Old 01-04-2013, 02:58 PM   #1
themightywheel OP
Oddometer: 2
Paint over Powder Coat
Looking to spray bomb tins that have been powdercoated. need help with the best steps to take. I'm using spray bombs, and wanna clearcoat with automotive-grade polyurethane...yes or no on that??? OPTIONS, PLEASE...Thanx Y'all!
themightywheel is offline   Reply With Quote
Old 01-04-2013, 06:17 PM   #2
sb955i
Grudge no toil.
sb955i's Avatar
Oddometer: 75
I have tried spray bomb over powder coat... It doesn't adhere directly and easily flakes off. You might try an intermediate layer of primer, but I haven't tried that.
SC Brooks
'15 BMW R1200GSA LC, '05 BMW R1200RT, '02 KTM 640 LC4 Adv, '99 Wife #1,..
"In order to maintain an untenable position, you have to be actively ignorant" - Stephen Colbert
sb955i is offline   Reply With Quote
Old 01-04-2013, 06:46 PM   #3
Beezer
Oddometer: 5,940
and an automotive grade clear coat is likely to wrinkle spray can paint
Beezer is offline   Reply With Quote
Old 01-05-2013, 06:14 AM   #4
showkey
Oddometer: 1,998
There are a lot of variables to make spray bomp paint stick on any surface not just powder coat, but generally clean the surface with a solvent prior to doing anything, then a complete wet sanding the old surface with 220 to 400 grit wet dry paper should done. Grit choice determined by surface finish needed. Primer can help but it must be compatible with finish coat. Mist coats first then regular coats and apply at proper temp with proper drying between coats are just some of the variables. The choice for the top coat ( brand and chemistry) is another variable that will effect the out come. The clear coat adds another variable and it must be compatible with all, the prior applied products brand and chemistry help to avoid bad things from happening with spray bombs then switching to auto clear coat. Is the clear going to in spray bomb? It may help if it the same brand. If the parts are valuable test panels would be a good idea.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey screwed with this post 01-05-2013 at 06:21 AM
showkey is offline   Reply With Quote
Times are GMT -7.   It's 07:15 AM.
