer: 925
Atlas,
All I remember is I got it when I got my GPSmap 60C. The copywrite on the bottom of the box says 1999-2002 and I suspect I got it before 2000 so it's pretty old. Maybe I'll load it on the computer and look at my local riding area to see what trails are missing. Jon...
2007 FZ6 Past Bikes.....Check with my Wife.....I've lost count :-) |
01-02-2013, 08:27 AM
#6527 |
Oddometer: 925
Almost forgot....... I do remember that I always had to have the CD's in the CD drive to work with it which was a hassle but from what I remember there were no unlock codes required.
Maybe they are all that way, I have no idea. But it sure was a hassle to have to load the disks (there are three of them) if I wanted to even view the map segments in MapSource. Is the 24K or 100K that way too? Jon...
01-02-2013, 08:43 AM
#6528 | |
OX Ambassador
Oddometer: 404
Current release DVD's install to your HDD and do not require the DVD be inserted each time to function. Oh, and SKIP the Topo 100K. Garbage. This a great 24k map for your area. |
01-02-2013, 08:55 AM
#6529 |
Oddometer: 925
Thanks for the link and info. I'll check it out when I have more time. Need to get some rest (I work nights).
Jon...
01-02-2013, 11:05 AM
#6530 | |
Procrastinators
Oddometer: 5,779
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
01-02-2013, 11:11 AM
#6531 | |
Oddometer: 192
There IS a way to get the data onto the HDD and make Mapsource recognize it: Install Topo USA normally and make sure Mapsource will read the maps from the CD. Create a directory called My Documents-My Garmin-Topo-East, West, and (Alaska/Hawaii, if you want them too) or wherever you like. Copy the CD's image files into those folders as appropriate. Run Regedit, navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Garmin\Mapsource\Produ cts (in XP) or in Win7: HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Garmin\Map source\Products Export a copy of \Products for safety. There will be numbered subfolders there, open each and look at LOC. It will say (drive letter) E:\East...or\West, or \Alaska, etc. Change this value to the appropriate folder you created above, including correct drive letter. (I left Alaska and Hawaii as E: since I'll never use them. (Right click, select Modify, type in new value)) Voila! The next time you run Mapsource it should read maps from the HDD, which is about 10 times faster than the CD. This came from http://forums.groundspeak.com/GC/ind...howtopic=61356 which also shows the alternate method listed below. Here is the other method https://support.garmin.com/support/s...00000000000%7D Now, once you have gotten this all to work properly in Mapsource, Basecamp should also recognize the maps with no further issues. (I said should ) Apparently you can also do this for Basecamp, but I don't have the correct registry key and I still want both Mapsource and Basecamp on the computer anyway.I've been happily using this old Topo for 13 years for 95% of my backcountry exploring and don't see much reason to spend money on new. I simply refuse to use autorouting in the backcountry when my life may be at stake....I insist on creating and vettting the routes or tracks at home with the use of varied resources (such as Google Earth). Hope this helps. Rocky TFS screwed with this post 01-02-2013 at 02:38 PM |
01-02-2013, 11:26 AM
#6532 | |
Oddometer: 192
So it must be MapInstall that re-enables all maps in all profiles when adding maps. ![]() I also later deleted the new map using the above method and none of the profiles changed....(not that that's surprising) |
01-02-2013, 05:14 PM
#6533 |
Oddometer: 539
I Went out on the super Tenere today with the 478 on board
I have been riding around with the Montana in the car. Simply stated; if you have one keep your 276/376/478. I forgot how good everything about the 478 is. I dont think I would ever be happy with the Montana for the Adventure riding I do with our small group. It just doesn't compare. Not even close I will keep the Montana and continue to use it because it is so versatile and i will use it for paved road only rides. And I will continue to hope they can work on the Montana so it can provide the full functionality of the 478. But for our adventure rides the 478 will be on the bike. JB
'12 Yamaha Super Ténéré (Blue) '08 WR250R I refuse to tiptoe through life only to arrive safely at death THE DEAN OF WESTERN ADVENTURE ROUTES Backcountry Byways Journal |
01-02-2013, 06:48 PM
#6534 | |
Procrastinators
Oddometer: 5,779
01-03-2013, 07:31 AM
#6535 |
Hooked Up and Hard Over
Oddometer: 7,440
Wow, this thread has been idle for 12 whole hours !
Frank Reinbold "Every bike I ever had, was the best bike I ever had, when I had it" *2010 FOREVER WEST* NEW ENGLAND AND CANADA OFFROAD F800GS 14 DAY IDAHO ADVENTURE KTM 950 TRANS AM TRAIL WEST TRANS AM TRAIL VID CLIP THE DEAN OF WESTERN ADVENTURE ROUTES |
01-03-2013, 07:59 AM
#6536 |
Oddometer: 1,434
Weird, I know.
I actually got all my routes and tracks loaded yesterday. No issues. I imagine I'm just utilizing 5% of the Montana's capability, but its working so far.
IBA#32778 2008 R1200GSA 2007 G650XChallenge No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..) |
01-03-2013, 09:26 AM
#6537 |
Oddometer: 925
Thanks everyone for all the feedback regarding my older copy of US Topo
I'll play around with it on my days off. Atlas, WOW that's quite a download you linked to. Unzipped it and it installed in BC without any drama. Took a quick look at some of the saved rides in the woods I have been on and the detail looks good.....thanks for pointing me to the map. It will be interesting to see how it compares to the Topo I have on CD. Rocky, Good info on installing the disks on a PC. I have both (PC and Mac) and have pretty much switched over to the Mac now but know all about RegEdit under Windows. I suspect I can accomplish basically the same thing on my Mac. So I appreciate the time you took to write up the info At the very least I can just copy all the CD data into one location as EmmBee suggested which will still be faster than reading from CD. Jon...
01-03-2013, 10:41 AM
#6538 | |
OX Ambassador
Oddometer: 404
atlas cached screwed with this post 01-03-2013 at 01:15 PM |
01-03-2013, 04:21 PM
#6539 |
Oddometer: 192
Oddball behavior with Custom POI files
I've been playing with custom POI files after reading Post # 1935-1938 way back in January '12 from DVWalker.
Several of them went well, then I started seeing this behavior: (posted on the Garmin POILoader forum) I have created a half dozen *.gpi files with POILoader from *csv or *gpx files with a custom bitmap for each. When I look for them in "Extras" on the Montana, they appear as originally named along with 6 instances of "Garmin", which has a single POI named "Poi" right at my house. This POI is NOT in any of the original files, it's being created during the conversion to *gpi process. I'm converting into a HDD folder, the GPS is not connected, so where is POI Loader getting that lat/long from? I use special directories for POILoader data, only including one bitmap and one *.csv or *.gpx file at a time, so there is nothing else in there for the Loader to see. When I look at the *gpi files with GPS Data Team's online editor, each *gpi file has as it's last entry the lat/long for my house, named as "Poi". However, this POI does not show in the listings of that file when viewed on the Montana, i.e. "Arizona Rest Areas", it only shows up in a separate list called "Garmin" with only that one identical poi in it, "Garmin" being repeated six separate times. Any of you gurus have an idea what's happening? |
01-06-2013, 06:00 AM
#6540 | |
Oddometer: 925
Jon...
