Old 01-02-2013, 10:20 AM   #3781
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,096
Originally Posted by Foot dragger View Post
I need an ultra-sonic cleaner as well,I used to use them all the time when I was a dental tech, They get the tiniest pieces out of the smallest crevices much easier. Some shops have em big enough to clean a bank of carbs in,best way to clean carbs from what Ive heard.
Yep the same HF ultrasonic cleaner with simple green as the solution works great on carbs! They come out looking like brand new!
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 01-02-2013, 10:54 AM   #3782
S H I F T Y
S H I F T Y's Avatar
Oddometer: 725
Just passed 5200 miles on my '08. Valves in spec, compression / leakdown still perfect
S H I F T Y is online now   Reply With Quote
Old 01-03-2013, 09:26 AM   #3783
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,899
Glad to hear the bike's working out and nice pic! Im heading out into the icey wonderland that is nor cal on mine tomorrow morning,scouting out the snow level for a singletrack ride on saturday..
I just picked up an 09 200 XCW and only have a couple rides on it so far,truly a cheater bike for the tight woods.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 01-04-2013, 06:45 AM   #3784
TipsyMcStagger
TipsyMcStagger's Avatar
Oddometer: 1,025
What would be the recommended gearing for riding the TET (1000+ miles) on an '08 450 EXC?
Tipsy
2008 Buell XB12X Ulysses
"There's a plane! Where there's a plane there's probably a pilot! Where there's a pilot there must be a bar! I can finally get a drink!" - Brian from Family Guy
TipsyMcStagger is offline   Reply With Quote
Old 01-04-2013, 07:11 AM   #3785
neduro OP
Addict
neduro's Avatar
Oddometer: 12,052
Tipsy
I'd go 14/48, or nearly equivalent 15/51.
Much taller and it will struggle to pull 6th with wind/ grade unless you're flat out.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 01-04-2013, 07:18 AM   #3786
TipsyMcStagger
Oddometer: 1,025
Okay...thank you!
Tipsy
Old 01-04-2013, 07:40 AM   #3787
Foot dragger
singletracker
Oddometer: 12,899
Okay...thank you!
Tipsy
Im pretty sure my 530 will buzz to 100 with 14/50 gearing,for lots of singletrack I would have 13/50 on it.
65mph cruise is easy with 14/50.
Old 01-04-2013, 08:02 AM   #3788
Junglerot
Hodor!
Junglerot's Avatar
Oddometer: 3,436
Hodakaguy
Use caution with simple green and aluminum, it can oxidize the carb if left too long. I do believe they make an aircraft version that is aluminum safe, but I prefer to use a 50/50 mix of pine sol and hot water.
What's the worst that could happen?
Junglerot is offline   Reply With Quote
Old 01-04-2013, 01:25 PM   #3789
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,872
Pine Sol does a great job on carbs. I also use it 50/50, and just leave the carbs in it overnight. It won't attack any of the metals in the carb, but it is conductive enough to allow a little galvanic corrosion because of the dissimilar metals. The little bit of "bloom" you get on some of the parts will wipe off.
It would take the carbon off of biopig's valves, too; but it would take the paint off the head. Carb cleaner, a bottle brush, and elbow grease will get the exhaust ports clean enough.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 01-04-2013, 01:28 PM   #3790
biopig
biopig's Avatar
Oddometer: 28
The brown truck just delivered a box of orange!!
All the parts for top end rebuild and fork rebuild.
biopig is offline   Reply With Quote
Old 01-04-2013, 01:39 PM   #3791
KMC1
There is no spoon.
Oddometer: 2,561
I'm a *little* bigger than a lot of the guys out riding trails , I went to 14/52 gearing on mine, and it's still a little tall on some of the tight stuff. Even with me on it, the front wants to come up a LOT on the street.... gotta be careful about that.....but it runs good enough to get from home to trail head.
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 01-04-2013, 05:30 PM   #3792
biopig
biopig's Avatar
Oddometer: 28
Just did a test fit of my new compression ring in the cylinder. Measured end gap at 7 thousands, I was surprised it was so tight. Is this typical with new rings? Should I file to make end gap to around 15 thousandths. Anybody have any good links on how to file rings. My old measured at 30 thousandths, this was at 140hrs. Picture shows new oil ring compared to old.
biopig screwed with this post 01-04-2013 at 08:04 PM
Old 01-05-2013, 08:17 AM   #3793
Foot dragger
singletracker
Oddometer: 12,899
Seems like the shop manual would tell you just what clearance to set it at? No point guessing.
Old 01-05-2013, 11:17 AM   #3794
biopig
biopig's Avatar
Oddometer: 28
Couldent find it in the shop manual, I'll have to take another look. Thanks
Old 01-10-2013, 10:31 AM   #3795
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
So my bike does not have the manual cam chain adjuster and have not heard a loud noise from videos I've seen of people who needed to replace but when I'm giving my bike gas I notice a slight different noise but have heard others who made the same noise, normal?
Here's a video of my bike idling, I'll have to make another of riding it.
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Times are GMT -7.   It's 06:19 PM.
