Old 12-26-2012, 10:26 PM   #301
_cy_ OP
Oddometer: 6,195
just got back from a short 21f degree ride and back home. was looking for an excuse to do a short ride with full heated suit blasting.. to test out new Earth-X ETX24, which did an outstanding job. as it took about 75 seconds cranking to start R80G/S. note this was starting from an unheated garage bike exposed to 21f degree for about 15minutes before starting.
kept the engine rev's up for all of 10 minutes it took to get there. then another 10min back. these LiFePO4 batteries don't have much in reserve amp hour capacities. ETX24 is a bit smaller than what I'm used to running. but it did an excellent job!!
_cy_ screwed with this post 12-27-2012 at 06:25 AM
Old 12-27-2012, 06:47 AM   #302
Global Rider
Alps Adventurer
Global Rider's Avatar
Location: Canada & the Alps - N 46 31.714' E 010 27.212'
Oddometer: 3,803
That battery is connected to the charging system, correct?
If it is, it isn't that battery that is doing the job of keeping your full heated suit warm. Its the alternator; either it can keep up to supply the X amps at 14V or it can't.
Note, run your starter in 10 second bursts and not 75 seconds of straight cranking. I know its cold out keeping the starter temperature down, but still.
All the best,
Alex
Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure
Euro & Alps Motorcycle Tours - Priced Right, How to go about
Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein
Global Rider is offline   Reply With Quote
Old 12-27-2012, 07:10 AM   #303
_cy_ OP
Oddometer: 6,195
come on... battery is connected to charging system of bike or it couldn't start. sorry was not more clear, 75 seconds total. actual crank times varied from 3 seconds to about 15 seconds with wait times in between to allow battery to recover and make sure starter armature doesn't melt. G/S charging system is putting out about 400watts and supports heated gear but rev's has to stay up.
purpose of ride last night was to duplicate worst case of long start time, full heated suit and short ride in 20f degree conditions. didn't recharge ETX24 last night.
rolled R80G/S outside at 7:31am... 21f degree outside. getting ready to go again. this time with meters documenting. we'll see how ETX24 cranks....
Old 12-27-2012, 07:27 AM   #304
_cy_ OP
Oddometer: 6,195
Earth-X ETX24 battery measured 13.04v @ 21f this morning after last night's brutal use without allowing enough runtime for R80G/S to charge battery back up. note actual capacity measured by Powerlab8 was about 6.3 amp hours. after battery gets a few cycles, capacity will probably go up some.
ETX24 at 13v is at aprox. 30% charged condition after last night's ride without charging battery. starter draws 181amp then falls... tests are stopped. note this test was designed to highlite a worst case senario of a short ride, hard start, cold conditions without recharging battery. what happens next morning....
we will be doing further tests with ETX24 fully charged under same cold conditions.
_cy_ screwed with this post 12-27-2012 at 07:52 AM
Old 12-27-2012, 07:37 AM   #305
Global Rider
Alps Adventurer
Oddometer: 3,803
Oh come on, you wuss. Thats not cold!
I used to ride daily to and from work with as much as 12 inches of snow on the ground and down to -23C (-10F). And the battery was a plain old FLA.
All the best,
Alex
Old 12-27-2012, 01:27 PM   #306
_cy_ OP
Oddometer: 6,195
it is for us Okies
Earth-X ETX36C installed in R80G/S ... much more comfortable with a properly sized battery in an Adventure bike!!!
_cy_ screwed with this post 12-27-2012 at 01:38 PM
Old 01-02-2013, 03:56 PM   #307
frogy
frogy's Avatar
Oddometer: 811
Don't forget about walking to school in 6 foot snow drifts with nothing but shorts and a tank top
2002 R1150RT, 1985 Naked K100RT
frogy is offline   Reply With Quote
Old 01-02-2013, 06:55 PM   #308
_cy_ OP
Oddometer: 6,195
did another Oklahoma wuss night ride ... bad conditions for a battery... cold start at 30f ... full heated gear for about a 20 minute ride to a buddy's house.
parked outside while they welded up a motorcycle carrier.... 3 hours later it was 20f ... Earth-X ETX36C cranked over R80G/S at 20f degree with authority.... 20 minutes to home with full heated gear.
this is where one needs a battery with ample spare amp hours. 20 minutes with full heated suit is not long enough to charge battery back up to full. as alternator is doing good just keeping up with added overhead from heated suit, etc.
next morning ETX 36C had power to spare!!!
Old 01-04-2013, 03:53 AM   #309
legasea
Ape on wheels
legasea's Avatar
Oddometer: 161
After all this reading, my LFX 18 went to live in the K12 where it does it's job nicely.
For the 1150 ADV, I'll wait a bit more as this thread goes and the Exide keeps his power.
Thank you all, battery minded fellows for filling our ignorance.
ADV....SE
It's God's fault if atheism is growing
legasea is offline   Reply With Quote
Old 01-10-2013, 05:06 AM   #310
_cy_ OP
Oddometer: 6,195
LFX18 is likely too small for BMW 1150 adventure. when battery are sized for when conditions are ideal for battery. ie warm temps and no issues with engine. ie .. engine cranks for about 1 second, fires and starts. then charging system takes over any electrical needs like headlights, heated grips, etc.... battery gets topped off
LiFePO4 battery's tiny amp hour reserve doesn't come into play.... yet. all that changes the first time engine will not start without extended cranking. Let's say your small LiFePO4 battery has an actual capacity of 6 amp hour. compare to BMW gel cell battery of 19 amp hour vs Odyssey AGM 28 amp hour.
ability of LiFePO4 battery to deliver cranking amps is different from that same battery's ability to deliver extended crank times.
this is why for most folks my recommendations is to go with a quality AGM battery for adventure bikes. unless the weight savings is worth the $$$ and trouble to learn LiFePO4 cold start procedures.
Go with Earth-X ETX36 or Shorai LFX36 ... these are two of the largest LiFePO4 motorcycle specific batteries available. actual amp hour measurements are posted a few pages earlier. both ETX36 and LFX36 will deliver monster cranking amps for extended crank times.
Shorai LFX36 has been tested in R80G/S for almost one year. LFX36 has not missed a beat. includes extensive cold crank times. and surviving deadly combo of extended cold starts/heated gear/ short rides times. then have enough reserve amp hour to start R80G/S next morning at 20 degrees.
Earth-X ETX36C is currently in R80G/S. it's performance has been outstanding. lots more winter left to see how ETX36C holds up....
weight comparison: Odyssey AGM 22lbs vs Earth-X ETX36C (3lbs 11oz) or Shorai LFX36 (4lb 14oz)
so we are talking about saving a whopping 18lbs with ETX36C and saving 17lb with LFX36
_cy_ screwed with this post 01-10-2013 at 05:35 AM
Old 01-10-2013, 05:28 AM   #311
_cy_ OP
Oddometer: 6,195
li-on battery described below are not Lithium iron phosphate (LiFePO4). which are inherently stable and very hard to cause a fire. unfortunately one cannot say the same for lithium cobalt Li-on batteries.
note lithium polymer batteries can be molded into almost any shape to take advantage of existing space.
Boeing is confirming that a fire on one of its new 787s appears to have started in a battery, as scrutiny of the problem increases.
Also Tuesday, the National Transportation Safety Board said it will send two more investigators to Boston to examine the Japan Airlines plane. The NTSB says the battery had "severe fire damage."
The fire happened on the ground Monday, with no passengers on board. But in-flight fires can be catastrophic, so the matter is getting close scrutiny by aviation authorities.
Old 01-10-2013, 06:45 AM   #312
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,058
Vstrom Battery Advice
Hi all,
i tried to read through this battery thread, but there's so much I get a bit lost.
I've got a Vstrom, DL1000, 2006, and I have no idea what battery to get. I run a decent compliment of stuff, including lights, aftermarket horn and heated gear.
Mind just pointing me to what I should buy? I'll also be at the IMS show here in NYC, and figured there might be some vendor deals on the new tech there.
Thanks,
George
2012 BMW R1200GS
www.TeslaLEDS.com
www.NYMSTF.org - Support NY Riders!
GHO100 is online now   Reply With Quote
Old 01-10-2013, 08:21 AM   #313
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
Originally Posted by GHO100 View Post
Hi all,
Thanks,
George
For the EarthX is the ETX18C. PM sent.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 01-11-2013, 11:18 PM   #314
_cy_ OP
Oddometer: 6,195
strangest weather... 62f degree at mid-night January 11, Tulsa, OK
Old 01-12-2013, 11:19 AM   #315
_cy_ OP
Oddometer: 6,195
winter is trying to make a comeback in Tulsa, OK...
here's a Press Release from 2006, re: Thales and GS Yusa, makers of Li-ion prismatic cells for Boeing 787.
GS Yusa makes aircraft Lithium Cobalt Oxide prismatic cells in 10 and 65 amp hour sizes.
besides main power backup for entire aircraft. above lithium cobalt li-ion batteries are also used to backup electronic aircraft control systems used extensively on Boeing 787.
it's understandable why lithium cobalt were spec'd back in 2005 era. but what's not understandable is why project engineers didn't pickup on the rash of new data generated by all the li-ion (lithium cobalt) fires connected to Sony laptops, etc and other consumer li-ion powered devices exploding.
then factor in fires related to transporting li-ion batteries resulting in new regs by FAA restricting transport on aircraft. it's inexcusable Boeing project engineers didn't pickup on inherent dangers related to lithium cobalt batteries.
what's most worrisome ... should a li-ion battery fire start on a backup power unit for an airplane control. fire could take out a perfectly good electronic control system causing aircraft to lose part of it's flight controls.
IMHO lithium cobalt cells should have never been allowed into production for this mission critical application.
Thales selects GS Yuasa for Lithium ion battery system in Boeing’s 787 Dreamliner
June 12, 2005, Thales will incorporate the latest lithium-ion technology from Japan’s leading
battery manufacturer, GS Yuasa, in the Electrical Power Conversion System of Boeing’s next
generation commercial airliner, the 787 Dreamliner. The multi-year, multi-million dollar contract
is a historic first as it marks the first commercial aviation application of Li-ion technology
anywhere in the world.
GS Yuasa’s Li-ion batteries will play a key role in on-board power, providing both Auxiliary
Power Unit start and emergency power back-up capabilities. In the first phase of the contract, GS
Yuasa will deliver prototypes to Thales starting in spring, 2005 and mass production will starts
for Boeing’s latest plane in 2007. ~
_cy_ screwed with this post 01-12-2013 at 12:03 PM
Times are GMT -7.   It's 01:06 PM.
