Old 01-05-2013, 08:00 AM   #16
CloudchaserSakonige OP
CloudchaserSakonige's Avatar
Oddometer: 53
Originally Posted by mouthfulloflake View Post
I even did the cross reference work for you.
order an etx12L instead if you want the pos/neg terminals on opposite sides.
take a meter with you, make sure the battery is charged when purchased
I've already ordered a Yuasa, but I do appreciate the info! It may come in handy at some point :-)
Photo taken at Mountain Motorsports Kodak on February 12 2013 http://tinyurl.com/cvgn4tc
On the Dragon on April 13 2013 by killboy.com http://tinyurl.com/clnor2z
My other ride is a Kymco Grand Vista 250 http://tinyurl.com/c9acaph
CloudchaserSakonige is offline   Reply With Quote
Old 01-05-2013, 01:50 PM   #17
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Originally Posted by CloudchaserSakonige View Post
Will keep that in mind, thanx!
I'm curious, how big?
I've built engines as big as 145 CI on the Twin Cam platform. Generally 113"-136" is the affordable range. And affordable depends on your wallet's contents.
I've collaborated on a few really large FrankenEngines using billet components fabbed in a machine shop combined with automotive stuff. 160" CI is the limit there by way off the shelf parts like cranks. Finding cam/valve trains to feed those big bastards is the real limit.
BTW if you're going to charge untended use a dedicated smart charger that uses a microprocessor to determine how and when to float it.
you don't see luggage racks on a hearse..........act accordingly
Old 01-05-2013, 11:37 PM   #18
Oddometer: 53
That's huge! I knew they could be bored and stroked, but not that much!
I have a Schumacher SE-1-12S 1.5 Amp Slow Charge/Maintainer. It automatically senses when the charge reaches 14v, cuts off, then comes back on if the charge drops 1 volt.
Old 01-06-2013, 06:14 AM   #19
anotherguy
anotherguy's Avatar
Oddometer: 6,631
When you get that far along the trail there's little if any Harley left in 'em. What is left doesn't resemble what sat on the showroom floor.
Old 01-06-2013, 10:25 PM   #20
The Shifty Jesus
Oddometer: 65
If you can, buy a battery dry with the electrolyte on the side. Read the instructions for filling, capping, and charging and follow them closely.
Doing it incorrectly (as happens more often than not), pretty much cuts the life of a battery in half from the get-go.
The Shifty Jesus is offline   Reply With Quote
Old 01-07-2013, 04:25 AM   #21
vfxdog
Oddometer: 618
A sealed AGM battery is a far better bet these days. Most batteries that come with acid separately are going to need constant maintenance (electrolyte level checking and topping up) throughout their lives, plus they are prone to spilling in the event of the bike ending up on its side.
vfxdog is offline   Reply With Quote
Old 01-07-2013, 06:07 AM   #22
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,338
That's what she said.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Times are GMT -7.   It's 01:57 PM.
