Old 01-02-2013, 05:27 PM   #6736
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 267
Originally Posted by Ryman View Post
Anybody know who makes the little aluminum bits that replace the plastic swingarm guards. Looking for a better tie down point for the giant loop.
http://www.advmachines.com/product_p/mduro1004.htm
I'll get me coat..............
Harty is offline   Reply With Quote
Old 01-03-2013, 06:59 AM   #6737
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Turns out the KTM dealer in Istanbul has new Exhaust and Intake rockers for me. I'm replacing those tonight.. they have also let me borrow a shim kit and I will return what I don't use
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-03-2013, 07:05 AM   #6738
yuu
yuu's Avatar
Oddometer: 122
Nice!
Onward to Tbilisi
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Old 01-03-2013, 07:26 AM   #6739
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,734
Awesome, hard to find such good dealers these days.
Old 01-03-2013, 11:59 AM   #6740
motoged
motoged's Avatar
Oddometer: 908
Noah,
That's good service and luck.....it would take me three weeks to get parts
Also following your RR and digging it.....latest intel suggests Croatia in the summer is the ticket
Have fun riding the slopes....
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 01-03-2013, 05:35 PM   #6741
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,142
whoops wrong thread
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan screwed with this post 01-03-2013 at 06:02 PM
TheMuffinMan is online now   Reply With Quote
Old 01-03-2013, 08:05 PM   #6742
Unkgd
Oddometer: 345
Might want to replace that roller
Take this FWIW - especially as it is based on one picture. To me it looks like the surface of the roller is starting to fail and part of it is starting to flake off. Failure mode is often described as "brinneling" and basically the surface of the roller has a bunch of micro fractures and the metal starts spalling off as the fractures connect. Also looks like there is a matching track on the cam below it. Generally caused by excessive loading of the surface of the material.
Would recommend replacing the roller. Also check the other rollers as well for similar surface cracking indications.
Just out of curiousity - what weight oil are you running?
I was checking my clearance today and they are loose. So tomorrow I will shim them. On one of my intake rollers it has some funny wear or deposited that I have not seen before.
I have 1700 km to Tbilisi Georgia then I won't be riding for 4 months to rebuild the suspension and whatever else is needed. It seems like my only option would be to get to Georgia then order parts if this should be replaced. Your thoughts?
Unkgd is offline   Reply With Quote
Old 01-03-2013, 09:35 PM   #6743
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,123
I think I have just come up with a design for an external fuel pump /duel pump/ manifold for multiple tanks its so simple .
Now I just have to get it out of my head and on to paper
Mudguts is offline   Reply With Quote
Old 01-03-2013, 10:23 PM   #6744
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
I was able to replace both rocker arms last night. I have a theory about the increased loading.. I don't think the "automatic decompression" is laying completely flat when the motor is at speed.
The cam behind it was ok but there was some scaring on the decomp.
I am running 10W 60 Motul right now. Its been either that or Motorex 10W 60
Old 01-03-2013, 11:35 PM   #6745
LOZ
Oddometer: 1,206
HALLELUIAH
loz
LOZ is offline   Reply With Quote
Old 01-04-2013, 12:01 AM   #6746
Mudguts
Mudguts's Avatar
Oddometer: 2,123
It's really just another tank/ manifold that sits under the throttle body that the pump sits in with the Reg as the access hole
To the pump it will need to hold about 500ml .
So I'm thinking of a tube with reg at one end and pump at the other , I,ll see if I can mock some thing up , so the great minds of the ADV ride can refine and suggest .
Old 01-04-2013, 01:48 AM   #6747
nibby
Oddometer: 105
Originally Posted by Roostre View Post
Thinking of one of these for a 12 690 UK model and wondering if anyone knows
a. weight saving over the stock
b. how they are holding up to daily/weekly use, also if you leave the bike sitting for a few weeks.
Cheers
nibby is offline   Reply With Quote
Old 01-04-2013, 01:55 AM   #6748
Evil Invader
Evil Invader's Avatar
Oddometer: 696
Thumb
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 01-04-2013, 04:29 AM   #6749
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,653
Cheers
I have one of the other newer design batteries...brand slips my mind. The size is about the same as the original but if weighs about 80% less. It is so light in fact that i thought it was a display battery when it arrived
Seth S
Seth S is online now   Reply With Quote
Old 01-04-2013, 05:27 AM   #6750
nibby
Oddometer: 105
Weight is one of the reasons I'm thinking of upgrading but need it to be reliable also, dont fancy being stuck with no option but to push wish the 690 had a kicker, would be near perfect then
Times are GMT -7.   It's 08:35 AM.
